Old Jun 9, 2015, 04:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
DIY: Interior light removal
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jan 4, 2009 | 08:20 AM
W200K's Avatar
C200 Kompressor
For the interior light, is there anything holds the cover?
coz i just try, and i crack it
so i decide to stop it instead i crack the whole cover.
thanks
Old Jan 4, 2009 | 08:57 AM
ctgilles's Avatar
S204 C220 CDI, VW Scirocco III 1.4TSI 160
Originally Posted by got_thang?
I prefer piaa or polarg leds. If you get a error message just put a resistor on and It'll go away and will stop staying lit or flicker
So you say the interior lights give a warning message?!? What a pain in the ***, not even BMW is this irritating...
I thought only outside lights trigger a warning message??
And is that festoon bulb 36 or 39mm ?
Old Jan 4, 2009 | 03:19 PM
got_thang?'s Avatar
2008 C350
Interior lights do not throw a code. That only happens on exterior lights
Old Feb 1, 2009 | 12:22 AM
Robbio204's Avatar
C350
So before I removed the trunk plastic reflector in the trunk (since it was the easiest to access) and I had trouble with removing the bulb, like how do I do it? It was hot since it was still on and I didnt want to break the bulb or the socket, do I pull it or what?
Old Feb 1, 2009 | 12:25 AM
Robbio204's Avatar
C350
Is it at the eighth picture down...basically how do I change it?
Old Feb 1, 2009 | 01:32 AM
got_thang?'s Avatar
2008 C350
Do it in the day time. And turn off the door lights and pull the bulb out
Old Feb 1, 2009 | 01:36 AM
  #32
aprince2die4's Avatar
08-C350 black/black
the bulbs just pull out...just dont squeeze to hard on the bulb...
Old Feb 1, 2009 | 02:22 PM
  #33
Robbio204's Avatar
C350
Okay sorry for the somewhat dumb question lol
Old Feb 2, 2009 | 12:04 AM
  #34
german-anger's Avatar
C350 Sport 4M
change 'em all to RED LEDs. would look pretty menacing on a black on black car =)
Old Feb 4, 2009 | 01:39 AM
  #35
woolala's Avatar
2007 SLK350
oh no! blood! O___O
but yea.. ~ thanks for sharing the instruction! =]
Old Feb 4, 2009 | 11:38 AM
  #36
M-bENZ's Avatar
Corrolla
yes if u mean the Rear dome.
Old Feb 12, 2009 | 06:18 AM
  #37
litlman's Avatar
W204 C200K Calcite White, W211 E320 Obsidian Black.
Thanks heaps for the DIY. I have just done this and probably wouldn't have without this, to worried about breaking stuff.
FYI - I saw in another thread that if you stick a credit card into the gap between the back of the front dome light console and the headlining you can pop the whole unit down and remove the lamps from the back.
Thanks again.
Old Feb 18, 2009 | 01:45 AM
  #38
Robbio204's Avatar
C350
extremely helpful....used Polarg M4's..will post pics soon
Old Feb 18, 2009 | 08:30 AM
  #39
ctgilles's Avatar
Rear number plate lights on a S204 are a PITA Won't be changing them I need to dismantle the whole trunk
Old Feb 21, 2009 | 09:01 PM
  #40
Robbio204's Avatar
C350
What is the Light Bulb Number for the Rear Dome Light, Like the Main bigger one? I have Polarg M4s 194 do they make compatible ones of that number for the same color effect?
Old Mar 20, 2009 | 09:23 AM
  #41
Robbio204's Avatar
C350
Anyone?
Old Mar 20, 2009 | 09:29 AM
  #42
TB5...'s Avatar
2009 C300 4Matic
and the pics have apparently exceeded bandwidth.
Old Mar 20, 2009 | 10:11 AM
  #43
who8888's Avatar
15 E350 4Matic
Anyone?
It is a Festoon light bulb and polarg has one. Don't have the number handy put can post it tonight once I get it.
Old Apr 24, 2009 | 09:08 PM
  #44
kevinwithdabenz's Avatar
08 c350
ahhh that dam dome light wont come offf!!!! im like pullin on th cover trying not to crack it, then when i give up, and push it bak in everything just snaps back in. I FAIL!
anyone can gime some advice PLEASE ;x
Old Jun 16, 2009 | 09:58 AM
  #45
kaku's Avatar
2009 C300S 6mt
i'm in the same boat as you !
it's much harder than i thought to remove that front dome.. even using 3 screwdrivers and no deal=I
Old Jun 16, 2009 | 11:51 AM
  #46
peabers's Avatar
2011 E350 4Matic Wagon, 2013 C350 4Matic Sedan
I found the dome light difficult to pry out as well... but I got it to work by starting to pry from the trailing (passenger) edge, and then working down the sides towards the front of the car. With every pry, I slip my screwdriver in deeper.
... Good luck!
Old Jun 18, 2009 | 12:12 AM
  #47
Exia's Avatar
2009 C63
Any advice on the front dome light? I found them really hard to remove and I am scared of breaking things..
Old Jun 18, 2009 | 01:30 AM
  #48
louiet3's Avatar
2009 C300 Sport Palladium Silver & 2012 GLK350 4matic Black
Dome Light removal
If you insert a credit card like in the picture in the link below you will easily remove the dome light without any breakage. Mine slid off quite easily.
https://mbworld.org/forums/attachmen...g-p1010077.jpg
Make sure you hit the 8 black pointy latches shown on the 2nd picture.
https://mbworld.org/forums/attachmen...g-p1010048.jpg
Luis
Old Jun 18, 2009 | 08:26 PM
  #49
kaku's Avatar
2009 C300S 6mt
fINALLY got it ! thks to Luis ! =)
Old Jun 18, 2009 | 10:56 PM
  #50
Exia's Avatar
2009 C63
Thanks Luis! I did it just now thanks to your pointers
Next up is eyelid, license and other interior lights !!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
