Service Bulletin #: 2008020003 Ignition Switch
Service Bulletin #: P-B-32.25/63 for Suspension
Service Bulletin #: 2007110003
IPOD AMP Here's the Bulletin: B-P-82.85/597
Part installed: 204-870-39-94
RECALL Mfg Campaign Number: 2008 070001
MB DTB Star bulletin and the order number is P-B-82.70/61d dated August 11, 2008 which supersedes P-B-82.70/61c dated July 28, 2008
SUBJECT: Model 204.054/056/081
As of Model Year 2008 Equipped with COMAND Head Unit (Code 512, 527) Blue Tooth Hands-free Telephone conversation Choppy, Echo/Distortion detected especially by the land-line caller.
If you receive customer reports in the above model vehicles of the Blue-tooth telephone hands-free conversation audio quality being choppy, produces echo on both sides but especially detected by the landline, this may be due to a software error in the COMAND head unit and/or in the COMAND controller (A40/3). update the COMAND head unit software to version 46/07 using DAS 07/08 (or later) and SD Telematics Disc part number 204 827 53 59 (or newer) and update the software in the COMAND controller using DAS 07/08.
This COMAND update will add audio fade option in NAV mode, new icons and different looks when memory card is played.
Too bad that site you link doesn't go into more detail as to what the issues are.
I posted detailed information about the bluetooth problem two months ago...hopefully some of you found it useful then:
https://mbworld.org/forums/c-class-w...oth-sound.html
thanks for the other good info Moe!
When backing up and turning the steering wheel front strut bushings popping as per "P-B-33.15/20B". The torque arm bushings were replaced, and the noise is gone.
DTB was out since Nov, 08. But only apply up to 06/08 production date
SUBJECT:
Model 204.054/056/081, Up to 06/2008 Series Production
Brake Squeal and/or Excessive Brake Dust From Rear Axle
If you receive customer reports in the above model vehicles of brake squeal and or excessive brake dust from the rear axle, replace the rear brake pads with revised parts. Refer to WIS document AR42.10-P-0250CW.
Only first 12 months or 12000 miles will be covered.
Originally Posted by 6spdmanual
SUBJECT:
My Bluetooth is terrible. Much static and the other people on other end can barley hear me. I got my car in May 2008. So can I get this fixed?
Curious if you have to pay for labor on service bulletins?
ExploreQuote:
No, mine was fix for IPOD amp and COMAND update free of charge. I'm going to bring in again for rear brake dust and steering noise before 12K miles.Originally Posted by sonosuke
How can I tell if I have this unit:
Originally Posted by Hazemonster
DTB
Date:November 18, 2008
Order No.:P-B-42.20/101a
Supersedes:P-B-42.20/101 dated Nov. 5, 2008
Group:42
Revision History
Revision a
Date 11/18/08
Purpose Warranty Information Updated
11/5/08
Initial issue
SUBJECT:
Model 204.054/056/077/081
Squeaking/Grinding Noise from Rear Axle Area When Driving Without Brake Application
If you receive customer reports in the above model vehicles of a metal-to-metal squeaking/grinding noise from the area of rear axle when driving without brake application, perform the following.
Note: The cause may be the result of the stator clip that is fitted to stator support of the parking brake shoes. This clip prevents the brake shoes from contacting the aluminum wheel carrier. If the clip is installed incorrectly, it can move from the stator towards the brake disc and make contact. Witness marks can generally be seen on the stator clip when contact is present.
Replace the clip and slide it on only far enough so that the side tabs ( are flush with the stator towards the brake disc
Parts Information
Qty. 2
Part Name Plug stator support
Part Number A204 357 02 89
Note: The following allowable labor operations should be used when submitting a warranty claim for this repair. This information has been generated on November 18, 2008. Please refer to Netstar Star TekInfo Star Time for the most current labor time allowance.
In Case of Warranty
Operation: Wheels – two, R&R (40-1590)
Brake pads – rear, R&R/replace if required (wheels removed) (42-2851)
Brake discs – rear , $&R/replace if required (brake pads removed) (42-2881)
Parking brake shoes (with rear wheels removed), adjust (42-1302)
Damage Code Operation Number Time (hrs.) Model Indicator (s)
35470 36 40 1590 0.3 hrs. CA, CB, CC, CD
42 2851 0.5 hrs. CA, CB, CC, CD
42 2881 0.7 hrs. CA, CB, CC, CD
42 1302 0.3 hrs. CA, CB, CC, CD
P-B-42.20/101a (November 18, 2008)
DTB
Group:42
Revision History
Revision a
Date 11/18/08
11/5/08
Initial issue
SUBJECT:
Parts Information
Qty. 2
In Case of Warranty
Hello,Originally Posted by theinmoe
When backing up and turning the steering wheel front strut bushings popping as per "P-B-33.15/20B". The torque arm bushings were replaced, and the noise is gone.Originally Posted by akbro93704.
Is this a recall service bulletin? I always feel this when backing out from garage with wheel turn, should i bring this up with the mbz SA? should the repair/replace free? Thanks.
Yes, my car has same problem during reverse with steering turning to end, it makes knocking sound. It should cover under warrenty free of charge.
Quote:
Thanks. I will call the service and make an appointment. Originally Posted by theinmoe
Turning the heat on, no air flows through the vents at all for about 10-15 mins.
Originally Posted by Ted in Toronto
Fan is probably freezing up overnight, it is a known defect that only happens in extreme cold. The dealer repaired mine, warranty service order says "referred to TIPS document #LI83.00-P-04349". They installed covering # 204-830-27-13, 4 rivets 000-990-46-92.
http://www.benzworld.org/forums/w204...ot-coming.html
MB has new cable replace under warrenty for IPOD 4 gen not charging issue.
Originally Posted by Mr_Slugger.
http://www.benzworld.org/forums/w204...al-update.html
