Will the blue bristle brushes at the self car wash scratch my paint????
Old Dec 14, 2007 | 03:36 PM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
Old Dec 14, 2007 | 03:41 PM
diamondblak05's Avatar
Too many to list
YES! Any brush will scratch the car's paint and leave swirl marks...esp. on dark color cars.
Old Dec 14, 2007 | 03:51 PM
webada's Avatar
528i, GLK
YES it will, best way to wash your car is with quality car wash mittens urself.....
Old Dec 14, 2007 | 05:57 PM
nick776's Avatar
C 300
Agreed, those car wash brushes are the tools of the devil!!! Unless the car is white--it's not as bad (although you can see them if you look under the right lighting conditions).
Old Dec 15, 2007 | 01:59 AM
chilledbenz's Avatar
2008 R350 & 2008 C300
*Checks calendar...nope says December not April.
+1 on brushes scratching.
Adds that auto car washes that have the spinning brushes or "rags" will also scratch the paint and in some cases remove your mirrors, license plates, and antenna.
Old Dec 15, 2007 | 10:25 AM
'91 300CE's Avatar
2000 C230K and 2002 ML320
GAH!!! Please don't take your car through a carwash!!
If you REALLY need to... they have ones that are completely touchless... just pressurized water and soap... work pretty well.
Old Dec 15, 2007 | 10:28 AM
ATSOBE's Avatar
I own 2008 C-350 2008 E-350 2005 C -230 Kompressor 2006 FORd F-350 6.0
Exclamation
keep away from it never use it or u get spider scracthes
Old Dec 15, 2007 | 10:33 AM
howie's Avatar
01 CLK 55 AMG
yes +684451326987 I would suggest to still use the car wash however:
1. you bring your own bucket, washmitt, soap and shammy
2. A) put in the minimum amount of quarters and wet your car (start from bottom to top)
B) fill up your bucket with water
3. wash with your personal mitt (top to bottom)
4. put in min amount of quarters again
5. rinse off car (top to bottom)
6. switch to the hot wax and spray (top to bottom)
7. switch to the ultra dry or whatever they call it these days (top to bottom)
8. pull out of the booth and shammy dat ***** down (top to bottom not incl windows)
Thats how I used to do it...saves a couple quarters and no scratches at the same time!!!
Old Dec 15, 2007 | 10:54 AM
ATSOBE's Avatar
Yeap he right that the way of doing it
Old Dec 15, 2007 | 11:38 AM
rb23lb's Avatar
you only get 5 mins for 2.50.... so i could do the first rinse, but is there time in the 2nd session to do steps 5-7 in 5 mins?
Old Dec 15, 2007 | 12:00 PM
howie's Avatar
01 CLK 55 AMG
^^^ yeah...try it out. You'll get better at it the more times you go. Slide in another quarter or 2 to extend the time if you need to
oh and step 9. once the car/paint is dry and streakless/spotless, dry the windows with the shammy and immediately follow with dry cloth/towel (to prevent streaking).
10. hit the slab like bling!
Old Dec 15, 2007 | 12:03 PM
MondayQB's Avatar
2009 C300 Sport 4MATIC
Practice Makes Perfect!!!!
