Finally! Got My C63 Grille Installed & Car Lowered
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
is it required to do an alignment after installing springs???
If so, how much does it usually cost in addition to installation, and do you have to get it done at the dealer for best results?
if I can barely clear (by about a half inchto 3/4 " max) parking stops with the stock suspension...
then I assume that there is NO WAY in heck that with Eibach's you will still be able to clear parking stops..
Guess it just means you always have to stress and be careful when parking...
Anybody have any comments from experience that say different?
2010 Prius & Miata MX5 PRHT, 2010 Toyota Venza AWD, 05 C55 AMG, Yamaha 1100 Custom, Honda 250 Reflex
Sorry I don't have any pictures, but nowadays I always stop short of the parking stops. Scraped a couple of bumpers before, so I am extra careful.
MBworld Guru
white and whiter
true and exactly what I do, but family members will occasionally drive this car as well. modding decision will be based on how others can drive this car. we'll see.
#33
mercedes c230 w204 2009
im digging the drop of the car, but still needs 1 more inch of a drop, then you should not get the CF door panels but get C63 CF difusser and the brabus CF mirror covers, no need to change the rims though, just needs a more fierce look. LOWER IT MORE.. looks great enjoy ur ride
#35
Took my car in to Garage 5 to have them install the Eibach Pro-Kit springs & C63 style Grille last Friday. Am quite happy with the outcome and the ride is still very comfortable.
The car came with the 4 dot rear spring shims (19mm), so I brought along the 9mm and 5mm shims, but it was not necessary after all.
Here's another phoyo of the C63 style grille from Madracer.
Hope you guys like it.
#36
I could still drop the back by another 10mm (shim with 2 dots) or 14mm (shim with 1 dot), but elected to have a slight rake instead and used the original 4-dot shim that the factory had installed on the car. There are actually 4 different shim thickness that is available at the dealership (19mm/17mm/9mm/5mm).
#37
mercedes c200k w204
just a suggestion, paint headlights inside housing black.(like C63) then it will look fierce..enjoy your ride!
#38
Yes, just the Eibach Pro-Kit with the optional 18" double-spoke AMG wheels that we ordered with the C350 Sports .
so i just tell them to install the springs and keep the stock shims than??
#40
#41
OK...sorry to be a hater...but you spent almost $400 for something that barely makes any difference in my opinion. Of course...everyone is certainly entitled to do what they want..but looking at the pictures..there isn't much difference. You also paid $$ to compromise the "factory" ride...which could be better...but might be worse.
If you are happy with it...that's all that matters...but I never understood why people want to lower the car...and only 1/2"....hardly noticeable for $400 spent
#42
and it improves the ride and handling...
just look at the numbers from the eichbach sites..
check out the results of the pro kit on other cars...
#43
...."Father, forgive them for those who know not what they do or say".
Eibach is known to be the best replacement for OEM springs for people who do not want a drastic drop or too much deterioration in comfort, yet give a noticeable improvement in handling.
Remember, different strokes for different folks. The line that divides the sublime and ridiculous is a very thin line.
Thanks for the support rb23lb.
#44
X3 and 2012 C coming soon
It looks just right now. One of the first things I thought when I got mine was, it needs to be about 1/2 inch lower. In-person, 1/2 makes a nice subtle difference in appearance. Not everyone wants the dumped on 22s look. When I get my springs done, I am placing 10mm spacers on the rear wheels as well. They will be subtle differences that may make other enthusiasts take a second look. Oh, the springs and spacers do improve handling.
#45
I think I clearly stated...if you like it..that's all that matters.
And derspeed..if you want to pay $575 for 1/2" of difference...then that is your choice. If you say it improves performance and handling..then more power to you. I don't race my benz...so I wouldn't appreciate that difference..but AGAIN...if it makes you happy..then no one can argue with that.
#46
MBworld Guru
white and whiter
#47
#48
