Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
- Mercedes-Benz C-Class: How to Remove Interior Lighting
Step by step instructions for do-it-yourself repairs
DIY: Interior light removal
#51
Have you replaced the rear dome festoon with LED as well? What did you use?
#53
2009 C300S 6mt
haven't replaced the rear dome yet. hopefully, it'll won't put up a fight to get opened=]
there should be plenty of festoon-type LEDs on Ebay. but with so many diff types, it's hard to pick one. i'm just gonna head to Chinatown or Alhambra-area and pick one up..
#54
Do let me know if the one you get is as white as the warm white LEDs - 4300K .
#55
Can anyone provide any insight on which LED lights to use. I am aware that the size is 194 or 168, but its hard to pick the right ones. I would like to change all of the interior lights to LED. Thanks!
Here is the site...
http://www.v-leds.com/194-168-158-LE...orLanding/true
Here is the site...
#56
2009 C300S 6mt
click on the product link and check the V-LEDS Part ID, if it starts with 194 you're good.
however, you should stick with the design/shape that's of the typical 194 bulbs - i.e., don't pick an led that's too big or has like 198528 leds on them.
#58
Do you have any pics or info on the bulbs that you are using? I wanna change them all out to LED, but I don't wanna waste money on bulbs that won't fit. I too am looking for that bright look. Thanks!
#59
2011 E350 4Matic Wagon, 2013 C350 4Matic Sedan
#60
2009 C300S 6mt
on the contrary. there were a few people who cracked their cover trying to pry it open. i know i was at the point of cracking it several times myself=)
#62
Sliding the credit card easily separated the front dome from its latch. Try it and you will know what I mean.
#64
2008 C350 Palladium Silver
Rear dome light cover removal
Thanks for posting that DIY, I couldnt figure out how to remove that rear dome light cover. Do you know where I can find a blue bulb for the rear dome light? I bought some off of E-bay but they look different. They fit in the front dome light, but by the looks of the rear light, it looks kinda like a fuse?? Didnt get one that looks like that. Thanks for your post.
#66
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
what is the polarg festoon bulb that you guys use???? is there a non LED light that works good with the rear dome??
I put polargs in the front dome and want to make sure it matches in the back dome...
please help TIA
are these the right bulbs for the festoon dome light????
anybody out there?
http://www.eautoworks.com/product-Polarg-2067.htm
please help TIA
anybody out there?
#67
Polarg M28 festoon
I remember seeing several posts before regarding the Polarg M28 festoons. Try searching for Polarg M28 to find previous posts.
Luis
Luis
please help TIA
anybody out there?
please help TIA
anybody out there?
#68
i need help with the reading light under the rear view mirror, tried changing it and the housing was push in? is there a way to open the rear view mirror to access the light housing and put it back in its place?
#69
did anybody else change the rearview mirror bulbs???
#72
2012 C250 Coupe
I ordered M28 Festoon Bulbs for my w204 and they are too small... They aren't long enough, I need them to be another 1/2" longer. Does anyone have any idea what the Polarg bulb is for the rear seat dome light?
#74
