SIRIUS signal
SIRIUS signal
I've had my C300 Sport about 6 weeks and I love it. The sound system blows away my 2005 E500. But the SIRIUS signal cuts out frequently. Is this normal? I find it very annoying.
I have my car for 2 months already. I haven't even activate my SIRIUS radio yet. ha ha.
does the subscription go away if I don't activate it in a time period?
1 Post
'14 GLK250 Diesel
Sirius has had signal problems on and off for the past 6 months or so.
A year ago, when we bought our C300 and immediately left on a long road trip, we went 4 weeks without any signal problems [except where you would expect them - deep in a high forest, tunnels, canyons]. This year, on nearly every trip, we've gone through periods where there have been periodic dropouts.
Others have noticed, some have complained....as far as I know, Sirius has never acknowledged the problem. Clearly, one of their satellites is not as healthy as it should be, but they apparently don't want to say so out loud.
Probably blockage or signal fading...
The point here is that the range and angle from the satellite into you car's antenna pattern varies bury the orbital cycle. This means that the signal strength versus received noise is cyclical. Sometimes you will have a booming signal, and at other times it gets quite weak. You Sirius receiver is supposed to sense this and switchover to another other Sirius that has potential to get you a clean strong signal. By comparison XM radio uses satellites in geosynchronous orbits that are always at same range and angle above the horizon, but they have their own drawbacks.
Another factor, and more likely what you are encountering, is that these signals only travel in a straight line and do not bounce of structures very well. The signal gets absorbed and scattered by overpasses, bridges, tall buildings, etc. The usually result in a signal drop-out that last until the blockage is gone.
Finally location is important. Use this URL (http://www.peopleswireless.biz/sirasasecoma.html) to see visualizations of the Sirius coverage areas, relative signal strength, satellite orbits, and a few hints on how better antennas can compensate and improve your reception.
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
They dont want to say anything outloud unless its positive at this point
'08 C350
2015 Iridium Silver Luxury Edition C300 4Matic
I've had my 2008 C300 for a year. First 9 months without any problem. Then, around August, I've started having this problem too. It happens a few times every day. Dealer tested unit and found nothing wrong. It's probably Sirius, but they'll never admit it.
2014 E350 Coupe Steel Gray
Nope, they aren't admitting it because I called about the same thing and I was told that my antenna was probably loose. But in the same breath she said that a loose antenna was very "odd" in a "Mercedes" (as though no other ish goes wrong on this car!)
C300 Sport/Palladium Silver on Black/P2
1 Post
C-300, XC70, Wrangler
I lost 1 of those free months due to this. No great loss, and I did not renew at the end of the free period.
Not worth the monthly fee ..... IMO
I also has reception problems but gone now. You can reset / reboot the SAT radio - might help.
I love the SAT radio - saves me so much time I used to spend finding new content for my I-POD (hardly use it anymore).
Can't remember exactly, but may be the manual might have the procedure.
I think I cycled through the radio freq via button on dash to SAT, then cycled through sub-menu via joystick and pressed when on the menu's "reset". I think it's in the same menu used to find the Sirius ID number.
Worked a couple of times, then the reception cleared up after they got their sat issues sorted - never to reappear again.
I like Sirius so much I bough a receiver for my home, the hardware was free as I rec'd $50 gas card, then I signed up for a year and got another $50 gas card.
It's plaing now on Area 38, as I write.
