Memory Card ???
The reason MB chose PCMCIA is you can get a PCMCIA card reader and use any memory card that works in that reader. You can get a 6 in 1 reader for instance.
They should've perhaps picked USB, already offered a card reader, or picked expresscard if they at all were going to do something like that.
If they did Expresscard, they could've done some fancy trick things, perhaps being able to hook up a eSATA drive and being able to upload new maps or things like that.
But that would make sense, so Mercedes will never do it.
Now I don't have to go buy that PCMCIA memory card anymore....
I have seen several other people say "USB" that would not be possible.
with so many devices . . thumb drives, eSATA it would require a "Driver" to be installed upon insersion, and of course a operating system.
PCMCIA = So many options
PCMCIA Card reader - MM cards, SD Cards, Compact Flash and quite a few others
No problem.
I figure, if you're dropping 30k$ on a car, what's another 500$ to be able to hook up things through USB
at the time, PCMCIA was still considered a stable technology.
Doesn't the owners manual explain all this? And more importantly, you have a 204 with Multimedia? When was it delivered? Mine is still a month away and I was told I had one of the first available. Perhaps in the Los Angeles zone.
Nope the owner doesn't, and yep i do have the mm..my w204 was a demo..
Good luck with getting your car and trust me the mm is worth it...
Ah, so. Blood pressure coming down now.
