Supercharging VS Turbocharging Pros and Cons?
Supercharging or turbocharging your MERC.
I'm new to this forum, so I was interested to know who has done either, which one is more reliable, advanced, cost efficient, the MOST POWERFUL?
IF there are some experts in this forum, I'd really appreciate your input.
Sorry, if I'm repeating somthing you guys may have already talked about, but it would be nice to revisit it again,
Thanks.
Nighttrain.
in the long term both will shorten the life of the engine dramaticaly.
turbo usually has leg and s/c don't. s/c are bolt on to the engine body and the turbos are not.
for the power it depends on the boost pressure of the s/c and turbo. turbo, i believe it can produce and sustain more pressure than the s/c. Since s/c are usually mechanical belt driven it will have more power available in all rpm. i.e. my C32 has the belt driven s/c with clutch, the s/c will engage as low as 1500 rpm when you punch the gas. for the turbo cars the turbo fans have to spin at/after certain rpm to produce the power.
IMO go with the turbo mod since it can be easier to be done which means usually less money involve.
if you are looking to have more technology in your car go with the s/c since s/c are said to be technicaly more advance. i have s/c in my car although it's factory mod
PRO'S
1 always there. there is never a turbo lag.
2 increases HP very well
3 makes the car sounds cool
4 you will usually get a much wider powerband
CON's
1 take away HP to make HP
2 increases wear on engine
3 more to break
TURBO'S
PRO'S
1 easy to mod. You can increase the HP of a stock turbo using a computer chip.
2 you can get an on-the-fly boost controller to really decrease engine wear when you dont need all that power.
3 cheaper to mod.
CON'S
1 LAG. although it depends on the size of the turbo, there will more than likely be some sort of turbo lag.
2 decrease engine life.
IMO I would rather have a turbo too. They are so easy to modify. Look at the Audi S4. You get a $500 chip from APR and it goes from 250 hp to 306 and like 275Torque to 366Torque. all electronically. Yeah there will be some turbo lag, but the increase in HP will make up for it. My friend has a 3000GT VR4 with an "on-the-fly" boost controller. he can run anywhere from 4-22psi, just by turning a knob on the controller that is located under his dash. When he is cruising on the interstate he turns it way down, and when racing way up. It really will help the engine life alot.
TURBO
PROs: Blow off valve....pSsSSSSHHHHH!
I would take the turbo for that fact that i can control the boost. Also, i have more experience with turbo (which you probably dont care, cuz that reason wont help you.....unless you have questions. ) NEWAYS..
...But then agian...i wouldnt mine TWIN CHARGING. No lag, lots of top end, lots of bottom end. The question is, can you make it all fit in there.
