Please help? need help with bixenon height
Just installed h&r cup kit and 19 inch wheels. After installation, the lights seemed to point to the ground more. I have the factory bixenon and I am trying to adjust the level of the lights to be higher as they were when they were at stock height. I have it adjusted too high on the driver side and good enough on the passenger side. I adjusted the knob on the lights but can't get the driver's side back down. Anyone have any ideas? Is it something to do with the autoleveling?
1 Post
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
citron, how do you know if the bi-xenon is level? I installed them myself and i think they are a bit low pointing to the ground. When i drive, I am scared because I cannot see that much in front of me....can I adjust these somehow? Either by adjusting them with the screws or is there the projector adjustment?
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
If this has happened, what you need to do is pull the reflector into place and alignment while turning the screw, to get the adjustment nut back onto the screw.
If you're not mechanically inclined, I do not recommend doing this yourself as you may mess up all kinds of things, or end up getting shocked, or who knows.
-s-
2015 E250D
If you instsalled them yourself, then you do not have the auto levelling feature. I think there is a way to manually level them. Do a search.
1 Post
W215 CL600
Easy to adjust...just take a phillips screwdriver and turn right to go higher, left to go lower on the black, plastic screw located on the top of the housing. My passenger side was way too high after install, all I did was take a phillips screwdriver and turn to lower the beam.
1 Post
2003 Citron Green C230KMT
are the BIX factory or retrofitted. if they are factory take it to the dealer for calibration, then the auto leveling feature will work ok. i installed my AMG sways and had to have then re adjusted and after my accident where they had to replace a headlight it required the new headlight to be cliabrated as well.
yeah it looks like i may have adjusted them too far. but how hard is it to pull the reflector into place and getting it back onto the screw to adjust the height level again. do you have to open the back of the light where the xenon bulb goes? I have the factory bixenons on the car and thats what may have happened
1 Post
i was told by the dealer they do the calibration. not sure with a computer or manually but they do it and its up to spec. i suggest you make an appt. and take it in. it will be done right and if your cars under warranty they should do it for free. just tell them the lights are level. are you taking it to MBSD?
i took my car to mb of escondido, where i bought my car and the level of the headlights are the same. it says on the service order that the headlights were brought back to spec. i don't know whats the deal with that? do they know what they are doing.
i tried messing with the lights to see where the adjuster seems to adjust the height for the bixenons. I opened up the back for the bixenon and notices that the angle plate just moves freely up and down. I dont know if it is possible to fix it without any knowledge of how the adjustment works with the plate. i could feel that when i turn the knob i can feel it turning but doesn't seem to do anything. i brought it to the dealer in mb of sd and they said some machine is set up to adjust to factory specs. i dont know if when i get my car back, that it will be fixed. would i have to remove the bumper and try to take the headlights off to see what has really happened to get a better view of the headlight itself?
CLK 320
Since you seem to be having problems with them, the worst-case is that you completely b0rk them, or shock yourself, or both -- and you're not gonna be any better off than you are now. That's not even worth it if the dealer is able to get them fixed. If it's daylight out, take the car back at dusk... or early in the morning, or take it to their warehouse, or something. If they say they brought it back to spec and it's still not right, then they're either lying or there's a bigger problem at hand -- one that you're probably only going to compound by opening them, taking them off, mounting them again, etc.
1 Post
the dealer can calibrate them. ive had mine done 2x. first because the auto leveling wasnt working right after i installed my AMG sway bars, the second was after my accident they had to install a new driverside headlight and the headlight required calibration.
let the dealer fix it. i totally agree with viguera on this one!
