Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
The lights also have the standard levelers as well. Also if you disconnect the sensors on the sway they just do not auto level but still work perfectly fine. If you are going to install them have the dealer set the Xenon=Present before you install them. You stock headlights will still work!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...ayphotohosting
7) You probably need an alignment. Mine was pulling to the right a little and got aligned yesterday, now it's fine. Make sure they don't try to charge you, it's free before 12k miles.
Is the first alignment free even if I've changed to different tires? I have an '05 SS that is now running on Bridgestone S03s. My car is pulling to the right - should the dealer still do the alignment for free (car has 2700 miles)?
Various versions of Star Diagnosis will have different paths to get to certain menus; if the version of software in use requires a different path, then it will require a little bit of thinking on the part of the technician who is using the Star Diagnosis.
-s-
-s-
For all of you in Colorado with questions about xenons, talk to Juan, he's the Xenon-Master. I just walked in, happened to be greeted by him, talked about my intention and he installed the headlights right away.
It took about 2.5 hours to finish the job (with me helping him a little), and everything was peachy.
Thanks again Steve and Wanda for the flawless headlights !
FYI, you don't have to remove the bumper to swap the headlights.
cheers.
Knowing how easy the tabs can brake off (as they are designed to break off easily), I would not advise anybody to swap headlights without taking the front bumper off.
Anyways - good to see that it all worked out for you - and regardless how long the install took - that price cannot be beaten!
greetingz,
is this an adjustment that i can do simply, or do i have to take i t to dealer??? thanks so much
A Very Simple way to adjust the Headlights is to find a LEVEL surface about 4 feet from a wall and Measure the center to center on the headlights..also measure the Height..from the ground to the center of the headlight..transfer the info to the wall and adjust the headlights..we used that for setting headlights at the dealer..works greats!
If you want more detailed instructions search the forum, has been posted, or google for them.
1. Besides being whiter, are these light actually brighter than the traditional bulbs?
2. Do the bulbs last longer than regular yellow bulbs?
3. How much does it cost to replace a bulb if it blows?
Still deciding whether i should order it. If there is anything else i should consider, please let me know.
Thanks in advance.
p.s On a side note, should i order teleaid?
I'd take that further.
I wouldn't buy another car period if it didn't have Xenons. All our cars have them now and it's a world of a difference from going from a regular car, to Xenons.
I'd brush off on Teleaid, we don't have it nor BMW Assist in our cars. I just think it's a waste of money. But that's my opinion, I'm sure others would swear by it. You should get one year free BUT MAKE SURE YOU CANCEL WHEN YOU DONT WANT IT otherwise they'll start charging you after that one year.
It's not just going from Halogen to Xenon, but to BI-XENON!!!! So worth it. I wouldn't take a car without Xenon lights, bare minimum.
