Dash Cluster LCD Dead after replacement
What could i have done and now what? Do i buy a used cluster on Ebay? Does a Dealership program it?
Im going to order a used cluster and have them clone the info from my old cluster
I can see if the company is still around, if interested?..
Yes please.Been putting off this repair because most of the products out there (the ones I heard of at least) were of poor quality. How does the one you have look compared to the original? Any fading issues during the summer?
The new one is easily readable, on the hottest of days, with no fading evident..
) Thanks in advance.
Not a big deal, but I remember some people mentioning that they couldn't see their displays with sunglasses on.
Not a big issue for me, but maybe for others..
The seller i bought off no longer lists them, but this one is still selling, and seems to have good feedback..
https://crngiarautoparts.aliexpress....
If Atlanta Speedometer is able to correct the problem (maybe soldier that connection) it would be great. I've been beating myself up over this as it is my sons (19) ride and he's off to college in several days, 2 hrs drive and that LCD has all the info about temp, oil etc'
Thanks for reading and responding to my post
Also I notice that a column of LCDs is out on your display. This is actually very easy to repair with some basic soldering equipment. There is a break in the trace somewhere. In fact, mine had a break at the exact spot shown at 3:30 and I imagine that's where it is for you as well.
The video uses the fancy screen but I was able to find the break by popping the circuit board film out and gently bending the suspected areas. The breaks can be seen with the naked eye, and most of the failures seem to happen at the same part of each track (where the trace goes from thin to thick, towards the bottom of the display).
TBH, i prefer not to touch it!
The LCD shadow doesn't really bother me, and it was such a pain to get the whole cluster to install correctly, i had to remove the rear cable connection and re-install it a few times to get the whole thing to work properly; not sure why it would not seat correctly, and cause spurious errors on the screen!?..
Also, the pic i took was at near lowest brightness, as i didn't want the pic to flare up..
added some pics..
MIN display
MAX display brightness
sent my cluster out to Atlanta Speedometer in Georgia, they called the day after receiving it and said several areas of the board were scratched and shorted out, just where the locking tabs are for the ribbon. They will locate and purchase a used unit and clone my info over.
