Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Subscribe
Dec 7, 2006 | 02:59 AM
  #1501
well if the car is under warranty just go back to the dealer. my bi-xenons go down and then up when adjusting/dancing.
Reply 0
Dec 18, 2006 | 02:49 PM
  #1502
bi xenon headlamps
hi guys....me currently having a C200 with a normal lights..isit possible to upgrade the lights to bi xenon headlamps..thanks for ur replies
Reply 0
Dec 18, 2006 | 03:21 PM
  #1503
Short answer: Yes.
You should check in the Classifieds section, I saw someone selling some recently. Also, check eBay, there are a couple there. Also, search the forum, I believe in the C32/C55 forum there is a thread on the installation process.
Good luck.
Tee_Tz.
Reply 0
Dec 18, 2006 | 03:30 PM
  #1504
if you want OEM BiX then get in touch with Steve at mbenznl.com ($1,500) if you want to go the cheap route then buy some depo lights off ebay ($250-known to melt) and a HID conversion kit ($250).
Reply 0
Dec 18, 2006 | 05:43 PM
  #1505
Quote: if you want OEM BiX then get in touch with Steve at mbenznl.com ($1,500) if you want to go the cheap route then buy some depo lights off ebay ($250-known to melt) and a HID conversion kit ($250).
steves are like $1250, but he only has a few left
Reply 0
Dec 18, 2006 | 06:05 PM
  #1506
do you have coupe or sedan
if sedan, yes
if it's coupe, then nope
Reply 0
Dec 18, 2006 | 07:14 PM
  #1507
talk to Steve, the after market stuff is lame (IMO).
Reply 0
Dec 18, 2006 | 07:33 PM
  #1508
Quote: do you have coupe or sedan
if sedan, yes
it is possible on the coupes
Reply 0
Explore
Dec 18, 2006 | 09:38 PM
  #1509
Quote: it is possible on the coupes
really
cause i thought there were few people that wants bixenon, but steve doesn't carry it, and said they don't make oem bixenon for coupes
i might be wrong loh
Reply 0
Dec 21, 2006 | 06:55 PM
  #1510
Quick Bi-Xenon Question....
I recently purchased an 07 with the lighting package. Supposedly the lighting package includes bi-xenon headlights.
My question is....what is the difference between xenons and bi-xenons?
I used to think that the difference was that bi-xenon's had xenon low and hi beams, but that doesn't seem to be the case......the high beams on the car are halogen. Did I get lied to or does bi-xenon mean something else?
Reply 0
Dec 21, 2006 | 07:43 PM
  #1511
Bi-xenon = hid/low HID + halogen high
Xenon=low HID + halogen high
There are 2 settings on the high beam lever. I don't remember exactly but if you pull the lever towards you, only the halogen highbeams turn on. But if you push it away from you (with the headlights ON), both the xenon HIGH and halogen HIGH will be ON.
Reply 0
Dec 21, 2006 | 07:47 PM
  #1512
Yes, in the BIX unit, there is a little motor that flip up the cut off shield to allow more light.
Reply 0
Dec 21, 2006 | 08:05 PM
  #1513
xenons are not made anymore. you can either get halogens or bi-xenons
Reply 0
Dec 21, 2006 | 09:27 PM
  #1514
learned something new today
i thought bixenon is hid/low HID, didn't know there is also halogen high
Reply 0
Dec 21, 2006 | 10:43 PM
  #1515
Oh darn; those who STFF the forum would have known that by now.
Reply 0
Dec 21, 2006 | 11:40 PM
  #1516
hahaha STFF.
Bi-xenons are like Bi-sexuals, goes both ways.
Reply 0
Dec 22, 2006 | 12:18 AM
  #1517
note: if you had HID single/low beam only it would resemble the HALOGEN LOW.
and the BIX HIGH
Reply 0
Dec 22, 2006 | 07:50 AM
  #1518
also the xenon lights were a reflector type lens whereas bi-xenons use projectors. When the lighting stalk is either pushed away from the driver or pulled towards the driver (pushed away sticks, pulled dosen't), the halogen high beams (normally the city lights) turn on, as well as the guards on the HID's move to emit more light from the low beam projectors.
Reply 0
Dec 22, 2006 | 12:34 PM
  #1519
Thank you all for the clarification......you are all much more helpful than the sales rep I worked with:
Me: Does bi-xenon mean low/high beams are both xenon?
Him: Noooo!!! That would blind people!
Me: So do normal high beams, that's why you don't drive with them on
Him: Yes, but xenons would be too bright....it's only the low beam.
Reply 0
Dec 22, 2006 | 05:13 PM
  #1520
Quote: also the xenon lights were a reflector type lens whereas bi-xenons use projectors. When the lighting stalk is either pushed away from the driver or pulled towards the driver (pushed away sticks, pulled dosen't), the halogen high beams (normally the city lights) turn on, as well as the guards on the HID's move to emit more light from the low beam projectors.
I think you might be wrong on that, because I see alot of regular xenons use projectors as well (i.e japanese cars and older bmws).
Reply 0
Dec 24, 2006 | 12:13 AM
  #1521
Quote: I think you might be wrong on that, because I see alot of regular xenons use projectors as well (i.e japanese cars and older bmws).
I think he was referring to the C Classes.
Reply 0
Jan 23, 2007 | 10:18 AM
  #1522
Xenon Ballist Gone Bad
hey again everyone, does anyone out there know how to contact the infamous Steve on this site, I know my buddy purchased his xenons off him a while back. My reason for finding him is i'm wondering if i could just purchase a ballist for my driver side headlight.. Or can anyone point me in the right direction to were i can find one at a good price. I'm having a problem when i turn my lights on sometimes my driver side light won't come on, i mess around with the switch turning on and off my lights and after a few try's BAM they both come on. i'm almost certain this is due to my ballist gone bad.
Reply 0
Jan 23, 2007 | 10:45 AM
  #1523
s_krabbenborg@hotmail.com
Reply 0
Jan 23, 2007 | 11:27 AM
  #1524
switch driver side ballast with pax side ballast. if the ailment switches sides,
then you can reasonably conclude it's the ballast. right now, it could be....
or not (bulb, wiring, connection, switch).
Reply 0
Jan 23, 2007 | 05:02 PM
  #1525
I may have a ballast for sale . It comes from an OEM passenger side bi-xenon. PM me if you need one!
Reply 0
