DIY - setting up the AUX input for iPod, mp3 player, etc.
#226
'05 C230K SS
Originally Posted by CarlosMC
Hi, only one anotation, i know that this forum is readed by a lot of people in europe, so, for them, the code of the cable is 210 440 50 05
Thanks to steve for the info.
Tomorrow i will get it and mount![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![](http://img153.imageshack.us/img153/9416/dscn13454wd.jpg)
#228
2010 C300
Originally Posted by k_lundquist
You guys should check out PocketDock for the lineout, I just got one - its great.
#229
07 G35 Sport 6MT, 2005 C230K SS (sold), 1998 Jeep GC 4x4 (da-heep!)
Its a lineout for the Ipod. It does not allow you to control the ipod through the MB stereo system.
It does allow you to use the lineout connection rather then the headphone connection to the AUX input of the car. (AFTER you installed the AUX Cable)
I like it cause its small and compact. I didn't care too much for the car charger / regular dock / stand solutions I had seen around. Too many unsitely wires.
Anyway its $24.99 - only available online. I got it at amazon.com
#230
Silver 2002 C32, Silver 2006 CLK 350
http://catalog.belkin.com/IWCatProdu...duct_Id=193794
__________________
#231
You mind posting a pic?
I looked at that same product and felt it was too many wires. Do you have them hidden?
#232
yes I have Pics and it is on:
https://mbworld.org/forums/c32-amg-c55-amg-w203/123027-ipod-nano-install-2003-c32-comand.html
you have to scroll down to see it. the charger is hidden inside where the shifter is, there is a lot of room to put it in there.
One guy here in this forum took this pic I think its Johncl, johncl I hope you dont mind if i use it. let me know if you want me to take it off.
this is what he did when he did hix XM install.
now I only have one wire going to my Ipod, very clean and still have my cigarette lighter fo other use.
#233
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Originally Posted by Trekman
on my c32 I have the aux input installed. I had the problem where I have to crank up the volume just to be able to hear the music. well found the solution when I bought an Ipod video. I used this cigarette lighter adapter that is made by belkin, it has a built in Amp on it so you can just set it to the highest setting. and you dont have to touch the volume on your Ipod. I had this thing wired derect so I dont have a plug on my cigarette lighter connected all the time. the Ipod sits by my cup holder where I can change the songs anytime I want.
__________________
__________________
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
#234
ahh yes I did have that problem at frist but I had to use a clean ground to get rid of this wining sound. or you can use a filter form Crutchfield is 127SNI135
this should take care of that wining sound
#236
Super Moderator
excuse my ignorance, but what does a "clean ground" mean? it looks like I may just be getting the filter...
#237
Super Moderator
https://mbworld.org/forums/showthread.php?t=123027
I just realized that I had a $20 gift cert to crutchfield, so I went ahead and ordered the filter. Thanks for letting me know! The buzz was annoying the hell out of me!
#238
you can go to radio shack and get one for $10. tap it on your cigarette lighter, use tie wires so its all secured. I would use that filter so you wont need to ground the negative on the frame of your car. good luck
#239
07 C230 SS Black/Black
I just installed the Aux cable last night for my sister 2006 C230.
It only took me 15 minutes. The 4 pin white connector is inside the plastic wire tray.
You have to open and look for the loose white connector.
I also try to play a CD-R with music MP3 files but the in dash CD player played it but no sound. What did I do wrong ? Help is appreciated.
#240
Super Moderator
#241
According to the window sticker of 2006 C230:
The standard audio for 06 is AM/FM Stereo/weather band. In dash single-CD player with MP3 capability. Any 06 owner try it yet ?
#242
Dia Blk '06 C230
#243
I also read else where in the Forum that the 06 CD Changer is backward compatiable with 05 Cars.
#244
2002 MB C230 Kompressor
is this MP3 player setup possible in an 02 C230K with no changer? i really, REALLY hate radio commercials, and its driving me insane.
#245
Not sure. What I do know is that the 06 MP3 6-CD Changer is fiber optic, so if you're 02 isn't wire for fiber then I can tell you it definately won't work.
If 02s are then there is a possibilty. Since the MP3 decoding actually happens at the CD-Changer level and not at the Head Unit level I would assume that the 06 would work in all C-Class cars that are fiber compatible.
Then again this is an assumption, and I would ask a more knowledgable member to weigh in on this.
If you HATE radio commercials why not consider sattelite?
#246
2)i hate not being in control.......i only listen to a few CD's- namely marilyn mansons new CD, White zombie, Ludacris, beethoven, classical, disturbed, and electronica....surprisingly enough only 6 cd's worth of music that i've been listening to for years, and never get tired of em. thats why i was figuring thhe MP3 player would be nice.
but then again satelite radio has all good music on almost all the time. hmm.
#247
2006 c230
#248
Originally Posted by Ccoupe2006
The plastic wire tray in the right door sill right? I am still trying to get the stupid A-Pillar thing off so I can look inside. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Orange sticks are Orange wood, and come from manicure supply shops.
#249
2005 W203 SS
Help
i opened up the A pillar on my 05 c230. i found the wire that runs up that is supposed to connect to the harness from the dealer, but it is alreayd connected to another harness. whats up with that? am i supposed to disconnect it? or is there another wire?
#250
