B Service
B Service
Hi guys,
I have my car due for a B service...so far, I've been quoted for $600, inc. taxes. I'm located in Vancouver, Canada. Is this a reasonable price?
Does anyone have any suggestions for independent mechanics in Van.? Thanks for all your help!
All the best,
e55fanatic
All the best,
e55fanatic
1 Post
2008 Mercedes C300 4Matic
Hi guys,
All the best,
e55fanatic
All the best,
e55fanatic
ML 350-Black=Sold. New 08 C300 4Matic, Black/Black, P1, Ipod, Auto7speed, 10/10 hit 100,000 miles
MB service isn't cheap, I had an ML350 before this and never had a service less than $400.00US
C350 4MATIC Premium Package Obsidian Black
i think that 600 incl tax is about right. when i picked up the car, they told me that the b service was around that 5 bill range. i am assuming that they quoted me a price not incl the tax. i expected this car to cost me more on maintenance.
08 C300 Sport
2010 ML350 CDI AMG Sports, BMW e92 335i (sold), CLK240 Avantgarde (sold)
it really depends on the wear and tear of the car, a good mechanic will let you know AND show you what is needed to replace / repair. Mine costed AU$2000 for Service B. Had the replace some bushes on the front suspension or something that was a common wear and tear issue with W203/W209 (share the same chassic). If not replaced it would have costed me more later down the track as other parts will need replacing. I will see my invoice and post what was done tomorrow.
Hello Kaiju, Could you tell me how many Km your car has travelled before you needed to replace the suspension bushes? . Has it had a hard life on bad roads? If not what would cause the suspension bushes to fail. I have a Peugeot 405 that has done 250,000 km on country roads & the suspension is original.
History of my services
20,000 km
Service A - around $300
oil change plus reset of the computer with star diag
35,000 km
Service B - around $500
same as Service A + more detail checks
50,000 km
Service A + front brake pad and disc - around $600
65,000 km
Service B + suspension parts - around $2000
Breakdowns of the major parts:
Labor:
front suspension arm bushes and stabilizer bar links on both sides - $240
Service B - $200
oil filter - $60
flushed cooling system - $60
replaced brake fluid and flush entire hydralic system including ABS/ESP - $60
parts:
air filter set - $103
fuel filter - $214
Antifreeze - $90
2 litres of transmission fluid - $50
2 litres of brake fluid - $50
2 x thrust arm bush - $153
2 x stabilizer bar link rod - $241
8 litres of full synthetic Oil - $116
Other issues that i had:
Wheel bearing failure on both wheels - $600
Should have claimed this under warranty but the stealership had no clue until too late... out of warranty now. They blamed it on my worned pads at the time which was crap because it still had 1/3 left. The failure sounded like a metallic rattle whenever i go over uneven surface, initially i thought my pads was loose in the calipers but upon inspection, it was not the case. My mechanic actually showed me how to check that by placing one arm at 12 o'clock and the other at 3 o'clock of the wheel and pulling back and forth towards yourself to feel if there are any free-plays... if there is, your screwed!
Noisy brakes:
Started having squealing brakes at around 30,000km which continued after it was replaced but that was due to the wrong pads the dealer delivered (wheel bearing failure was also part of the caused of the noise). Pads were "dust-free" type for cold climate (noticed that i didn't have to clean my wheels for month which made me suspicious). Once it was change to the normal dusty oem ones, it was fine (now i have to clean my wheels every week again ).
As mentioned before, all depends on the wear of the car but as the car has more km's, more thngs will need to be replaced, a good merc mechanic will know what to look for and what to expect. But I have to admit after that major service, the engine feels really solid and smooth, a good reset of the star diag always helps (good luck getting that done at your local stealership! let alone having a young apprentice servicing your car).
20,000 km
35,000 km
50,000 km
65,000 km
Labor:
Service B - $200
oil filter - $60
parts:
fuel filter - $214
Antifreeze - $90
Noisy brakes:
Kaiju ,Very interesting, thank you for taking the time to list all the servicing. Cannot understand why the front wheel bearings would fail unless they were torqued incorrectly, the seal failed or faulty hard facing during manufacture. I think you have a case to question MB about this. Carsy.
1 Post
20,000 km
35,000 km
50,000 km
65,000 km
Labor:
Service B - $200
oil filter - $60
parts:
fuel filter - $214
Antifreeze - $90
Noisy brakes:
20,000 km
35,000 km
50,000 km
65,000 km
Labor:
Service B - $200
oil filter - $60
parts:
fuel filter - $214
Antifreeze - $90
Noisy brakes:
hehe... no, its a W209 but they are very similar or at least the new CLK will be based on the new W204 platform.
Just got a message that my vacuum tubes were leaking....and that they replaced it because it was difficult to contact me..
Don't know how much that will cost me yet. However, it was interesting how they said that I had 20% brake pad left when the low pad wear indicator kept lighting up every time I pressed the brakes. After telling them that my wear indicator kept coming on, I got a pricing for $500 to replace the front discs and pads. Does this sound reasonable? I'm not quite familiar with the pricing. Thanks in advance!
shelled out $2050
A quick update:
So I paid $1150 for the b service + front pads and rotors. 1 day later, my check engine light went right back on. I brought it in again, but the SA said that it was not their fault and they would charge around $200 to check it again. I said fine, being all too nice, and now, as I expected, he said that the MAF sensor needs to be replaced for a whopping $700. So now, I'm waiting for my car to be fixed, and lighten my wallet when I pick it up later today. Any advice, guys, or am I pretty much screwed? :S
Btw, I had it serviced at the MB dealership at Boundary Road in Vancouver.
1 Post
A quick update:
Darn it! If you'd only tell me earlier...I've already signed an authorization form, so I think I'm pretty much screwed. *sigh*
I bought my MB from the Vancouver dealership, but I thought Boundary road might have had better service. Guess not.
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Repair costs
<<History of my services
20,000 km
35,000 km
50,000 km
65,000 km
Labor:
Service B - $200
oil filter - $60
parts:
fuel filter - $214
Antifreeze - $90
Noisy brakes:
As mentioned before, all depends on the wear of the car but as the car has more km's, more thngs will need to be replaced, a good merc mechanic will know what to look for and what to expect. But I have to admit after that major service, the engine feels really solid and smooth, a good reset of the star diag always helps (good luck getting that done at your local stealership! let alone having a young apprentice servicing your car).>>
Some of these prices are seriously out of whack.
$214 for a fuel filter?
$90 for one gallon of antifreeze? Let's hope it was the MB approved stuff and came in a crystal decanter at that price.
$50 for 2 liters of trans fluid? Why only two? Changing the trans fluid takes far more than that and I don't see a filter listed which is always changed.
8 liters of oil at $14.50 per? Twice the US dealer price which is also a ripoff.
I know this is Australia but, come on!
And wheel bearing failure? Not until high mileages. And if this should have been warranty and the dealer screwed this up, they should eat it. Not you.
And, brake pads have absolutely no connection with the bearings.
BTW, the CLK is on the W202 chassis, not W203. Front suspension bushing failure was not exactly unknown on both the 202 and 203.
20,000 km
35,000 km
50,000 km
65,000 km
Labor:
Service B - $200
oil filter - $60
parts:
fuel filter - $214
Antifreeze - $90
Noisy brakes:
Vacuum tubes??
<<Just got a message that my vacuum tubes were leaking....and that they replaced it because it was difficult to contact me..>>
Vacuum tubes? What in God's name are vacuum tubes, automotively speaking.
