How to hard wire a V1
Old Jan 14, 2008 | 02:22 PM
speedye500's Avatar
W204 C300
Has any one hard wired a V1 to there car yet if so are there any pics?
Old Jan 14, 2008 | 03:39 PM
visions's Avatar
W204 C300 4Matic Luxury - Steel Grey/Black MBTex/P1/MM
As soon as I get some free time, I'll be running mine. current plan is run along the headliner gap against the window down the A pillar and into the fuse panel on the drivers side (I havent explored the panel yet.. just assume its there and that the cigarette lighter runs to that panel). In there, I plan on just connecting the positive to the positive on the cigarette lighter fuse, ground to a ground.
If anyone beats me to it, definitely post pics. I probably wont get to it for a couple days as the weather isn't exactly joyous.
Old Jan 14, 2008 | 11:19 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
V1 Wiring
<<As soon as I get some free time, I'll be running mine. current plan is run along the headliner gap against the window down the A pillar and into the fuse panel on the drivers side (I havent explored the panel yet.. just assume its there and that the cigarette lighter runs to that panel). In there, I plan on just connecting the positive to the positive on the cigarette lighter fuse, ground to a ground.>>
Unfortunately, there is no driver's side fuse panel in US models because the (very few) fuses located there served equipment that we don't get here. If you have not looked at the fuse diagram, it's the folded paper next to the jack in the spare tire.
Just yesterday I found this because I planned to resume my V1's hard wiring. I had previously planned to tap into the glove box electrical plug until I found out that it's not switched off with the key. I had already fished the V1's power cable down inside the A post (popped the cover off) before I discovered the power problem so I just coiled it up and concealed it. Then replacing the right side kick panel and toe-panel I had removed.
I looked at the underhood fusebox also and it looks like accessing 12V there would be a huge task because the panel must be lifted. Which involves unscrewing the four torx screws at each corner (rear ones invisible) and then fishing a wire through the firewall hole.
The cigarette lighter wire is the next possibility since it feeds from the rear fuse panel in the trunk. If you look at the fuse serving it, you can see the color code and I plan to pull the carpets and cover panels in front of the RF seat again to search for it. If past MB practice applies to this car, there may be a plastic wire chase from up front, under both seats and into the trunk, somehow, through which a wire could be pulled.
BTW, when running wires down the A pillars, it's vital that they be run BEHIND the airbags for obvious reasons. That's why I pulled the a-post covers off.
Old Jan 16, 2008 | 12:11 AM
speedye500's Avatar
W204 C300
On my W211 i had hooked up my V1 from my home link on my rear view mirror. Can that be done on the W204. Oh and I just installed HID fogs and 20% tint.
Old Jan 16, 2008 | 12:59 AM
Savage c-300's Avatar
C300 Sport, MM, P1
this might be a little off topic, but i saw on ebay, someone was selling their services to have the V1 secondary display installed into their rearview mirror. it look flawless! they somehow were able to open up the rearview mirror, take out some of the reflective material and replace it with the V1 display. it made me drool!
here is a youtube link http://www.youtube.com/watch?v=qJa1g3bBSXw
this was installed in a 2008 C300
Old Jan 16, 2008 | 06:27 PM
visions's Avatar
ah useful information. keep us updated on what you end up finding as it will definitely save a number of us a lot of time. pictures are great too if you have the chance.
Old Jan 16, 2008 | 07:07 PM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
That is sick. He also has a backup camera video posted. I think I'll need both.
http://www.youtube.com/watch?v=BRn8BR40peo
Old Jan 16, 2008 | 07:14 PM
kevblah's Avatar
E90 M3
sorry to hear that its a lot harder to hardwire accessories on the w204
im currently tapping 3 fuses on the w203 and my v1 is hardwired with a rocker switch as well
Old Jan 18, 2008 | 06:14 PM
visions's Avatar
RLE was mistaken on the 12V. The passenger side glovebox 12V outlet is switched, so its fine to use that. Should be a simple install.
Old Jan 21, 2008 | 04:56 PM
01S408C300's Avatar
01 S4 6spd-Eurotuner mar.05, 08 c300 6spd, P1-MM- 18`s, 2010 Cayenne GTS 6spd, 98 5.9 Jeep
The lighter is the fuse box is switched
plug the V1 in and turn the key mine goes on and off
Old Jan 22, 2008 | 05:41 PM
ChrisT's Avatar
c320
Hi There, I've got a w203 too and I'm trying to find a switched 12v for a fake alarm light. Can you help!
Cheers
Old Jan 22, 2008 | 06:59 PM
mbenz06's Avatar
So I got my V1 taken care of last night. I took the wire up through the roof on the passenger side to the door. Went down the door line. On the bottom of the glove box, there is a little insert part which u can see when you open the glove box. I can easily open and close the door without problems because it doesn't pinch the V1 wire. Plugged it into the cigarette lighter in the glove box and no hanging wires. Took me 20 min and it was free. I would have taken pics but my camera is getting fixed.
Old Jan 22, 2008 | 09:02 PM
RLE's Avatar
RLE
Fake/
<<I've got a w203 too and I'm trying to find a switched 12v for a fake alarm light. Can you help!>>
Since you already have a flashing red light on the dash when the key is off, I'm not sure why you ask the question, particularly when "switched 12V" means no power when the key is off, not on. If you are looking for a 12V source that's off when the key is off, I can help since I used that in my old C320.
Old Jan 23, 2008 | 03:36 PM
ChrisT's Avatar
c320
Smile
Pehaps I did not express myself right! I want to install a fake alarm light as a
deterant! because I have the command system instaled (by the factory) I do
not have the original blinking light on the radio!
Cheers
