bought a MB oil filter, now i have questions about diy oil change
Old May 22, 2008 | 02:39 AM
delirium's Avatar
C350
so I bought an oil filter from the MB dealership today and have a couple of DIY oil change questions..
1. There is a washer taped to the top of the box, is this washer for the drain plug?
2. Can I use an oil extractor like the topsider to extract the oil from the dipstick tube or do i have to drain the oil? (I used to extract the oil from my BMW, not sure if this is ok on the C350)
3. How many quarts of oil does the C350 require?
TIA!
Old May 22, 2008 | 07:46 AM
narky's Avatar
2008 Arctic White C300 Sport 6M
Old May 22, 2008 | 08:34 AM
Derspeed's Avatar
X3 and 2012 C coming soon
It takes about 8 quarts.
Old May 22, 2008 | 09:31 AM
RobertG's Avatar
things with and without wheels
Yes, the washer taped to the oil filter box is for the drain plug.
Old May 22, 2008 | 09:06 PM
nyca's Avatar
They give (sell) you a drain plug washer, when the spec calls for a topside extraction. How's that?
Old May 22, 2008 | 09:53 PM
AsianML's Avatar
2007 E63
You can do it either way. The engines were designed with oil extraction in mind, so many opt for this method since it's easier.
Old May 23, 2008 | 12:47 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
Oil change
<<so I bought an oil filter from the MB dealership today and have a couple of DIY oil change questions..
3. How many quarts of oil does the C350 require?>>
How coincidental. Just yesterday I changed my C300's oil using my Topsider.
At 5000 miles, the oil was visually filthy. Took about 30 minutes. I used the last of my Mobil 1 0W40. I did not reset the service indicator.
The brass washer is for the drain plug which I didn't use, of course. The oil filter comes with more 0-rings than are needed. I used three. The oil capacity is 8.2 quarts and I put in 8 (see your manual). The oil level on the stick should be anywhere between add and full.
Old May 23, 2008 | 02:17 AM
delirium's Avatar
C350
3 o-rings needed? I'm used to using only one, is it obvious where the 3 o-rings should go? Thanks!
Old May 23, 2008 | 03:31 PM
nyca's Avatar
RLE, this is not for a W204, but is it similar to what is shown here? They show 4 gaskets for the filter assembly.
http://www.mercedesshop.com/Wikka/OilFilter2
Old May 23, 2008 | 11:54 PM
RLE's Avatar
RLE
OIL CHANGE
<< this is not for a W204, but is it similar to what is shown here? They show 4 gaskets for the filter assembly.>>
Yes, it is. The tools required are the same and the filter itself is visually the same. The filter installed on the cap assembly which is different but all will be obvious when you remove it. It is in the same general location as the V-8 but under the corner of the engine cover.
Really, you can't go wrong.
Old Jul 15, 2008 | 10:19 PM
Spec_Davis's Avatar
W204 Color: 090 / 1999 Honda Civic EX / 2003 Acura TL
can any one make a DIY sticky on how to change oil on a 2008 C300/C350 i need pics and instructions.
