Grille removal instructions?
Subscribe
Feb 14, 2008 | 09:59 PM
Hi Anyone here has the step by step grille removal instruction?
Reply 0
Feb 15, 2008 | 06:40 PM
grille out
<<Hi Anyone here has the step by step grille removal instruction?>>
I did this yesterday. Someone said, once you have done it, fifteen minutes. The first time with no instructions..........
Reply 0
Feb 15, 2008 | 07:03 PM
Reply 0
Feb 15, 2008 | 09:14 PM
Once you have popped the hood:
1) Push the lower part of the grille towards the engine it "clips" out of the bumper.
2) You will see that there are 2 tabs (1 on the left and 1 on the right) that attach the grille to the bumper. Slowly push the upper part of the grille and then you're done.
Hope this helps. If the instructions lack elaboration, just pm me.
Reply 0
Feb 15, 2008 | 10:50 PM
Thats all and good...but how to you remove that damn cover over the top of the grille and hood latch? Theres a nice twist button..but once you twist it nothing happens, even shined a light under neath to see if it was held on by something and came up empty.
Reply 0
Feb 16, 2008 | 04:17 AM
Quote: Thats all and good...but how to you remove that damn cover over the top of the grille and hood latch? Theres a nice twist button..but once you twist it nothing happens, even shined a light under neath to see if it was held on by something and came up empty.
It doesn't need to be removed. Great thing you mentioned this. After the second step, there's a small latch that holds the center of the grille. You need to see that small part clearly in order to know what to do with it. Basically, you just need to hold that latch and push that part of the grille where the latch holds it either to the left or right so that the grille can be removed totally.
To install the new grille, you would need to attach the grille to that small latch first before attaching it to the bumper.
Reply 0
Feb 16, 2008 | 09:07 AM
Thanks guys I will do this next week once the car arrives.
Reply 0
Feb 19, 2008 | 04:25 AM
Finally it's here.
I Hope I don't break anything.
Reply 0
Feb 19, 2008 | 08:17 AM
no you wont, is so easy
Reply 0
Feb 22, 2008 | 05:23 AM
Got it out and didn't break a single clip
It's now in the painters hands.
Reply 0
Feb 22, 2008 | 08:22 AM
Good job
Reply 0
Feb 27, 2008 | 04:01 AM
Finally got the painted grille back and they did a good job
Painting the whole grilled without the chrome inserts.
Reply 0
Feb 27, 2008 | 08:22 AM
looks good
Reply 0
Feb 27, 2008 | 08:38 AM
Rebel, it looks like you left the black plastic center star in the grill for painting. Is that correct? What color did you paint it?
I have mine at the body shop currently for Obsidian Black everything has been removed except the very top black strip. That thing just wouldn't come off. Otherwise everything is off, all chrome, full center star w/black plastic backing.
Reply 0
Feb 28, 2008 | 08:44 AM
Quote: Rebel, it looks like you left the black plastic center star in the grill for painting. Is that correct? What color did you paint it?
We didn't remove the full center star with black pastic backing since it would be covered by the chrome star anyways.
I had it painted black FLAT. the result actually looks like the plastic top black strip that you couldn't remove.
Reply 0
Feb 28, 2008 | 01:18 PM
Quote: We didn't remove the full center star with black pastic backing since it would be covered by the chrome star anyways.
how did you pry out the chrome with out damaging it?? any recommendations?
thanks
Reply 0
Feb 28, 2008 | 01:20 PM
Looks good. I like that you chose flat black.
Reply 0
Feb 28, 2008 | 05:06 PM
Getting the chrome out is a serious PITA. Basically take your time with two small flathead screwdrivers. At least this is what I did. The chrome inserts fit together very very tight to the main grill body. One suggestion for the center star is to remove the entire "assembly" which includes the chrome star and the black plastic backing. The whole thing will fall out once you pry out the bottom two tabs at the 5 and 7 o'clock positions. From there if you want to paint the black plastic it will be easy to remove the chrome.
Reply 0
Feb 28, 2008 | 09:47 PM
Quote: Getting the chrome out is a serious PITA. Basically take your time with two small flathead screwdrivers. At least this is what I did. The chrome inserts fit together very very tight to the main grill body. One suggestion for the center star is to remove the entire "assembly" which includes the chrome star and the black plastic backing. The whole thing will fall out once you pry out the bottom two tabs at the 5 and 7 o'clock positions. From there if you want to paint the black plastic it will be easy to remove the chrome.
Thanks for the info!
I'll give it a shot next week
Reply 0
Feb 29, 2008 | 02:51 AM
Quote: how did you pry out the chrome with out damaging it?? any recommendations?
thanks
At first I didn't know how as the clips seem very fragile but during the installation I notice the guy who did it was very simple and practical.
They use a screw driver to press down the PLASTIC grille body that the chrome clip attaches as a result it would give slack for easy removal of the clips attached to the plastic.
Do not try to move the chrome clips unless it's loose on where it clips on as it may break apart.
I hope this helps.
Reply 0
Feb 29, 2008 | 11:37 AM
Quote: They use a screw driver to press down the PLASTIC grille body that the chrome clip attaches as a result it would give slack for easy removal of the clips attached to the plastic.
you're referring from the back of the case right?
Reply 0
Mar 3, 2008 | 09:50 AM
Quote: you're referring from the back of the case right?
Yes this is at the back of the grille where the clip of the chrome attaches.
Just use a screw driver to press it towards the front and the clip of the chrome will loosen.
Reply 0
Subscribe
Currently Active Users (1)
