Coupe door panel removal
Old Jul 22, 2004 | 11:32 AM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Post Coupe door panel removal
After searching so many times for this I putted hands to works.
(sorry fot the bad quality, taked from a nokia 6600)
1-pull out the srs badge and remove the star screw
2-under the door arm rest there is a cover, popit off and remove the screw
(drop the window)
3-remove the c-shaped plastic piece by the door latch
4-slide of tweeter grill cover
5-pull the panel to pop the push pins all around the cover (sides and down, use a big screwdriver to make a lever, or use a specif tool)
6-lift the panel from the top near the window all the way
7-remove the cable from the pull handler
8-remove the electric window/seats switch from the module
and thats all folks
Attached Thumbnails Coupe door panel removal-1.jpg   Coupe door panel removal-2.jpg   Coupe door panel removal-3.jpg   Coupe door panel removal-4.jpg   Coupe door panel removal-5.jpg
Old Jul 22, 2004 | 12:05 PM
gaiex's Avatar
Attached Thumbnails Coupe door panel removal-6.jpg   Coupe door panel removal-7.jpg   Coupe door panel removal-8.jpg
Old Jul 22, 2004 | 02:57 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
DEFINITELY use specific tools... I would recommend that people not use metal tools when doing any "prying" (the badges or the door panel or trim pieces). It's too likely that a scratch can be made.
Plastic wedges are the best tools for that, they are of a soft yet strong plastic.
-s-
Old Jul 22, 2004 | 03:05 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I used an old credit card to remove my badges. They're very simple to remove, and don't require much force.
I agree about the panels; I'd get a door panel removal tool - they're cheap, and much cheaper than fixing an "oops, sh*t!" slip of the hand.
Old Jul 22, 2004 | 03:09 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
I agree with the others, specific tools are the best for these kind of jobs. Thanks for sharing the pictures..
Old Jul 23, 2004 | 08:51 AM
gaiex's Avatar
I done the job with no scratch!!!!
and if you wanted you could remove the badges with your finger tips, its possible... :p
I used the screw driver only to demonstrate
Old Aug 8, 2007 | 08:25 PM
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
thx
Old Aug 8, 2007 | 08:40 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
now this was a thread worth resurrecting !
Thanks Brabus_x2 !
Old Aug 8, 2007 | 08:55 PM
KIRA's Avatar
Thanks Brabus_x2 !
nahhh lol thx advan lol
Old Aug 8, 2007 | 08:59 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Either way, it was a very valid bump because it made it easier for me to add this to the D.I.Y. / AFTERMARKET MODS STICKY.
Old Sep 5, 2007 | 03:54 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
As always, the forum comes through.
I've taken the above, made into a word doc, printed as a pdf, and uploaded to the site that you can download and print w/ pics.
Thanks gaiex !
New rear speaker panels, to be installed.
EDIT-Speaker grill installed, no more hole from the seatbelt.
Part was $15. I've heard people say they paid $250 or more for this job?
wow. It was not hard.
I added some info, like T screw sizes, brightened up the pics, and
here it is for your DIY'ing pleasure.
Melting the plastic with a butter knife was the funnest part.
Now that I've done it once, it wouldn't take more than 10 minutes to remove and reinstall the panel.
Thanks again to Gaiex!
File Type: pdf
Old Oct 6, 2007 | 10:00 PM
KIRA's Avatar
Thanks gaiex !
i guess i ma shop home depot for T20 and T30 screw now
Old Oct 7, 2007 | 07:51 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Why do you guys need specific tools? All you need are the 2 torx drivers. For step 5, fingers will easily do the trick.
Old Oct 7, 2007 | 08:48 AM
gaiex's Avatar
I made this DIY 3 years ago when I was installing my 2ways focal 16cm at front and 3ways 13cm at back door.
3 years passed and I yet didn't fixed the crossovers well!
This week I will install a OEM Bose sub and a magnat amp to push my focals and the sub, since the comand sound is crap (audio 10cd was much much better)
Old Nov 20, 2007 | 07:14 PM
KIRA's Avatar
WOOOOHOOO!!!!!!!!!!
open my door panel in 2 mins!!!
replace new speaker 2mins
put everything back together 2mins
return my tool back to home-depot 2mins(yaaa i did all these job outside the parking lot)
return my broken speaker back to the stealer for my $70bux back-40mins
well gotta love your help for the DIY
Old Nov 22, 2007 | 06:24 PM
I'm telling your Mom, you're a very bad boy!
Then again, ripping off the stealer?
Oh.....the irony....
Tell me it was Smyth...please...
stick it to 'em. And tell 'em to stick there $300 oil changes too.
Old Nov 22, 2007 | 09:44 PM
KIRA's Avatar
of coz is smythe, I ain't driving 200 miles for another dealer
and no, my parent thinks that's a really good idea coz i end up fixing something for free
lol $300bux oil change??
DIY cost you 50bux MAX with 0W-40 and filter while dealer change it with 5w-30
lol i still wanna know how i can do an oil-change
Old Nov 23, 2007 | 10:43 AM
I do my own oil changes now. Since I got oil on sale at Kragen,
3.50 + 2.50 a quart rebate, it only cost me less than $20.
Nice....
Old Nov 23, 2007 | 03:54 PM
KIRA's Avatar
Nice....
wait how??
you need 6 quart right??
the guy did oil change for me said i need 6.5 quarts
and it cost about 6bux per bottle of 0W-40 (so about $36)
and a oil filter (my friend told me they should cost about $2 but i can't find it only the STP filter for $15 )
what oil do you use??
do you drain it or pump it out?
Old Nov 23, 2007 | 07:23 PM
spyderpig's Avatar
'02 CL203 M111
our car requires 7 us quarts according to the owner's manual. I guess you can go 6.5 quarts. If you put 6 (what I've tried) the oil check tool tells you to add 1 quart.
Old Nov 23, 2007 | 07:43 PM
KIRA's Avatar
ahh thx, coz that's what the guy told me, he said i need half a bottle more, and i think in my mind that too much oil won't do the car any good since my is only 2.3L
i think i will add half a bottle more now
Old Apr 18, 2008 | 05:14 PM
Midnight Koop's Avatar
CL203
anyone know how to remove the rear side panels in a coupe?
gaiex?
Old Apr 18, 2008 | 08:38 PM
jedcred's Avatar
'04 Mars Red C230K Sport Coupe (not Coup-EH)
gaiex?
Vilkomen. To. Hell. (I kid, I kid).
First, pull off the plastic runner on the bottom of the front door. This is the plastic cover that is right after the Mercedes-Benz text on the bottom of the door jamb. This will help you because that covers part of the back panel.
Next, pull off the SRS badge and unscrew the torx screw behind it (same as the front SRS badge size, I think). Then pull up the bottom rear seat (there's a small loop on the side of the seat, pull it and the seat rotates up). The bolster that makes up the portion between the fold-down back and the side panel is secured with a small nut on the bottom which was revealed when you pulled up the bench seat. Undo the nut and then you should be able to pull the bolster off.
At this point, it will probably make your life easier to remove the side of the bench seat you're currently working on. To do this, first pull up the seat itself, then pull back the black covering underneath. The straps attach to two nuts underneath the black covering, so remove them. Then, use a flathead to pop off the plastic covers on the bottom of the seat, near the floor. Undo the two nuts behind them, then remove the seat.
OK. Now, you have to start pulling outward on the panel, starting from the front side and bottoms of the panel. This portion uses the same plastic clips as the front doors, so they pop out the same. Once you feel the sides and bottoms are reasonably free (sorry, I forget the number of pop-clips on this panel), start pulling up. The hardest part will be the part that clips into the front of the window; it's very stubborn. There are three metal clips for that top portion; don't lose them.
A word of warning. The back panels use thick black plastic hooks behind the upholstery sections of the panel. They're slotted into square holes in the body of the car. Make sure to pull up before you pull out, else you will break them. I broke one side's hook; it's a little looser than the other side, but not in a really bad way. It would behoove you, though, not to
Let me know if you need some pics or something like that.
EDIT: You know, I don't remember if I had taken out the seat backs before I took out the side panels. Just looking at it, with wrangling, it should come out if you work around the seat back. If you need to take out the seat backs, that's another set of steps. The thing is, both sides need to come out for one side to come out, so hopefully there won't be a need for that.
Old Apr 19, 2008 | 12:55 AM
CL203
any pics or guides would be superb... i am looking to do something similar to what you did with your interior... but the people making the interior are hesitating with the panels because of the airbags. right now they don't want to do the panels because of liability issues... so i'm trying to convince them to at least make them and let me put them in if i can take off the panels myself.
if you could post any or all of the photos you took of your install i will be eternally indebt... or even better a write up/DIY!
i love your interior and hope i can upgrade from my cloth too! different color scheme of course.
thanks
Old Apr 19, 2008 | 12:16 PM
jedcred's Avatar
thanks
Unfortunately, like all my projects, I was thinking more about getting the project done rather than taking pictures, which I really should have in retrospect. However, we can get away with properly annotated external pictures, and that's what I'll do on Sunday.
In the meantime, if they're just looking for a sample panel to see what they can do, give them the front passenger door. It's much easier to pull out and put in, and it is 99% the same idea in terms of removing the upholstered panel from the door and reattaching it, and the panel has the airbag mount behind it just like the rear panel. If you need to carry passengers, all they have to do is pull the little hook and they can still open the door (which I had my passengers do for a week or so ). The only thing you should worry about is taping the tweeter and the window control to the door so that they don't get caught in the door jamb.
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
