Old Jun 9, 2015, 04:48 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
DIY: Interior light removal
Old Aug 3, 2015 | 11:35 AM
  #126
deeepsix's Avatar
2009 C63
Originally Posted by kenju4u
Yes I have the homelink mirror without the compass. Not sure what you mean by 5 tabs. The plastic lens for the map lights are small 1/2 inch circular. Think I only see one or two little notches in it where something can be inserted to pop it out.
mirror must be different. here's what mine looks like.
Attached Thumbnails DIY: Interior light removal-img_5571.jpg   DIY: Interior light removal-img_5572.jpg
Old Aug 3, 2015 | 11:52 AM
  #127
kenju4u's Avatar
2013 C300 4MATIC Sport with P1, Bi-Xenon headlights, Navigation with backup camera, Sport Plus
Yeah its different. I'll take a pic of mine soon and see if i can pop out the lens.
Old Aug 3, 2015 | 12:45 PM
  #128
kenju4u's Avatar
This is what my map lights looks likes. Any idea how to remove those covers? I tried turning them which i was able to do from L to R position but then not able to pop them out. Tried pushing in as well as pulling them out.
Afraid of breaking the glass or worst damaging the unit.
2013 C300 Map lights
Old Aug 3, 2015 | 12:48 PM
  #129
deeepsix's Avatar
2009 C63
i would assume R and L are 'release' and 'lock' maybe?? i would twist and then try to pop them out using the notch. being that small i would think you could give it to them pretty good without them breaking. again, i'd use a small pick if you have one to try and get behind those notches.
keep us posted
Old Aug 3, 2015 | 12:52 PM
  #130
kenju4u's Avatar
Yeah I thats what I figured about the R and L but man I was hoping the cover would just fall down when its on R. Its not even budging...guess i'll try the pick and see what happens.
Old Aug 3, 2015 | 03:33 PM
  #131
kenju4u's Avatar
Cant do it...looks like the covers edge extends beyond the hole on the rearview mirror. No idea how this is suppose to be removed.
Old Aug 3, 2015 | 03:35 PM
  #132
deeepsix's Avatar
2009 C63
bummer. i did some searching....best i found was people taking the front of the mirror off (???) i guess the front/glass "snaps" off and you can get to them from inside
Old Aug 3, 2015 | 03:37 PM
  #133
kenju4u's Avatar
humm sounds risky. I can easily see myself breaking the mirror or scratching it while trying to take it off. Probably not worth the effort unless someone knows a way to get to it from the bottom. You would think it should be possible since the cover has notches to turn it in for some reason....
Old Aug 3, 2015 | 04:20 PM
  #134
AZN Optics's Avatar
SPONSOR/MBworld Guru
Yeah, you have to take apart the mirror to gain access. First gen w204 (rectangular shape) had had an easy exterior clip that popped open to remove.
Old Aug 3, 2015 | 04:32 PM
  #135
kenju4u's Avatar
Bummer, thanks for confirming.
Old Nov 5, 2015 | 11:12 AM
  #136
Andr3s's Avatar
2011 Mercedes c300 4matic
Did anyone find a way to remove those circle covers?
Old Mar 24, 2016 | 06:50 PM
  #137
Jimmy Brown's Avatar
2012 Mercedes Benz GLK350 4 Matic
I am very interested to know that as well.
Old Jul 28, 2016 | 07:52 PM
  #138
Nicoreyes's Avatar
2010 W204 C300
Originally Posted by got_thang?
Rear trunk light
Pry cover change bulb and put back together
Sorry if I left out any steps or pictures but this diy isn't as great as my others
This DIY was awesome! by any chance would you happen to know how to replace the lights in the rear view mirror?? I have the 2010 C without homelink, I'm guessing I have to take apart the mirror? Idk, how would I do this?
Old Jul 28, 2016 | 08:01 PM
  #139
deeepsix's Avatar
2009 C63
if you have an interior panel tool set (the 'plastic' blades in different shapes/sizes) you can "pop" the glass off if you work your way around. sounds more daunting than it really is. i recommend the trim tools because its easier to not damage/scratch the mirror/housing.
Old Jul 28, 2016 | 08:23 PM
  #140
Nicoreyes's Avatar
2010 W204 C300
Sounds pretty daunting lol but I'll give it a try, thanks!
Old Jul 28, 2016 | 10:08 PM
  #141
deeepsix's Avatar
2009 C63
Haha go slow, find the 'clips'. Once you get it started it will make a million times more sense!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
