Frank's C32 Obsidian Obsession
Subscribe
View Poll Results: FrankW's Obsidian Obsession
FTW
69
100.00%
FTL
0
0%
Voters: 69. You may not vote on this poll
Jul 11, 2009 | 11:48 PM
  #1376
My guess....
Quote: ...the noise is definitely coming from the driver side valves. giving it some gas and the noise speed up and gets less noisy and after about a min the noise completely went away. while there was the loud tapping the idle is rough and after the noise stopped the idle was better...
Sticky valve that frees up with temperature.....the "loud tapping" is the valve lifter smacking the valve when it fails to close on time.
Reply 0
Jul 12, 2009 | 12:05 AM
  #1377
Quote: this car just hates me more and more.
was adjusting the driver side camber and decide to move her out of the way of the pepper tree with leaves falling all over the place.
started her up and hear the loudest tapping noise I've heard ever from her. pop the hood put my ear down on all possible things (passenger bank valves, TB, driver side bank valves, purge valve) and yup...the noise is definitely coming from the driver side valves. giving it some gas and the noise speed up and gets less noisy and after about a min the noise completely went away. while there was the loud tapping the idle is rough and after the noise stopped the idle was better.
soooo on top of everything that are possible causes for the recent events this leads me to think maybe because the car wasn't firing properly for a while due to ignition wires dying and because the car is tuned to run slightly rich the misfire caused built up in the valves etc.
so far I've eliminated the wires, plugs, and possibly the coils (running two coil packs from the CLK to replace the one that was questionable. the CLK runs fine and the 32 still doing what it's doing).
next on the list are MAP, EGR, and dirty valve.
Crap franky, i hope u get ur car running.... dammm 32's scary v6 kompressor i have 78k miles now, reading ur problems scares me ****less
Reply 0
Jul 12, 2009 | 07:07 AM
  #1378
Frank - You must stop driving the car until this is diagnosed. You are going to damage something - valve hit piston etc. It could just be a dirty valve but you need to know. You might still have a broken valve spring - valve assemblies rotate constantly & that might be why the noise comes & goes. Depends on the orientation of the springs. Please compression test & I advise getting that head off for full inspection. I'm not saying it's not build up on the valve tulip - American fuel is not great & we don't know the condition of the valve guides & stem seals - but if you are using Techron - running slightly rich should not cause problems. It should help clean the inlet tract. Build up on the tulip is usually a combination of fuel crap & burnt on VI improver from the oil leaking down the guide. If you continue to run with excessive clearance on one valve you will wear a flat on that cam lobe. You might have a damaged valve collet - Good luck!
Reply 0
Jul 12, 2009 | 01:51 PM
  #1379
Quote: Frank - You must stop driving the car until this is diagnosed. You are going to damage something - valve hit piston etc. It could just be a dirty valve but you need to know. You might still have a broken valve spring - valve assemblies rotate constantly & that might be why the noise comes & goes. Depends on the orientation of the springs. Please compression test & I advise getting that head off for full inspection. I'm not saying it's not build up on the valve tulip - American fuel is not great & we don't know the condition of the valve guides & stem seals - but if you are using Techron - running slightly rich should not cause problems. It should help clean the inlet tract. Build up on the tulip is usually a combination of fuel crap & burnt on VI improver from the oil leaking down the guide. If you continue to run with excessive clearance on one valve you will wear a flat on that cam lobe. You might have a damaged valve collet - Good luck!
problems problems sigh... maybe is time for us to sell the 32 take a lost ...
Reply 0
Jul 12, 2009 | 04:39 PM
  #1380
damn frank, the car is takin a big hit on you.. goodluck wit everything
Reply 0
Jul 12, 2009 | 06:15 PM
  #1381
Quote: problems problems sigh... maybe is time for us to sell the 32 take a lost ...
it's not gonna depreciate more than it is right now.
it's turning into something i only drive once or twice a wk car anyway.
Reply 0
Jul 12, 2009 | 06:26 PM
  #1382
Don't even think of selling it - If it's just head work - fix it - not a major train smash - It's when you loose a block on these engines that you have to wonder whether repair is worthwhile - then better to find a secondhand engine.
Reply 0
Jul 12, 2009 | 06:39 PM
  #1383
Quote: Don't even think of selling it - If it's just head work - fix it - not a major train smash - It's when you loose a block on these engines that you have to wonder whether repair is worthwhile - then better to find a secondhand engine.
just one of them hiccups. all good.
Reply 0
Explore
Jul 12, 2009 | 11:37 PM
  #1384
Quote: just one of them hiccups. all good.
God dammm money pit, think of the things you can do in Taiwan and the fun you can have with the money repairing the c32.
Reply 0
Jul 13, 2009 | 12:04 AM
  #1385
Quote: God dammm money pit, think of the things you can do in Taiwan and the fun you can have with the money repairing the c32.
airline tickets too expensive man...lol
it only made me change the wires that I wanted to change for a while anyway.
and when asked when did I change out the plugs was a very good question because I thought I only did it 20k miles ago, but searching around I think it was more around 35-40k miles ago.
so so far i've only spent on necessary maintenance items.
Reply 0
Jul 13, 2009 | 12:49 AM
  #1386
+1
Reply 0
Jul 13, 2009 | 04:50 PM
  #1387
My lil sis went back round trip ticket 800. hahahaah i wanted to go back sooo bad, but, tons of work to do. Let us know the results of engine problems.
Reply 0
Jul 13, 2009 | 08:34 PM
  #1388
ran STAR. misfire on #4. all electrics checked out. the readout shows something 5.6-6.7 in the "smooth engine running" menu in the STAR.
suspect it's the valve sticking or not closing (valve spring probably died). erratic vacuum read. did not have time to do compression test.
Reply 0
Jul 13, 2009 | 08:39 PM
  #1389
Erratic vacuum reading is almost certainly a valve.
Reply 0
Jul 13, 2009 | 08:42 PM
  #1390
Quote: Erratic vacuum reading is almost certainly a valve.
hopefully it's the valve spring and not the valve stem itself.
Reply 0
Jul 13, 2009 | 09:45 PM
  #1391
Damn. You already know about the compression/leak down tests.
A borescope can also reveal if the valve(s) and piston have made contact.
I sure hope not…
Reply 0
Jul 13, 2009 | 10:05 PM
  #1392
Quote: Damn. You already know about the compression/leak down tests.
I sure hope not…
i wouldn't think so based on what bullejo said what his symptom was.
Reply 0
Jul 15, 2009 | 06:28 PM
  #1393
does anyone have repair manual for M112 replacing the valve springs?
Reply 0
Jul 15, 2009 | 09:39 PM
  #1394
Frank - I don't think you've had a hard touch if at all. If you had bent valves you would know - big noise!!! & terrible running. Damn I bent a lot of Alfa valves in the old wild days.
I don't have a manual or procedure - sorry - This is all I have for the C32. Let me know if you need pics of front chain case & all.
Good Luck
Frank's C32 Obsidian Obsession-c32-valves.gif   Frank's C32 Obsidian Obsession-c32-cams.gif   Frank's C32 Obsidian Obsession-c32-head.gif   Frank's C32 Obsidian Obsession-c32-rocker-cover.gif
Reply 0
Jul 15, 2009 | 11:19 PM
  #1395
Quote: does anyone have repair manual for M112 replacing the valve springs?
Does this mean you verified a broken valve spring? I've heard of similar valve spring replacements being done without removing the head. They used air pressure to keep the valve in place while compressing the spring and installing the collets (or is that how everyone does it now?). How about subscribing to All Data for the tech info? However you do it the information will be better at hand.
Reply 0
Jul 15, 2009 | 11:41 PM
  #1396
Replaced valve springs on Detroit iron in situ without too much effort.
MB’s procedure…
Reply 0
Jul 16, 2009 | 03:53 AM
  #1397
Quote: Replaced valve springs on Detroit iron in situ without too much effort.
MB’s procedure…
thanks john. that looks like PAIN to DIY.
I'll ask around to see how much repair will be. already got one quote.
thanks glyn for the graph as well.
on my older bro's 97 528 we had a broken valve spring too and we were able to DIY it without much trouble, but everything on this M112 seems over engineered to a point you are asking ...WHY? lol
BMW made the same power with a 3.0L inline 6 on single spark 4 valve design and it is more fuel efficient as well. why the heck did MB's engineer decide to go twin-spark and 3 valve. lol in truth not very efficient and cost grip to repair and replace parts.
glad on the M272 they made it simpler.
Reply 0
Jul 16, 2009 | 10:51 AM
  #1398
[QUOTE=splinter;3624347]Replaced valve springs on Detroit iron in situ without too much effort.QUOTE]
Yep - Achieved the same with Italian ALUMINUM when I had bent nothing. Bloody Alfa had dual valve springs to add to the angst.
Reply 0
Jul 16, 2009 | 11:13 AM
  #1399
Quote: but everything on this M112 seems over engineered to a point you are asking ...WHY? lol
So FrankW could "drive it like he stole it"
At the time the 112 was developed they were determined it enjoy LEV (low emission vehicle) status in Europe. Hence the twinspark. Kraut engineering for the sake of engineering if you ask me sometimes.
Their auto trannys are a masterpiece in simplicity - especially the 7G for what it achieves I think cost is driving simplicity in the new DB regime & that is good.
Reply 0
Jul 16, 2009 | 02:16 PM
  #1400
The bolded part of your quote I think pretty much sums up why they did it. I'm sure the thought was that "if" anything like that were to go bad, they make money on people wanting to repair the m112 engine, rather than having to buy a new car or get a whole new engine. Logically speaking, I could only think that they would do it to make more money on people trying to fix the car, rather than make it more efficient / cheaper for the consumer.
Reply 0
