2002 C240 transmission issue?
I own a 2002 C240 with 116k miles that I hoped to keep for some time. But, now, I'm not sure I want to.
Over the last few weeks, the car, randomly, would not go into park. First time was at a gas station. It freaked me out, I won't lie. But when I took my foot off the brake, it slid right in. It has done that several times. I've never had an issue putting it into gear, only putting it into park. Last week, I left the grocery store and the car seemed to stay in a lower gear. I got it home, albeit slow, and determined it was in "limp mode".
A quick internet search revealed I should look at TCM fuses, transmission fluid level, conductor plate or issues with not enough electricity reaching the transmission.
Yesterday, I took it to the local AAMCO to see if they could diagnose the issue.
Their tests came back with a number of codes that I have looked up but really don't seem to scream transmission problems, per SE.
They initially said I needed a bushing in the shifter which was cheap and I okayed. Then they said I needed a whole new "shifter". As of 5pm today, they were still pricing.
My gut tells me this won't fix the problem so I'm hoping for pearls of wisdom from this group.
Thanks, in advance, for any advice!
The electronics in the shifter are known to go bad. Not common, but it can happen. My understanding is that it's not the components that go bad, but cold joints (ie cracks) in the solder.
Depending on how dirty you want to get your hands, this can be DIYed with some hand tools and some soldering equipment. The cold joints can be identified by hand and resoldered, or if you want, you can either a) bake the entire PCB in a toaster oven to reflow all the joints, or b) replace the PCB with one from a wrecker.
https://www.youtube.com/watch?v=f-0l7-I2z6Y
As an update, although AAMCO said it probably needed a new shifter, they reported it also gave a bunch of other codes and I wasn't convinced the shifter would fix so I decided to have the car towed to a shop that specializes in electronic stuff. Well, as of this morning, they reported a ton of other codes and advised maybe the car wasn't worth being fixed. And I am beside myself!
The car doesn't smoke, does not leak any fluids on my driveway or make any weird noises but they are telling me it's toast. I don't get it.
I wish I was a DIYer, but I'm not. I'm a 65 year old, widowed Social Worker that hoped to keep this car for some time.
Maybe I'm being naive, but my gut tells me my car can't be as bad off as they are saying.
That's why I joined this group. I don't know much about cars but I'm good at researching and finding solutions to problems.
I'm in the DC area so if you have any advice or know someone in my area that might be able to assist, please let me know. Thanks.
A car is technically "totalled" when the cost of an upcoming repair exceeds a certain % of the market of the value of the car. Personally I don't agree with this definition at all, but most people in general also cannot be bothered to take the time to figure out what's wrong with the problem. A problem can often be DIYed for a fraction of the cost for those who are able and inclined to do the repair (therefore saving a car from being totalled), but definitely isn't for everyone. I understand that DIY isn't an option for you, so at this point your best bet is to start replacing parts. FYI this is why dealerships often just throw parts at cars. It costs too much to pay a technician to diagnose.
In your case, the car clearly drives fine, so there is nothing wrong with the transmission (a lot of transmission "error" codes don't affect driveability and can safely be ignored). It's the last part where the car doesn't want to go into P. Based on this, I would advise replacing the shifter module. If this doesn't fix the problem, I would next look at the sensor that tells the car if the brake pedal is depressed. I think the entire assembly is sold as a single PN. In other words, the electronics are not sold separetly from the housing with the shifter stick.
A car is technically "totalled" when the cost of an upcoming repair exceeds a certain % of the market of the value of the car. Personally I don't agree with this definition at all, but most people in general also cannot be bothered to take the time to figure out what's wrong with the problem. A problem can often be DIYed for a fraction of the cost for those who are able an inclined to do the repair (therefore saving a car from being totalled), but definitely isn't for everyone. I understand that DIY isn't an option for you, so at this point your best bet is to start replacing parts. FYI this is why dealerships often just throw parts at cars. It costs too much to pay a technician to diagnose.
So AAMCO originally said I needed a shift bushing and a brake light switch. Then they said, upon inspection, I needed a new shifter. The part was reasonably priced. Are you saying this might be all I need?
A couple of days after I installed the license plate LED's with the resistors -which seemed to work fine- my shifter got stuck in park(C240 2004).
I don't know if they are related or if it has something to do with the rear SAM or if you would know
if there is a known thing connected to these two issues-the stuck in park and the "number plate bulbs"??
I have watched so many videos and read so many posts.
Also, I have seen it is possible that the triangle piece might be broken in the shifter, or it could be a relay
or it could be something in the transmission- but I thought I would ask you
just because I saw your name in the above posts and you were nice to help me with the LED's. Thanks
There's some barrier mechanism (no idea what it looks like, I assume it's a hinged piece attached to a solenoid) that unlocks the shifter stick when the brake pedal is depressed and the brake light turns on. It might simply be that the brake light switch has gone bad, which would cause your car to think the brake pedal wasn't depressed and therefore keep the shifter stick locked. That's where I would look first. The barrier mechanism isn't known for failing. Let us know what you find.
As of this afternoon, they are advising they cannot find a shifter replacement. Is this possible? I am so, over this.
Where are you located? You might want to add your location in your signature.
I am in northern Virginia, 5 minutes from DC.
If you know someone who can fix my car, please advise.
In the modern era it's hard for someone to be a specialist in all cars. I'm guessing AAMCO is probably a specialist in domestics, which is why you're running into problems. Your best bet is actually a local MB or German specialist, if you want to avoid dealer prices. Dealer will be able to fix it but they will also be the most expensive.
The dealer parts department or a website like MBOEMParts will have what you're looking for. Be sure to do your homework (ie go by your VIN when looking for the part, not just year and model) so you don't order the wrong part. The good news is you're in USA where it's super easy to obtain parts.
Good luck.
AAMCO called me today and advised they received the 3rd shifter they ordered and it "was bad". They are giving me attitude and saying they have to pay re stocking fees for parts they ordered that don't work.
I took your advice and looked at the MB oem website and got nothing, even after submitting my VIN.
I've got a gift basket for anyone that can find the freaking part I need to get my car back.
$200 for a used one on ebay. I also have 2002 and 2002 connections are different than later years.
I know these things from experience.
In the end I managed to get the correct shifter from a Picknpull for $30 after waiting some months for a 2002 to show up anywhere near my then home of San Jose.
I ended up driving to Richmond to get it, and later I managed to aquire a spare so I won't have to go through this again.
If you aren't seeing that it's not the shifter.
What codes did Aamco get?
How many miles on your vehicle?
Here's my old thread with instructions for removing and replacing.
https://mbworld.org/forums/c-class-w...314-p0705.html
I see someone added a video to the thread about baking the circuit board in an oven to fix it.
Interesting idea.
Search P0705 in any of the forums using 5 speed trans and you will find
lots of info.
At the time, dealer told me to use one of these part numbers for 2002.
"The P/N 2032678824 is the latest P/N for your car.
The older P/Ns are 2032672124 , 2032672724 , and 2032674924"
So, I bit the bullet, had the shop order a new shifter and got it done. It was $1000, out the door. Car seems to be shifting fine now.
You mentioned Richmond. Do you, by any chance, live in the DC area? I sure could use a friend/ear/mechanic type to help me navigate keeping this old girl on the road a while longer!
In the future you can read your own codes, and post them here, using something like
this
https://www.ebay.com/itm/29527460807...IAAOSw3J1iAMgg
Free program called "Torque" for Android will read the codes from this, and likely other programs for Apple as well.
You can email yourself a report then cut and paste.
Easy peasy!
Best of luck with your car.
So how many miles on it?
this
Easy peasy!
The only code I'm getting now is for the purge control valve. That doesn't look like a hard fix but who knows. This car has worked my last nerve!
I'm a 65 y/o, retired Social Worker. Not a DIYer, by any stretch but I try to educate myself so I can make sound decisions and not get screwed. I actually had the car towed to an "electrical specialist" shop while waiting for AAMCO to find a part. They told me the car was throwing so many codes it would cost thousands to diagnose and maybe the car wasn't worth fixing.
The car has 116,000 miles.
