Old Jun 4, 2015, 06:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
w204 secrets thread...
Rating: Thread Rating: 11 votes, 4.64 average.
Old Mar 2, 2009 | 10:39 PM
  #351
hemptation88's Avatar
2009 c300 4matic
is there a way to switch quickly from bluetooth back to just the cell phone while your on the phone in the car?
Old Mar 2, 2009 | 10:45 PM
  #352
c200mfmw's Avatar
C200
Originally Posted by Xaniar
Jesus man,
Have you been living on another planet?
That feature is called a child safety lock and you have it on most of the vehicles.
I must have been since it wasn't on my previous Boxster.
Old Mar 3, 2009 | 05:30 AM
  #353
Xaniar's Avatar
E200C-Fully loaded, Obsidian Black, ILS, Panoramic roof and some other bits and pieces.
Boxster is more of a non-family car, and it's a coupe.
That's probably why it didn't have it.
The feature is quite useful but annoying at the same time.
Imagine having both of the back door’s child lock activated and someone wants to get off the car, then you need to play the smiley chauffer part.
Old Mar 3, 2009 | 08:28 AM
  #354
Bokx_350's Avatar
C350
I think this depends on your phone. It is very easy on the iphone, just one button on the screen and your conversation goes thought the phone's mic/speakers (but the car stereo is still muted). Also, if I pick up the call through the phone (not by pressing any of the car's buttons) it will go directly to the phone and not the car stereo. Very usefull.
Old Mar 6, 2009 | 04:23 PM
  #355
sm787's Avatar
C200K Elegance 2008, auto,Met Black, Comand + HD, Alloys, Fully Loaded.
am new on this board .but would like to say thanks to everyone for sharing all this information........very interesting ...knew some already ...
Old Mar 22, 2009 | 12:04 AM
  #356
Mrsl500's Avatar
SL
Heres afew helpfull links with information On the Bluetooth phone system in the W204.
http://mercedes-benzbluetooth.blogsp...h-pairing.html
http://mercedes-benzbluetooth.blogsp...2009/03/1.html
http://mercedes-benzbluetooth.blogsp...y-pairing.html
http://mercedes-benzbluetooth.blogsp...comand-or.html
http://mercedes-benzbluetooth.blogsp...ap-cradle.html
I hope this helps!
Old Apr 1, 2009 | 09:35 AM
  #357
woofwoofz's Avatar
2009 C300 4Matic Sport...2012 C350 4Matic
Originally Posted by dansonchan
i dont hv too!!...
why??....i like the one can tilt down when u in R gear!
On mine, you need to program it before the passenger mirror will tilt downward in reverse gear. Here are the instructions:
Storing a parking position
To make it easier to park, you can store the front-passenger side exterior mirror position in such a way that you can see the rear wheel on that side as soon as you engage reverse gear.
You can store a parking position for the exterior mirror on the front-passenger side using the memory button.
You will find information about using the exterior mirror's parking position in the "Parking aid" section more.
<1> Exterior mirror on the driver's side
<2> Exterior mirror on the front-passenger side
<3> Adjustment button
<4> Memory button
Make sure that the vehicle is stationary and that the key is in position 2 in the ignition lock.
Press button <2> for the exterior mirror on the front-passenger side.
Use adjustment button <3> to adjust the exterior mirror to a position which allows you to see the rear wheel and the kerb.
Press memory button M <4> .
Press one of the arrows on adjustment button <3> within three seconds.
The parking position is stored if the exterior mirror does not move.
Hope this helps.
DW
Old Apr 1, 2009 | 06:35 PM
  #358
sameer13's Avatar
2009 C300 4Matic
<4> Memory button
Hope this helps.
DW
Thank you for this post, this is the most usefull post I have seen here. I am a new C300 w4m owner.
So this can only be done on the passenger side?
Old Apr 1, 2009 | 07:53 PM
  #359
nickm's Avatar
C350
This didn't work for me. I have a US 2009 C350.. Is that only for Canadian models? Thanks
Old Apr 1, 2009 | 09:00 PM
  #360
sameer13's Avatar
2009 C300 4Matic
Initially this didn't work. This not even in my manual.
What I did was start the car and put in reverse, then set the passenger side mirror all the way down to see the lines on ground in the parking spot, then press the memory button only.
To test this, press he left mirror button and should notice that the right mirror moved back to the regular position. Then press the right mirror button and the mirror will tilt back down. All this with car in Reverse.
Now everytime I put the car in reverse, the mirror tilts and will move back when I switch the gear. Remember that the right mirror button should be last active button for the mirror to tilt automatically.
Old Apr 1, 2009 | 09:01 PM
  #361
woofwoofz's Avatar
nickm,
I don't think it is specific to Canadian model. Can other US C class owners confirm this?
DW
Old Apr 1, 2009 | 09:04 PM
  #362
woofwoofz's Avatar
Unfortunately, only the passenger side only :-(
Old Apr 2, 2009 | 09:50 AM
  #363
Mark08859's Avatar
2008 C300 Sport
nickm,
DW
Unfortunately, for 2008 anyway, the US models do not have a tilt feature when going into reverse. I have not heard anything about it being included for 2009.
Old Apr 10, 2009 | 03:55 PM
  #364
len56's Avatar
C350
I don't get a something from the first post:
"if you use two fingers you can do all fore windows at the same time, up or down."
How do you do that?
Old Apr 10, 2009 | 05:21 PM
  #365
woedee's Avatar
w205 - Black
Is the "R Tilt-Down" mirror feature only available as part of Memory Seats option?
Old Apr 10, 2009 | 06:09 PM
  #366
JimPap's Avatar
2008 C300 Sport, RWD, US
How do you do that?
I think the way you'd have to do that is to place each finger between a pair of window buttons or have some radical surgery that widens each finger quite a bit.
Old Apr 10, 2009 | 06:34 PM
  #367
hazee's Avatar
C200 Kompresssor
27) slight tap on blinker gives a short 3 blinks for lane changes
What is it?
37) you only get the beep beep beep on the alarm if you actually have an alarm. otherwise just lights will flash.
How to disable alarm?
Old Apr 10, 2009 | 06:51 PM
  #368
len56's Avatar
C350
"hold alarm on/off pointed at small square on driver's-side door handle to open/close sunroof and windows."
Guide me through this. Doing this would be a sick way to show off
So you press and hold the alarm button and aim the key at the driver door...
do the windows go up or down? I thought it would be something like you hold the open button to bring all the windows down, and close to bring them up...
Since there is only one button, which way do they go?
Does this process open the panorama roof? And if it does, how does it open it, tilt or slide?
Old Apr 10, 2009 | 07:00 PM
  #369
sameer13's Avatar
2009 C300 4Matic
OK so there is no need to point it a the small square. If you hold theunlock button down, all the windows and sunroof (slide) will open. If you hold the lock button down, all the windows that are open and the sunroof will close.
You have to hold the button down until fully open or close, if you let go, it will stop.
Old Apr 10, 2009 | 07:06 PM
  #370
jstaneff's Avatar
C-300, XC70, Wrangler
I did this the other night with a friend's new C (new 2008) and the pano roof did not open/close.
But, when I paused closing mid-way up, then pushed close again, they resumed properly.
Don't press the alarm button, you'll just get a scare!
Old Apr 11, 2009 | 12:07 AM
  #371
sameer13's Avatar
2009 C300 4Matic
I don't have pano roof and my roof open and closes.
Old Apr 11, 2009 | 11:57 AM
  #372
len56's Avatar
C350
Ok, thanks to both of you! =)
To bad the pano roof don't do it :P
Old Apr 11, 2009 | 04:27 PM
  #373
hazee's Avatar
C200 Kompresssor
Here is a new, if you have it as a standard option, I have it.
The Cooling/AC/Fan with a knob in glove compartment.
Old Apr 11, 2009 | 04:30 PM
  #374
sameer13's Avatar
2009 C300 4Matic
I have a knob in the glove compartment and it controls the opening and closing of the the vent in the glove compartment to allow for cooling or heating.
Old Apr 11, 2009 | 05:06 PM
  #375
SmokyMtnBenz's Avatar
C300
New to MBWorld and thanks for the insight. One really convenient feature, although not really a secret, is being able to open the trunk without having to push a button inside. The car just has to be unlocked. I think all cars I've owned before this one, you've either needed a key, had to press a button on the driver's door or needed the key fob. Super convenient.
You have already rated this thread Rating: Thread Rating: 11 votes, 4.64 average.
