iphone
2nd option is what i did...loaded my 10-15 most used numbers with friends phone, i didnt want every number (over 100) loaded in my car
Once loaded the iPhone works great!
also to previous post without MM i don't think you can manually enter entries....at least i could not figure it out
MM Package is "Multimedia Package"?
This package have a Flash Card interface?
I dont send the contacts with my MB using iPhone.
Is right, BT of iPhone works with voice, but not with data.
And have another detail: Dont work with stereo earphone.
iPhone is this, beautiful but ordinary...
Dont worry.
I have one too.
Tks4All
You can add the numbers to the car manually. I do not know the exact method off hand but its for sure easy to do.
I will be in the same situation when/if my car arrives.
I used my roommates phone loaded 10 numbers into car...turned off his phone, turned my bluetooth on and when i went to phonebook they just showed up....the car only has 1 phonebook
Thanks for you response..
The phone did sync(read) , I had all the list on command, and after? what to do to add them to the car?
Even on voice calls it is not clear when you put the call through the car. I'm not sure if that the problem is with just me.
But when I bluetooth my Nokia phone to the car, everything is perfect.
1. First, take note of what your voicemail number is with your current provider (for example, in Spain the Vodafone voicemail number is 177).
2. Click on the phone button in your iPhone.
3. Click on the keypad tab.
4. Tap the following code:
*5005*86*xxx#
The xxx is the voicemail number, in our example it will read: *5005*86*177#
5. Tap call.
6. After a second, the code will have been set.
7. Tap now on the voicemail button and it will automatically call your usual voicemail service.
doesn't work bro
or do i need to process it or sth?
i just got a loaner car from my dealership
is a 2010 b200
i am pretty pissed now as i see
i got an iphone
and you know what
i can get all my contacts in and i can't on my C Class
If you need help on how to it drop me an email, I'll run you thru it, Good Luck.
