Emergency call from a newbie, all hands on deck please 🚨
Old Mar 24, 2023 | 03:17 AM
W203Boi's Avatar
W203 C200 Kompressor
I know its not the right place to start this thread but please help me. I have been experiencing serious issues with my 2001 w203 c200kompressor.
It all started with one day, it misfired on cylinder 1. Went to te garage and immediately changed the spark plugs and coils. The problem went away for a week, it drove perfect. Then all of a sudden it came back. I suspected it was the spark plug, so changed the 1st one with the 3rd one to see if it would go away. But it stayed. Same cylinder #1.
the car sometimes starts rough but becomes normal when I rev it. But the problem starts on the 3rd gear, when I want to accelerate, it rattles, hesitates and starts shaking when stopped like it works on 3cyl.
thank you so much in advance. 🥲
This is a photo of my dtc codes.
Old Mar 24, 2023 | 04:10 AM
W203Boi's Avatar
Up..
Old Mar 24, 2023 | 06:42 AM
DLB_Adelaide's Avatar
GL320 X164 OM642 722.902
Looks like you have electrical gremlins there. The cylinder misfire might be an effect of the air control actuator malfunctioning. The air-fuel ratio might be upset and not receiving enough air thus causing the misfire. Anyhow, I am no expert in electrical but might want to start your google search with the actuator controller?
Old Mar 24, 2023 | 08:10 AM
W203Boi's Avatar
to be honest with you, conducted a through search but couldnt find that part. Do you know the part code? Thank you so much.
Old Mar 24, 2023 | 07:06 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W203 forum...
Old Mar 24, 2023 | 09:29 PM
I am not sure how you define "thorough search". I spent 1minute and searched "w203 air manifold controller" and plenty of good results came up. One of the things that popped up below. Not sure if that is what you need or if that will be closely related to your problem.
Intake Manifold Runner Control Valve Fits for Mercedes W203 W20 6420910150
Old Mar 25, 2023 | 06:04 AM
W203Boi's Avatar
okay so its my fault, couldnt find that part. Gonna show the picture of it to the local dealer. Thank you so much 🙏🏻
Old Mar 25, 2023 | 04:27 PM
weedonald's Avatar
C300 4matic sport, Suzuki SX4
Have you had the problem evaluated at your MB dealer?
Old Mar 25, 2023 | 04:31 PM
W203Boi's Avatar
yep, I have. But the mechanic kept saying its either the coils or the spark plugs. The problem is, we had replaced them together with him. I have changed the crankshaft position sensor today and it runs smoother, no stalling so far. Fingers crossed. 🍀
Old Mar 25, 2023 | 04:52 PM
chassis's Avatar
2017 GLE350 4MATIC
New plugs from dealer
new coils from dealer
new battery
check and clean all ground points
After all of the above are done, if the problem still exists start diagnosing injectors.
Old Mar 26, 2023 | 03:52 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Leaking intake manifold gasket? Check around in the R170 forums here and elsewhere.
They used M111 engine all the way till 2004, and lots more experience and information.
Most 4 cylinder cars here are newer M271. Only 2002 C230 used M111 in USA for W203.
(Like me)
