Which kit is better performance wise and looks wise? Eibach Pro Kit or HR Supr Sport?
Old Sep 8, 2008 | 03:44 AM
rb23lb's Avatar
LOADED 08' C350 & 14' GLK-350 Diamond White (P1, MM, AMG Pkg, Ln Trkng, Htd Sts, Keylss Go)
Really thinking about getting some lowering springs now after seeing the latest members post!
I love how it closed the wheel gap nicely with the eibach pro kit...
Are there any negatives (other than potential scraping) from installing either of these springs?
Performance and looks increases seems to good to be true with no side effects!
Old Sep 8, 2008 | 09:34 AM
yxc145's Avatar
2004 E320, 2006 Audi A6, 2008 C350 W204, 2010 BMW F10, 2012 Porsche Carrera S 991, 2014 E350 W212
they are 2 different drops. Eibach only drops about 1.2". While Super Sport drops 1.7" and 1.8". Of course super sport will much nicer. it will only leave about 1/2 finger gap.
if you don't want to lower it that much, than you should compare Eibach to the H&R sports spring. it also drops 1.2".
Old Sep 8, 2008 | 11:31 AM
rb23lb's Avatar
thanks for your response.... but ok, other than the drop height, are there any differences performance-wise? like what about MPG increases or decreases?
Or what about 0-60 speed increases, or what about speed in the slalom and stuff like that?
Old Sep 8, 2008 | 12:01 PM
yxc145's Avatar
I don't know about making the car faster or better MPG. But it makes it handle a lot better.
Old Sep 8, 2008 | 12:06 PM
Azn_C300's Avatar
Mercedes C300 Sport, BMW 745Li, VW Mk6 Golf TDI
springs won't give you better mpg They're a suspension component, so it's more comfort and stability, than performance. Get the super sports, you won't regret it. And if you ever do, I'll swap you my sports :p
Old Sep 8, 2008 | 12:26 PM
rb23lb's Avatar
better MPG and performance from eichbach springs on some cars
the eihbach website quotes better performance numbers for these certain sedans after putting on the spring kits... that is why i asked... if they improve numbers for a honda accord, then why not the w204???
check this link - better MPG and performance for a honda accord and ford f-150 with the eibach pro kit installed:
http://eibach.com/cgi-bin/start.exe/...try=y&thid=122
Old Sep 8, 2008 | 12:34 PM
Azn_C300's Avatar
ok, I see what they're getting at, but some of that data will work for all springs regardless of brand....like since these are all lowering springs, car should have less aero drag due to lower profile...but that's true for all cars that are lowered...if anything, the H&R super sports should be even better since you're going lower than regular eibachs. Either way, all these are too minor to notice imo, especially with everyday normal driving.
Old Sep 8, 2008 | 01:58 PM
rb23lb's Avatar
right, probably too hard to notice...
so from your H & R sports, did you notice a harsher ride? a less uncomfortable ride? a more grounded, aggresive ride?
Does it mess up your gear box or drive train or anything since the engine was desgined for the car to be driven at a certain height?
does it void the manufacturer's warranty if you go really low, like with super sports?
Old Sep 8, 2008 | 02:20 PM
CinOttawa's Avatar
2008 G35x
I am pretty sure that such components have nothing to do with warranty...
on the negative side, i do hear that lowering springs, for some reason tend to make your tires wear out faster....I tend think that it has more to do with the driver and his new found 'handling' than the springs themselves.
Old Sep 8, 2008 | 02:30 PM
benggolf's Avatar
2010 Prius & Miata MX5 PRHT, 2010 Toyota Venza AWD, 05 C55 AMG, Yamaha 1100 Custom, Honda 250 Reflex
Take the change in driving habits aside, the only way lowering springs will affect tire wear is when you don't check your alignment after a spring swap.
Old Sep 8, 2008 | 02:40 PM
Azn_C300's Avatar
ride quality felt about the same. a little stiffer, but not by much.
