Old Jun 9, 2015, 04:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
DIY: Interior light removal
Rating: Thread Rating: 2 votes, 5.00 average.
Old Nov 11, 2011 | 03:11 AM
  #101
AMafia718's Avatar
'11 E350 4Matic AMG Sport ,09 C300 4Matic Sport Sedan, 25,000miles,P1, MM Package, (Sold) 1998 E320
Cant even get the front to budge, scared to try back.....my 2000 eclass was a piece of cake to change every led!!!!!!
Old Dec 21, 2011 | 01:34 AM
  #102
qaz393's Avatar
AV6
how do i pull out the bulb for the front reading lights?
Old Dec 21, 2011 | 04:12 PM
  #103
AZN Optics's Avatar
SPONSOR/MBworld Guru
tweezers and a thin thin flat head screwdriver. 90 degree precision needle nose pliers with a bit of double sided tape on them for grip and padding work too to remove the bulb.
Old Dec 21, 2011 | 05:29 PM
  #104
qaz393's Avatar
AV6
good idea. im going to try to use some tooth floss and wrap about the base and pull it out like a teeth
Old Dec 21, 2011 | 06:31 PM
  #105
AZN Optics's Avatar
That works too, but it's pretty tight in there so will probably take some time to get it looped and tightened. Good luck
Old Oct 31, 2012 | 11:52 PM
  #106
Adrian97c's Avatar
2010 Mercedes-Benz C-300, 2011 Kia Optima 2.0T(GDI)
Question
I will try this!! I gave up on the map reading lights in the rearview mirrors, left them yellow stock
I replaced all my interiors just now, but I left the 4 door courtesy stock since the red covers kinda makes adding white LED pointless...
@ AZN Optics, question... since I have 4 extra 194 wedge bulbs (from skipping the doors), could I use the same bulbs for my exterior Eyelids? (error free?)
Attached Thumbnails DIY: Interior light removal-photo.jpg
Old Nov 1, 2012 | 12:30 AM
  #107
AZN Optics's Avatar
yup, and works for sidemarkers as well.
Old Nov 1, 2012 | 10:25 PM
  #108
Adrian97c's Avatar
worked thanks! only issue really is the 2010c300 I have doesnt have the bi xenon headlights, so the eyelids are white now and the low beams are yellow
Is there a way to switch (non-xenon headlight) low beam bulbs for a 5000k bulb? or would i have to do a complete headlight assembly switch out for the xenon set?
Old Nov 1, 2012 | 11:18 PM
  #109
AZN Optics's Avatar
If you don't want an HID kit, you can try for whiter halogen bulbs like Philips Diamond Visions.
Old May 30, 2013 | 08:54 PM
  #110
Carlos.33193's Avatar
C250 2012
Anyone know how to remove the 2 map/reading lights that are in the rear view mirror on 2012 W204? I don't want to break it but it seems like the little frosted lens doesn't come off.
Old Jun 1, 2013 | 07:21 PM
  #111
C250 2012
Anyone?
Old Jun 3, 2013 | 09:46 PM
  #112
katuga's Avatar
2013 W204
2013 W204 internal LED Lighting
Anyone?
I have a wide variety of LED lights from previous Bimmer convertion. I decided to replace all internal lighting on my 2013 W204 to LED except for the map light. It is cool white enough for me. Now the footwell lit up for a second when door is open. I think it need a load resistor.
Old Jun 16, 2013 | 08:39 PM
  #113
got_thang?'s Avatar
2008 C350
They came led on mine so I didn't mess with it nor do i want to
Old Jun 17, 2013 | 03:23 AM
  #114
rolex16233's Avatar
c220
can anyone advise me that the size of the center length of the rear dome light. 39mm? does normal LED trigger the alarm? the interior lights. i am assuming the license plates light bulb will trigger alarm as i seen one w220 has alarm while license plate light bulb blown.
Old May 31, 2014 | 03:15 PM
  #115
kerrylancaster's Avatar
2012 C250 Sport Coupe
C250 Interior Dome Lights
Has anyone tried the Sylvania 6000K 168/194/2825 LEDriving bulbs (instead of Polarg M-4) as dome light replacements for 2012 C250?
If so, do the Sylvania LEDs already have the resistors mentioned in previous posts, or will they require adding a resistor?
If a resistor is required, what kind/size/model/spec is required?
Thanks in advance!
-Kerry-
Old Jun 2, 2014 | 09:39 AM
  #116
2012 C250 Coupe interior dome lights
Thanks in advance!
-Kerry-
SORRY FOR THE DUPLICATE POST
Old Mar 1, 2015 | 05:47 AM
  #117
reneftw's Avatar
W204 C200 CDI 2009
Hi guys. As I didn't find any information on this, if the interior lights are replaced with leds, does the dimming efect remain?
Old Mar 12, 2015 | 12:20 AM
  #118
rookiezxc's Avatar
2013 C250
I'd like to know on this as well!!
Also, do you guys mind to post pictures? I want to see the differences
Old Mar 12, 2015 | 02:15 AM
  #119
AZN Optics's Avatar
Due to digital nature of LEDs, you'll be hard pressed to find dimming LEDs for this application. LEDs simulate dimming by having multiple discrete steps in lumen. Vast majority of LEDs are single step though with a single on and off. Our LEDs are 2 step with a torch mode and ambient mode which works great in spots like footwell where you need that ambient setting while driving.
Old Jul 21, 2015 | 01:06 PM
  #120
deeepsix's Avatar
2009 C63
if you need any help
i know this thread is old....but i just replaced all mine in about ten minutes using a combination of all the tips in here. if anyone is having any trouble with removing the dome light assemblies or deck lid housing...i'd be glad to help
Old Aug 3, 2015 | 10:11 AM
  #121
kenju4u's Avatar
2013 C300 4MATIC Sport with P1, Bi-Xenon headlights, Navigation with backup camera, Sport Plus
How did you remove the map lights under the rear view mirror? I need to swap those out and i see a little notch in the frosted glass. There is also a mark on near it which says "L and R". Not sure how they pop off and I dont want to damage anything. Good instructions would be very helpful!
Ken
Old Aug 3, 2015 | 10:19 AM
  #122
deeepsix's Avatar
2009 C63
ken - are your map lights out or you're just wanting to swap them? i did not change those, i think they're already LED, or at least they match the color of the rest of the lights now. i will look at mine in a bit and let you know if i can pop the covers off.
Old Aug 3, 2015 | 10:32 AM
  #123
kenju4u's Avatar
Map lights are working but they are not LED's. My 2010 C were LEDs when I bought the car but my 2013 are halogen. I swapped out everything except the map lights and the dim "night light" under the rear view mirror.
Old Aug 3, 2015 | 10:39 AM
  #124
deeepsix's Avatar
2009 C63
ken - do you have the homelink mirror? i just looked at mine, assuming it's the same, the lens in the center shows 5 "tabs" you can see through. i would use a small pick or try a credit card to pop the long edge out first. i can see the bulbs through the lens and i assume they pop right out once the lens is off
Old Aug 3, 2015 | 11:06 AM
  #125
kenju4u's Avatar
Yes I have the homelink mirror without the compass. Not sure what you mean by 5 tabs. The plastic lens for the map lights are small 1/2 inch circular. Think I only see one or two little notches in it where something can be inserted to pop it out.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
