ESP, BAS error messages
After a turn, acceleration or braking the MFD starts displaying 2 malfunctions: "ESP off, BAS off. Visit workshop."
After shutting the engine off, and restarting the malfunctions go away. However they come back pretty soon while driving.
Has anyone had similar problems?
The car is in the shop.
Yeah, it's happened to me on my E class. It's just a faulty relay according to MB. Easy fix. You should be back up running by the end of today.
and some codes were stored that were causing the ESP and BAS shut off.This makes no sense to me
mbtech, does it make sense? please help
INDICATOR LAMP ON AND FAULT CODE C1000-008 STORED: Gentlemen,
Please see Dealer Technical Bulletin #187 below. FYI
ROUTE=ALL
TO: ALL SHOP FOREMEN
ALL SERVICE MANAGERS
ALL PARTS MANAGERS
ALL SERVICE ADVISORS
ALL WARRANTY ADMINISTRATORS
CC: MBUSA FIELD PERSONNEL
VPC / PDC MANAGERS
SUBJECT: DEALER TECHNICAL BULLETIN 26/01
***REPLACES MB-NET MESSAGE NO. 028 DATED JANUARY 24, 2001***
26/01-1 RECALLS AND SERVICE CAMPAIGNS: WHEN REPAIRING ANY VEHICLE, ALWAYS
CHECK THE VEHICLE MASTER INQUIRY FOR OPEN CAMPAIGNS
26/01-2 GROUP 42 - MODELS 170, 203 AND 202 WITH M111 ENGINE, ABS INDICATOR LAMP ON AND FAULT CODE C1000-008 STORED: Manufacturing tolerance's in the Teves ESP control module may cause the control module to switch off and store the fault code C1000-008 at high engine compartment temperatures. Once the control module has cooled down and the vehicle has
been restarted, the ESP system is fully operative again.
Repair procedure:
Install optimized ESP control module, identified by the Q status printed onto the control module.
New control modules:
202 545 49 32 - Q08 (202)
170 545 02 32 - Q06 (202)
203 545 17 32 - Q02 (203)
170 545 02 32 - Q06 (170)
Please use these part numbers and these Q values or greater. Please use Damage Code 43181 52, if necessary, and Operation Code 42-8236.
NOTE: The part number which can be seen on the control module refers to the assembly kit consisting of the control module AND the hydraulic unit, and is therefore different from the part number stated above. This is intentional.
Service Engineering
JLdg
4-10-01
MALFUNCTION INDICATOR LAMP ON AND FAULT CODE C1000-016 OR C1000-128 IS STORED:
Gentlemen,Please see Dealer Technical Bulletin #205 below. FYI
ROUTE=ALL
To: ALL SHOP FOREMEN
ALL PARTS MANAGERS
VPC / PDC MANAGERS
SUBJECT: DEALER TECHNICAL BULLETIN 34/01
34/01-1 RECALLS AND SERVICE CAMPAIGNS: WHEN REPAIRING ANY VEHICLE,
ALWAYS CHECK THE VEHICLE MASTER INQUIRY FOR OPEN CAMPAIGNS
34/01-2 GROUP 42.45 - MODEL 170, 203 and 202 WITH M111, ABS/BAS/ESP MALFUNCTION INDICATOR LAMP ON AND FAULT CODE C1000-016 OR C1000-128 IS STORED: If you encounter
complaints of the ABS/BAS/ESP malfunction indicator lamp illuminated and the ABS/BAS/ESP fault message appearing in the multi-function display while the vehicle is being driven or after the engine has been started, and at the same time, the fault code C1000-016 or C1000-128 is stored in the ESP control module, please check the power to the ESP control module. This complaint is generally caused by problems with the power supply. In such
cases, the control module must NOT be replaced.
To check the power supply, please consult the appropriate wiring diagram while observing the following instructions given below.
MODEL 170:
- Check the power supply at PIN 45 (2.5 sq. mm, sw) and PIN 47 (4.0 sq. mm, sw) of the ESP control module.
- Check fuse F31f3 (fuse 3 in the battery fuse box) for secure fit and continuity.
- Check Z4/3 (end sleeve of terminal 30)
MODEL 202:
- Check the power supply at PIN 45 (2.5 sq. mm, rt/rs) and PIN 47 (4.0 sq. mm, rt/ge) of the ESP control module.
- Check the fuses F23/1f8 and F23/1f9 (control modules box) for secure fit and continuity
- Check X12/3 (terminal block for terminal 30)
MODEL 203:
- Check the power supply at PIN 45 (2.5 sq. mm, rt) and PIN 47 (4.0 sq. mm, rt) of the ESP control module.
Service Engineering
JLdg
4-12-01
. Here you go Mike:MB Service Records
I had a similar message which I think read as above if memory serves. The malfunction message (MM) did not reappear the next time I used the car. I think the MM is stored in memory when the engine is turned off after the first occurrence. I never saw the message again after the first time. I had the shop check it when I took the c coupe in for repairs to the fuel pump and gauge. The fix for the BAS/ESP was to replace the ESP relay. I have had no other malfunction messages. Good luck.
Deb
So sinse this problem is related to my fault dead battery, I like MB quality again
DtS, thanks very much. That link is a great resource.
Deb
I must warn you all not to read all of the service records too closely (you might get depressed
Ah ah ah, not so fast! MB also made that awful battery. Mercedes-Benz batteries are some of the worst original equipment batteries out there. If I bought a Benz, first thing I'd do is buy an aftermarket battery such as Die Hard or Interstate.
So, in your opiniion, does it make sense, that the low battery causes ESP/BAS shut off?
Thanks mbtech, that sux, but good to know. I'll keep monitoring the charge.
What goes wrong with the batteries? Isn't it true that the battery needs to be maintained even though the manual makes no mention of this?
Hey, DTS, do you think they update that Tech Bulletin website regularly? Or, have you periodically visited and seen that they've added bulletins from time to time? The last entry is Nov, 2001.
