Light switch Illumination on 2005 vs 2001-2004 W203
Old Feb 27, 2006 | 02:24 PM
  #101
allen_7's Avatar
2016 E350, 2013 C300 4MATIC, 2004.5 C230SS
My 04.5 C230SS does light up.
Old Jul 6, 2006 | 11:22 PM
  #102
power-fade's Avatar
"One Man. One Engine."
My 06 C55 doesn't light up icons, only the pointer.
Old Jul 7, 2006 | 11:44 AM
  #103
bnzct's Avatar
06 C230
I opened the switch assembly of my 06 C230, and there is no LED in place to light up the icons.
The circuit board has connections ready for 2 LEDs under the icons. But no LED soldered on it. They kept the old ciruit design (for pre-05 models where icons light up), but decided not to solder the LEDs anymore.
Could it be a cost reduction thing?? LEDs don't cost that much....
Old Jan 25, 2007 | 05:18 PM
  #104
suthnbred's Avatar
2005 C320
Cool Headlight switch on my 05 C320
This is my first post.
I have been round and round with my service department about this problem. When I brought it to their attention in 2005 everyone just scratched their heads. They replaced the switch twice. The switch is a multi-component switch including the lightbulb for the indicator array, so it made no sense that the light array did not come on also, right? Lets go a step further. This switch fits all C class Merz from 99 to 200? and the light array works on all C's up to 2005. It comes down to a technical error on Merz behalf. I was told the computer did not recognize the indicator light array. Go figure. If it weren't for automatic lights I would be lost because my dash is light tan and with those teeny little white icons on the dash panel you cannot even see them in the daytime....no contrast. Have I missed something or has anyone been able to resolve this?
Old Jan 25, 2007 | 08:07 PM
  #105
Arn560's Avatar
Black 04 C230 Kompressor SS
Originally Posted by DriveABenz
I've attached the pics of my light switch in 3 modes:
#1: Ignition in #2 position in dark garage.
#2: Ignition in #2 position, switch set to park.
#3: Ignition in #2 position, switch set to park, front and rear fogs on.
I know that when I got into the car tonight after work that the light switch, only the black part you twist was lit without the key in the ignition. I couldn't repeat that in the garage when taking the pics. I hope that the pics are clear, the tripod wasn't exactly stable when I took the pictures. But you should be able to see that the center icon of the lightbulb is lit in all three modes. I hope this helps.
My 2004 light up just like that.
Old Jan 26, 2007 | 10:46 AM
  #106
suthnbred's Avatar
2005 C320
Cool Response to 2004 lights up
99 through the end of the 04 model year all light up...05 uses the same exact switch but the light will not work. Merz dropped the ball on that one.
Old Jan 26, 2007 | 12:02 PM
  #107
bnzct's Avatar
06 C230
Like I said before there is no LED (or "bulb" if you prefer) under the icons...Take your switch apart and you'll see what I am talking about.
The 2 solutions that I see:
- Install a pre-2005 switch.
- Solder LEDs on the circuit board. The circuit is there. Only the LEDs are missing. But it's Surface Mounted (SMT), so it is not easy to do... I am not even trying.
The only thing I would like to understand is WHY they stopped putting these lights.
Old Jan 30, 2007 | 05:05 PM
  #108
suthnbred's Avatar
2005 C320
Cool Heres your sign
Agreed. My understanding also is that 2005 and later, even if the lamps (LED's) were installed they would not work as the computer does not recognize the circuit, which is there and not connected. I would think a good engineer would have figured something as simple as an onboard lamp could be turned on at the switch itself to begin with instead of looping through the computer. This is why I think I will look at the BMW next go.
Old Jan 30, 2007 | 05:19 PM
  #109
brydon's Avatar
His '06 C350 SS 6MT, Hers '07 C280 S Auto
Originally Posted by BabyBenz6spd
on my car,
Headlight on = Green light icon lights up on dash (right below the speedo)
Fog light on = Green (or orange??) lights up to the left of the turning knob.
Hey check your manual mate. When your headlights are in "Auto" mode, you can't manually turn your foggers on. When you turn the knob to "Headlights On" which is all the way to the right, you can then turn on the fog-lights by pulling the knob 1/2 way out (one "click") and the green light goes on. If you keep pulling so it comes all the way out (two "clicks") your rear fog lamp turns on as well and you get an orange light as well as the green one.
Old Feb 26, 2007 | 03:25 PM
  #110
Cintoman's Avatar
2005 C230WZ SS Capri Blue/Ash
So, with all this talk about the light switch, it seems that the following is the conclusion: All pre 2005 C's icons light up. Some early build 2005 C's light up. But most 2005's and anything newer do not light up. My car is a late (04/2005) build 2005, and, as such, the icons don't light up. Besides the fact that this is utterly stupid, I guess MB wanted to save a whole $0.50 by not hooking up 3 LEDs to the board.
With that said, for those of us with later 2005's, is there anything we can say to the dealership to have them replace our switch plate with a 2004.5 or older one? I have a feeling that even if I print out and bring this post to them, they're just going to say it's not a defect, that 2005 models should NOT light up, and they won't replace it under warranty.
I live in RI. Has anyone here (or in New England) had this work done successfully by the dealer? Heck, I'd be even willing to travel to NY or NJ to have the switch module replaced under warranty.
Thanks,
Paul
Old Feb 26, 2007 | 10:03 PM
  #111
ctC230K's Avatar
excites your girlfriend
Thanks,
Paul
I agree. I already tried it two years ago and I'm in CT. No luck, they will not replace it with an older switch.
Old Mar 2, 2007 | 02:47 AM
  #112
pmb600's Avatar
E550 4MATIC
Oh, I don't know if anyone mentioned this but have you noticed how they cheaped out even more for 2007 by making the headlight switch surround black for every car, regardless of interior color.
Old Mar 2, 2007 | 01:05 PM
  #113
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Are you serious? Wow...that is going cheap. Well, it could be an excuse for people to get folding mirrors, since that entire unit has to be replaced in order to get the folding mirrors! It's one of my favorite OEM mods that I've done.
Old Mar 2, 2007 | 05:41 PM
  #114
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
OEM MB Folding mirror assemblies is one of my favorites too, especially with the MB EURO Convex mirrors.
Carlos
Saprissa@aol.com
www.mbca.org/sandiego
Old Mar 2, 2007 | 06:08 PM
  #115
drexappeal's Avatar
Carlos
Saprissa@aol.com
Yes indeed! I find it hard driving without the convex mirrors. Even though it was a pricey OEM upgrade, it was so worth the money!
For you newbies that want to do an OEM mod, this is one that is worth the good amount of $$$ that you'll spend.
Old Mar 4, 2007 | 12:43 AM
  #116
Cintoman's Avatar
Soo......anyone want to swap their 2004.5 or older ash color with headlight washer button headlight switch assembly with my non-lighting 2005 model one????
Just curious....
Old Sep 5, 2007 | 07:02 PM
  #117
bnzct's Avatar
06 C230
Did anybody manage to fix this headlight switch problem?
Old Oct 16, 2008 | 04:29 PM
  #118
Sbnick04's Avatar
07 C230 Sport
Question Interior lights above light switch
Just picked up an 07 C230 sport and at night when the interior lights are on just above the dial for the headlights the symbols for running lights/auto/headlights do not illuminate. Just out of curiosity I was wondering if that would be a burned out bulb or is that just the only part that doesn't illuminate as far as dash lights are concerned? Thanks everyone
Old Oct 16, 2008 | 05:47 PM
  #119
ChrisBrown's Avatar
2005 C240 4MATIC, 2020 GLC300 4MATIC
They don't illuminate. The only thing that will is the symbols for the fog lamps when you activate them.
Old Oct 16, 2008 | 08:17 PM
  #120
Saprissa's Avatar
there was an extensive conversation about this here on this forum.
Please search for these kinds of common questions before starting a new thread. Thanks !
Carlos
Saprissa@aol.com
