noisy idling sound from 2.3L Engine
Old Feb 28, 2005 | 07:34 PM
tmak26b's Avatar
Quick question, my C230 with a 2.3L SC motor, seems to make noise at idle. It makes a ticking sound kinda from idle (not from valves), it goes away when you touch the gas. It seems to me it is from the belts, can someone tell me if it is the belt or maybe a pulley or something?
thanks
Old Feb 28, 2005 | 07:46 PM
05Css's Avatar
Well I drove the 2.3 engine as a loaner once and it is a noisey car to start with. The ticking sound could very well be related to what you call the PURGE VALVE. When I owned a 2002 C240 I had the same ticking sound at idle as you did. If your car is under warrenty take it in and they would put a cover on the purge valve. The ticking noise should pretty much go about 90%. Easy solution.
Old Feb 28, 2005 | 08:04 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
I love my loud 2.3!! Very noisy when cold, you'll get used to it.
Old Feb 28, 2005 | 09:50 PM
tmak26b's Avatar
I dont think its from the purge valve, I get the noise even when it is warm. It sounds more like a whine/clickish sound
Old Feb 28, 2005 | 09:54 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Supercharger sound. Run a search, this topic has been discussed countless times here.
Old Feb 28, 2005 | 10:35 PM
nukblazi's Avatar
Get a stethoscope and put in on the SC housing while the car is running. BE MINDFUL of the belt.
If it sounds like metal grinding, that's not cool, try changing the SC oil. If it is just a clacking noise, go to zzperformance.com and buy the $40 Eaton SC nose coupler. It's made of harder plastic and makes less noise, and does not fatigue as easily as stock. The stock piece is said to start getting noisey around 40-50, and horrible 65+.
Old Feb 28, 2005 | 10:39 PM
Outland's Avatar
2002 C230 Coupe(M111)
Interesting. Thanks Nuk, never knew that!
Old Feb 28, 2005 | 10:40 PM
nukblazi's Avatar
I find the obscure!
Old Mar 1, 2005 | 03:09 AM
rubensans's Avatar
Brabus K3
Interesting part. Will keep it on my bookmarks. If it wasn't so dificult to replace I will do it right know. But seeing the install, I will wait until the stock one fails.
Best Regards,
Ruben.
Old Mar 1, 2005 | 11:11 AM
nukblazi's Avatar
Best Regards,
Ruben.
Don't think it will ever really fail, you just get noise and slack. I wouldn't want it to fail though, how would you motor get air?
Old Mar 26, 2006 | 01:48 PM
rubensans's Avatar
Brabus K3
tmak26b: Did you finaly solve the problem?
nukblazi: I have this sound but only in cold and with a gear (the first 3 min); could it be this be the coupler? or if it is the coupler I should also have the noise after 3 min?
Best Regards.
Ruben.
