Help - Foggy Exterior Front Windshield
I just picked up my 2008 C300 4Matic a few weeks ago. Ever since I had it, the front exterior windshield is constantly fogging up. It starts small at the bottom of the windshield near the wipers and slowly creeps up. I've tried everything: various a/c settings, de-fog button, closing the a/c vents ect...and nothing seems to help. It really frustrating and annoying.
I live in Toronto and I guess its humid this time of year but still. This is a $50,000 car and all my previous Fords and Subarus that were cheaper didn't have this problem.
Anyone else experiencing this? If so, any solutions? Can the dealer help?
Your advice would be really appreciated.
Thank You
i have the same problem too , until now i just have to keep cleaning it
Thank You
wipers
Can anyone else help other than the two above who didn't help at all?
since you're so well mannered i googled windshield condensation for you and here is the FIRST link that popped up.
- It's too hot and humid outside the automobile, and you have your air conditioning (or 'defroster')* running at a very cold temperature. In this instance, the water vapor is accumulating on the outside of the glass, because the interior of your car is very cool, relative to the outside temperature. Water vapor condenses on cold surfaces.
One common mistake in windshield-defogging is the belief that there is something wrong with the windshield defroster. There's not. The problem is you. I'm sorry, but I'm just being honest. You turn it on at full blast set for the coldest temperature (or the hottest temperature), and then get all pissed off when, after about thirty seconds of blissfully clear glass, you are dismayed at new formations of condensate. You give up, thinking your defroster is not working. But you just didn't give it the right instructions, that's all.
The first line of defense should always be fresh air. Very often, fresh air, either let in through the windows or the vents, can eliminate condensation without the need for a 'formal' defrosting process. But sometimes this won't work; if it's raining; if you're particularly sweaty; if it's particularly humid outside; or if it's too cold outside to roll down the windows.
In the event that fresh air does not work, (and for both scenarios above), you must attempt to minimize the difference in temperature between the two sides of the glass. Follow this process:
Turn on your car's defroster (and if that does not automatically engage the air conditioning, if you have one, turn on the air conditioning too). This applies in any weather. The 'air conditioning' involves a dehumidifying process which is very helpful at windshield defrosting. If you don't have air conditioning, but rather, just a fan vent pointed at the windsheild, turn that on instead.
Now, the most important step: Find the right temperature! If it's hot outside, start with the temperature adjusted to the hottest setting until all of the fog disappears from the glass. Then, slowly begin moving it to colder and colder settings until you see the first hint of frost beginning to form on the windshield again. Immediately turn the temperature back ever-so-slightly warmer, and you should have found the equilibrium point. If it's cold outside, you'll want to do the opposite: Start with the temperature as cold as possible until all of the frost disappears, and then immediately begin adjusting the temperature warmer and warmer, until the first signs of condensation reappear.
Thank You
The only other exterior source of vapor would be the cabin air intake which is under the right side wiper blade. The next time this occurs, you might stop and check the plastic grille over the intake for dampness. Of course, air is always flowing into that intake, except when the recirculate button has been pushed.
