C63 Quad Exhaust Project
W204 C300 with C63 exhaust
http://www.youtube.com/watch?v=uM-JmvUQ8Ww
Have you put it on a 4 cylinder? If so have a video clip? Thanks
Sorry for the very late reply, yes I do have some picture, and made a sound recording.
Car is original a W204 180K Avantgarde AMG package, so it is a four cilinder machine. This mod works also fine on a 200K or 6 cylinder machine, the 6 sound beter as I said before.
Limits on the picture size, at this forum but it give you an idea.
As you can see, one original pipe from the engine had to be split into a Y split. When this is done, test have to be done to see if the left and right have the same amount of exhaust gas. If not the Y split needs to be adjusted.
Bare in mind, this is a original C63 spare part exhaust, I had to get a C63 VIN to get it. The replica exhaust, as far as I understood, don't give the same "sound" as the original one.
And ... there is no problem with the warranty, as the parts are original, and build in by a dealer.
Cheers,
Gokalp
expensive don't you think
until i see otherwise
