Anyone retrofitted active cornering lights?
Administrator
HTH
'05 C230K SS Granite Grey Metallic
It wasn't standard on mine, so I don't know if you have to have a certain package since I don't have the lighting package (bixenon). When I asked the dealship, they said it was not possible, but I'm sure a lot of that has to do with experience. I saw another member that had active fogs set by Steve or Sunil and I don't think he had the lighting package either and it was an '05.
Super Moderator
bone stock E55 AMG
2005 C55, 1988 260E, 2000 Chevrolet Silverado
I upgraded my front SAM and had Sunil add that feature. It worked with the turn signals and when I turned the wheel past a certain degree.
#34
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
this thread makes so much more sense to me now that Steve (MBenzNL) installed an updated SAM in my Coupé and activated the passive fog lighting feature via DAS.
Carlos
Saprissa
Carlos
Saprissa
#37
If it was a true "active" cornering fog light like in some of the high-end new cars, then you would need that new fog light ensemble with the gucci active cornering fog lamp. And as previously mentioned, not doable on the W203.
In my C320 Coupé's case, I have 2005 AMG SL55/E55 clear fog-lights, and I believe that even the 2005 W203 clear fog lights, allow a bit more of lateral light to shine than the older 2001-2004.5 fog lights.
Also, you do not need to have the fog-lights turned "ON" for the feature to function. If you're lights are on, fog-lights off, then when you signal or turn the wheel past a certain degree, the respective side fog light will turn on.
Carlos
Saprissa
#38
Super Moderator
bone stock E55 AMG
05 SS fogs = C32 fogs
but then again, MB has about half dozen different part numbers and maybe there is one that aims further out...
with mine, it doesn't help at all at night... it just looks 'cool' from outside...
the one that really worked was those 1st generation maximas...
