Removing speaker grille's & speaker sizes re: '02 C240
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Does anyone know how to remove the speaker grille's on the C240? Does anyone know what the speaker sizes are?
thanks
Jim
thanks
Jim
GL450, Sienna SE
They are the same size all around. For the fronts you need to remove the whole assembly or just unclip it from the bottom and just access it with your hand. They are 6.5 by the way.
1 Post
thanks!
JIm
Craig from London, Ontario, Canada - please search for "remove front door" - it's been well documented here with pics. It's fairly simple: remove interior door pull, remove torx that is there; remove SRS badge, remove torx that is there, remove third torx from rear portion of door pull, then remove door panel without breaking the clips, and it's done.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Buy spare clips.
Does your 240 have the subwoofer in the back parcel shelf?
https://mbworld.org/forums/c-class-w...rear-deck.html
1 Post
Aston Martin V8 Vantage
we took off the entire door panel when we replaced the component system in my sister's 02' c240. it was farely simple. just 4 bolts i believe and then door panel goes up and out.
Nowhere ...Fast
can the stock speakers be simple replaced by any other brand speaker? mine are starting to fuzz...i dont need anything fancy and was thinking Xploids...any comments? suggestions? Thanks
P.S. sorry for jumping into this thread
W203 06
yeah bro just replace em how you would on any other car. if your using a 6.5 u might have to make a mounting for it. its pretty simple.
W203 06
i recommend getting infiniti kappa 6.1 components. man they are heaaapps clear and go pretty loud. im getting 146 db from my subs in my car and u can still hear them fine and they dont distort at high volume.
yallah hold on ill try find that thread
oh yea and u dont have to remove the speaker grill cuz it all fits fine
W203 06
https://mbworld.org/forums/c-class-w...30k-coupe.html
this is what guided me while i was doing it. its quick and easy bro
W203 06
if ur gonna go with polk audio just go to ur local fruit market and mount some oranges in ur door. will sounds the same.
Super Moderator
That's nasty - The Polks are fine. But if you don't like Matthew Polks creations - Infinity had a direct fit as well.
Nowhere ...Fast
end up ordering 6.5" two way Kenwoods each rated at 280W...will have to dig into the rear deck sub to see what size it is to upgrade that as well.... thanks boyz!
Super Moderator
Nowhere ...Fast
installed
Didnt want to start yet another thread on this so i figure i continue this one. Just replaced all the speakers except for the center front, and rear sub ( yet to get to it to look at the size but i think its an 8" bass)
Anyways, the clarity and power of these 4 + tweets is amazing...should have dont this years back.
Anyways here are the shots of the new ones, i end up using all stock housing , the install was a breeze, except that when i was done with pass front i forgot to isntall the corner speaker and grill which were dangling between the door. SO stupid me shot the door crushing the speaker mesh...so now i got to find one. Anyone knows the $ for the plastic corner mesh?
Thanks!
Pic 1- Rear Clarion 2way 6.5", i had to modify stock mesh by removing the stock center tweeter and opening up the plastic mesh that held it.
Pic 2- Front Kenwood 2 way 6.5", the tweeter from which replaced the corner tweeter.
Pic 3- stock fronts Bose that got replaced
Thanks!
