Roof Rack Thread for W203/S203/CL203 & bike/ski mounts
PM if you're thinking about one...
but anyways.. the answer to your question is yes
The sunroof will not open with some of the other kits at all, you need 2-3 inches over it other wise you will hit it---spend the money up front, it will pay off in the long run
I have attached Canoe racks, Bike Racks, Carriers, and Paddle holders with ease and very cheaply with "MINIMAL" modification---(and yes a 16 foot canoe will fit on a sportcoupe!)
Kit(s) you will need to buy:
1. One (1) TK1 - Parts bag from the Tracker Kit
$13.00 each http://www.thuleracks.com/product_sp..._id=82&sku=TK1
2. Eight (8) 924-0617-15 Bolts $.50 each http://www.thuleracks.com/images/lineart/TK1_422W.jpg
3. One ORIS rack for your vehicle $Price Varies http://www.oris-gmbh.de/pics/bild_grundtraeger.gif
4. Thule or Yakima Attachments $Price Varies
Pictures will follow shortly
The example will be the most poular i'm sure a Thule BIKE RACK
1. Take your Attachment and allign holes already drilled in the attachment with the front of the first roof rack
2. Mark the center of the attachment where it meets the rear rack (center of the channel below)
3. Drill a 6mm hole in the attachment if no hole is present (which usually is not)
4. Put the flat nut labeled (A) in the diagram in the oris track
5. Screw in the allen bolt (F) till it tightens the flat nut
6. The bolt (F) will be too long--you have 2 options
a. Put spacers (E&D)on the top side to fill out the bolt
b. Better way is to cut off/dremmel off the bolt length excess to fit correctly
7. tighten the allen bolts and the nuts will clamp down on the underside of the track inside and will not slip
For about $22 worth of Thule spare parts shipped, you can add any attachment to your roof Rack.........
I have done this to my Upright Uptight Thule bikeracks and a couple other attachments so I don't have to go to the stealership for theirs
I made the rack attachments from flat metal from an old desk, bent it into an L shape, drilled holes in the correct spots, put the bolts in that are mentioned from the previous post, put rubber grips w/adhesive from Lowes (supposed to be applied to the bottom of vcrs and such) and of course I have to strap it down, but there is no front/back, or side to side movement whatsoever.
The rear pair has only has one bolt in the picture but now has 2 bolts in each on all four corners. (was testing it to see what was more stable)
It is solid!
Hopfully this post will help others that lack an suv and that it also becomes a sticky to be added to the DIY section--- I found one other Mercedes forum veteran from the other site (had an older w124 that had an oris rack) but it never showed exactly how his attachment was added, only that he used wind surfing Chinook bolts. This post will eliminate buying various hardware to "see if it fits" I have already searched for a long time and had all the trial and errors before arriving at this setup.
Nick, if you find a Oris coupe roof rack for $100 then i'd buy it on the spot--far more advanced then the thule and yakima racks (i don't trust their fitment)
Unfortunately the ML and the G-Wagen are not going on the trip.
off to eBay I go...........
Carlos
Saprissa@aol.com
(note: this pic was taken last year while on vacation in the Tetons so it is my car but different rims)
