Crank but no start when cold
My mechanics checked all the fuel pressure and everything he could get a reading on. Everything is normal. At the time the alternator died, the lights on the dash flashed like crazy and there was misfire. But the alternator shouldn't cause this to happen. After the alternator was replaced, everything was normal except for the starting process. And the car only has hard start when temperature is below 10C or so.
I have the crank position sensor and coolant temperature sensor replaced, thinking the dying alternator might have fried the sensor and caused it to give wrong readings the the ECU. But they didn't help.
Any thoughts of what could be wrong? Without error code, I am shooting in the dark.
Thanks,
Michael
I'm wondering if your fuel pump has an intermittent fault. Did your mechanic check the fuel pressure when the car was having trouble starting? A failed fuel pump doesn't trigger an error code.
The W203 has an electronic throttle. Stepping on the gas may change the throttle body position, but I'm not even sure if that happens when the car is cranking.
The other thing that comes to mind is the voltage regulator, which is attached to the alternator. Not sure about the V6, but for the I4 there are 2 versions of the alternator (Valeo, Bosch) and my understanding is they are not interchangeable. Did you get an OEM alternator and VR?
I assume your plugs and ignition coils are working properly. Failed coils will trigger a CEL. I assume failed plugs will too.
My mechanic said he checked every reading he can possibly got. And fuel pressure is within the spec. He said there's nothing leading him to think the fuel pump is the culprit. He wouldn't mind changing the fuel pump for me, but even he couldn't justify
Regarding the alternator, if Valeo and Bosch alternators aren't interchangeable, I think a lot of things in the car will behave erroneously. And he always uses the VIN of the car to make sure he gets the right part for it. Although I can't be 100% certain, I am pretty sure he got the right alternator.
Spark plugs are relatively new. Ignition coils are still the original from the factory.
One thing I didn't mention. Over the past winter, while I needed to floor the gas while cranking to get the car started, in colder weather, the car might need a few crank before I could be started. After that, white smoke got out of the exhaust with gasoline smell. And I got P0151 error code. The code would go away after a few days.
I've replaced the following:
1. MAF
2. Fuel Filter
3. EGR Valve
4. Fuel Injectors
5. Cleaned throttle body with Seafoam
6. Coolant Temp Sensor
7. Crank Position Sensor
Here is other thread where I've discussed that went nowhere: https://mbworld.org/forums/c-class-w...ml#post8669813
- Fuel filter
- Spark plugs
- Spark plug wires
- O2 sensors
- Throttle body cleaned
- MAF
- Coolant temperature sensor
- Crank position sensor
I was suspecting aging fuel injector o-rings. But after reading your other thread, I start to doubt it has to do with it. Since it's more like guessing, I changed the coolant temperature sensor and crank position sensor because they are relatively cheap to do. Changing fuel injectors are more expensive.
If you have to remove the fuel pump fuse to get the car started, would it be suggesting a faulty fuel pump? Perhaps it is pumping too much fuel at the very first "pump" of the day.
- Fuel filter
- Spark plugs
- Spark plug wires
- O2 sensors
- MAF
Sure enough. After leaving the ECU with him for a few days, found it and reflowed the joint. He sold it right after that. I would of kept it after that kind of win.
