Fuel Injector O-Ring Lubrication
When I had to remove the injectors as part of the crankcase breather hoses and check valve replacement I didn't even know any lubrication was required. I just hammered them back into the engine.
If you think about it, the lube is really just for ease of installation/removal. The stock holes are already super tight. I imagine any grease that doesn't eat o-rings will also work. Unfortunately I can't tell you what those would be. I should also mention that the o-rings were completely dry when I pulled them out, so whatever they used was long gone.You may also want to look at the job above if you haven't done so already.
And be sure to use a genuine MB or Bosch injector. I know someone who replaced their injectors with cheap Amazon junk and it resulted in poor drivability.
I use a silicon grease and never had problems so far. You can clean injectors usually very good. Put them in a vice (I bored a hole in a wood piece) connected to 12V and a switch, a syringe full of carb cleaner and pressed it through.
https://a.co/d/6fNe9uv
When I replaced the hoses and check valve, I do remember finding that a brass nipple with a pinhole had completely plugged up. Might want to look into this too. The good news is this nipple is relatively easy to access, and only requires removal of the air box.
Will definitely clean the pinhole and probably replace the check-valve too while I am in there.
