The Truth about Netherlands Setting
Old Feb 4, 2007 | 07:20 PM
  #176
c230_04's Avatar
04 C230 SS
Will the stealership charge me for wanting this setting ? If so how much. My car is still under warranty there shouldnt be any charge right ?
Old Feb 4, 2007 | 07:21 PM
  #177
harpz's Avatar
some will do it for free others charge something like $25+ and some won't even do it period...its between you and your relationship with the dealer
Old Feb 4, 2007 | 07:22 PM
  #178
harpz's Avatar
BTW a search would help you greatly! this has been discussed numerous times, you may want to check out the user sunman, he has the baddest C class ever! he's got heated seats in the back everything! (even stuff you can't get)
also contact MBenzNL (Steve and or Wanda) they have many things you can retro fit into your car (i.e. Command, parktronic etc...)
Old Feb 4, 2007 | 08:24 PM
  #179
yeuchau's Avatar
Stage 2 C7 A6, QX60
Originally Posted by harpz
my mistake Netherlands setting
https://mbworld.org/forums/showpost....6&postcount=13
there's the link
i like that
my aunt's car has that sound
Old Feb 4, 2007 | 08:37 PM
  #180
rlee02135's Avatar
2004 C32 ///AMG
i have it, its alright...
its more of a BEEEEP, BEEEEP, BEEEEP...
i like the bimmer's beepbeep when you open and beep when you lock..
Old Feb 4, 2007 | 08:54 PM
  #181
WaveyKat's Avatar
Something Slow
this was spoken about many times click thiis link you will get video sound and everything
https://mbworld.org/forums/showthread.php?t=169496
Old Feb 4, 2007 | 09:46 PM
  #182
yeuchau's Avatar
Stage 2 C7 A6, QX60
just checked
that sound is different than the 07 C sound
Old Feb 4, 2007 | 09:55 PM
  #183
SUNILP's Avatar
2015 E250D
The netherlands setting will remove the panic feature and enable the chirp. if you want both, you need to use a star diag with developer mode. This will enable you to switch the duration of each beep, the number of beeps for unlock and lock. I don't know of any dealers that have star diag with developer mode.
Old Feb 4, 2007 | 09:56 PM
  #184
yeuchau's Avatar
Stage 2 C7 A6, QX60
that's nice to know
Old Feb 4, 2007 | 10:28 PM
  #185
LuxuryC240's Avatar
2003 C240
Anyone have this done in Massachusetts for free? If so, which dealership?? I asked my nearest dealership, they said they weren't able to do it there.
Old Feb 5, 2007 | 01:11 AM
  #186
GINO-ESC's Avatar
turning it on or off does not affect the panic feature, my dealer had it turned on after some warrantee work and the panic feature also worked. What a pain the the rear, I had to make another trip to the dealer to have that stupid noise turned off. That stupid beep noise was cool like 20 years ago. turn it off and just flash the lights. A lot classier than beeping like every toyota in the parking lot.
Old Feb 5, 2007 | 03:06 AM
  #187
phattbam's Avatar
'08 BMW e92 335i
what year is your C class? And do you know what settings it was? I'd like to get my panic button working again..
Old Feb 5, 2007 | 10:14 AM
  #188
GINO-ESC's Avatar
I drive an 05 c230SS. My dealer first told me that it couldnt be done. I explained that it could and it was working the way I wanted it before my service appointment. They had me talk to the tech and I told him to look in the star diag. for the netherland setting. Five minutes later I had my car back and the chirping was off.
Old Feb 5, 2007 | 12:14 PM
  #189
phattbam's Avatar
'08 BMW e92 335i
hmm I must have misread and thought you had it chirping and had the panic button working.
Old Feb 5, 2007 | 07:22 PM
  #190
sdsilverm3's Avatar
Steve enabled the Netherlands setting on my car and my panic feature still functions.
The beeps are convenient so you don't have to keep looking back at the car to make sure it actually locked.
Old Feb 5, 2007 | 07:55 PM
  #191
cla 1000's Avatar
2002 C230 K, 6 speed
Hei. Would you be able to set mine up so it does the crip? I'll pay you.
Old Feb 5, 2007 | 08:59 PM
  #192
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I like the panic function...mostly when I'm panicking because I have no idea where I parked.
Also useful for dispersing people....for whatever reason...
I used it because some numnuts was leaning on my car...it took several times for him to get the hint. Or if some undesirables are hanging about in the vicinity.
Old Feb 5, 2007 | 09:39 PM
  #193
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
My panic function still works. I don't know how, but Steve is the one who programmed mine. Netherlands setting and Panic function!
Old Feb 5, 2007 | 09:41 PM
  #194
phattbam's Avatar
'08 BMW e92 335i
yeah.. for parking lots it's great to have it.
Old Feb 5, 2007 | 09:45 PM
  #195
SUNILP's Avatar
2015 E250D
that would be fine.
Old Apr 16, 2007 | 07:59 PM
  #196
power-fade's Avatar
"One Man. One Engine."
Mine came from factory w/ Netherland setting (chirps for arming and disarming) and the panic feature also works.
Old Apr 17, 2007 | 01:39 AM
  #197
pmb600's Avatar
E550 4MATIC
That's because you have a 2006. That was the year that they made the chirp widely available on the cars without having to do Netherlands setting. Although I did see a 2005 E55 AMG that did the chirp and was not Netherlands setting. I think for the W211 they had this feature in earlier model years.
Old Apr 17, 2007 | 01:48 AM
  #198
power-fade's Avatar
Thanks for the clarification.
Old Apr 17, 2007 | 01:56 AM
  #199
14cue's Avatar
05 C55
i want these feature. i wonder if my SA will hook that up...
what is the exact name under Star, anyone? i know it's under country "NEATHERLANDS" but i am sure my SA will ask me where to set that.
edit: i dont care for the panic mode, if i lose that, then so be it.
Old Apr 17, 2007 | 06:12 AM
  #200
SUNILP's Avatar
2015 E250D
Rear Sam
