Regular Unleaded Gas Users Post here
, but in the meen time Welcome to MBworld.-Mike
M
Plus.. I find that i get better overall better mpg compared to 91, or regular. (i track it using an spreadsheet, and everytime i fill up i record how much gas ive driven on that full tank, and the price at which i paid for 93(usually 3.29-3.40) Oh... and i go out of my way to find a cheap gas station.
No one has presented any real evidence of long term damage, and if anyone has any, I'd can certainly be persuaded to change my mind on th issue.
And since now one else has posted (yet) to the forum that they are using Regular, I guess I am the only one "stupid"
enough to do so ?Anyhow, thanks for the feedback, and keep it coming. I'll be sure to report when my engine blows up from "pre-ignition?".
His other caution was that the new higher mileage synthetic oil ratings were based on using proper octane, and it'd be a good idea because of the extra heat, to change the oil more frequently.
He didn't mention anything about engine longevity ... both of us only keep our cars 3-4 years so we don't really care about rebuild times. We're more concerned with transmission longevity (we both had BMWs at the time and BMW automatics aren't known to last very long).
I figure, I like power and since the extra $.20 a gallon is only 5-6% more than the cost of low octane, I'd spring for it. I'm already spending way more than I need to for transportation anyway ... if I were really concerned, I believe a better way to save money at the pump is just to drive less. Compared to other cars in its power/size bracket, the C gets awful fuel economy, so I'm already spending more than I should.
Plus if I feel like slumming it, I can get better than 5-6% discount on my gas by using a grocery store or costco branded gas.
I tell my wife's grandma to use regular though. She only drives 50 miles a week and drives like a 'granny' so there's no point in her spending the money.
On the flip side, my wife accidently put lower octane in her Q7; she noticed a lot of pinging and hiccups in acceleration ... but it could've just been crappy gas too?
Mercedes has no incentive whatsoever to make you use higher octane than you need, and of course Mercedes knows more about its "knock sensor" than do you.
I would suggest those proud of themselves for "beating the system" by using regular fuel put their money where their mouths are and post their VIN numbers here--cars to avoid on the used market for sure.
Your engine will probably not blow up from pre-ignition, but there are a number of other possible issues that could happen, one of which happened to a friend of mine a couple of years ago.
This guy bought a new C class and ran regular in it, always insisting it was no different. Eventually he started getting some noise from the valve train so he brought it in to the dealer (still under warranty). They inspected the car and it turns out he bent a couple valves. Since they were confused how this would happen on such a new car, they checked the ECU and found numerous stored codes for pre-ignition. Now very suspicious, they analyzed the gasoline and found it to be below the 91 minimum. Since they knew not only that the gas was under spec, but that he had been using that for a long time, they charged him the diagnostic fee and voided his warranty.
I agree with LK, if you are going to continue to use regular, post your VIN so nobody here will get stuck with the car.
maybe I should clarify. "You won't see any immediate ill effects."
I wish I could hit people in the head with a gas nozzle when I see them fill up 87 in a car that requires at minimum 91 octane. Why? Why? To save $2 at fill up? You are going to spend more money maintaining the car otherwise and have larger repair bills.
