Back up camera
Rating: Thread Rating: 2 votes, 4.00 average.
Old 10-04-2008, 09:33 PM
theinmoe's Avatar
C350
Back up camera
From hidden engineering menu, back up camera option can be activated. Just need a camera to work I guess.
In Mitsubishi forum has same mod with the pictures of back connections to the head unit.
Link
Old 10-04-2008, 09:37 PM
Flame3g's Avatar
CLK500 SPORT
HOW DO U GET TO THAT MENU
Old 10-04-2008, 09:43 PM
theinmoe's Avatar
C350
At center command, press and hold 3 buttons, " hang up , 1 and #. You will see Eng menu in LCD. Go to (option 7, sub menu 7) HU parameter and enable backup camera install.
Old 10-04-2008, 10:01 PM
Flame3g's Avatar
CLK500 SPORT
is this the same for the non mm screens
Old 10-04-2008, 10:27 PM
theinmoe's Avatar
C350
Eng menu works for both MM and Non MM. Not sure about back up camera display on non MM screen.
Old 10-05-2008, 11:10 PM
Shodan01's Avatar
2012 CLS 63 AMG
Has anybody tried connecting a camera to this? Where would it attach?
Old 10-05-2008, 11:13 PM
micropower99's Avatar
2008 Mercedes C300 4Matic
Read the link in the first post.
Old 10-05-2008, 11:35 PM
XtinaNoel's Avatar
09 white c63
i dont have that back up camera option in mine
Old 10-06-2008, 12:17 AM
white46's Avatar
08 C300
ok, i was playing with this menu and got to software update section.
after I went in there, this message poped up and can not get out from it.
anybody know how?????
please don't tell me i need to bring the car to dealer.
Old 10-06-2008, 10:24 AM
theinmoe's Avatar
C350
It did that to me couple of times, at SW update menu when you pull down common knob. I did the following to clear this. Eject the CD, hit clr key beside common knob. Re insert the CD and during loading hit clr and press command knob many times. Abort icon will highlight and you can exit from there. I warned this on the other post not try SW update.
Old 10-06-2008, 10:45 AM
theinmoe's Avatar
C350
Following link shows how to install backup camera.
Link
It should connect to the back of head unit. There are some empty connector slot at the back of the head unit. I also want to know pin out of these empty connectors. Video AUX is another option that is available which can be used for low light or night vision camera installed infront of the car. This head unit is manufactured by Mitsubishi MELCO. There are some software CD patch for VIM different model head unit from MELCO.
Link
link
Old 10-06-2008, 05:23 PM
white46's Avatar
08 C300
thank you very much for your help. it's working now.
btw, just sent you PM.
Old 10-07-2008, 09:27 PM
Shodan01's Avatar
2012 CLS 63 AMG
The links use midcity chip correct? I was just curious if the input was already there and if there was a plug and play version?
I do like the VIM available from Midcity, but stile unsure what I want to do.
Old 10-07-2008, 11:35 PM
theinmoe's Avatar
C350
No, this is activated just from eng menu, without the chip. You can try it now. When you reverse, you will see this screen. We dont know about plug and play yet. Green FAKRA connector at the back of head unit is for video input. white46 will try this weekend with a camera.
Old 10-08-2008, 04:36 AM
lx Raven xl's Avatar
C180K 2011 COMAND, AMG, Dynamic Xenon, Business Pack, H&K Audio and +
I changed the Reverse Camera to "Installed" and Video AUX to "ON" in the menu. Now I when switch to reverse gear in the automatic gearbox , the blank screen with message " Check your entire surroundings" did not appear. Anything more needs to be done?
Old 10-08-2008, 11:48 AM
Misiek4's Avatar
C63
Hi !
Could anyone let me know which connector is proper to attach the backup camera ?
Regards
Misiek4
Old 10-08-2008, 12:08 PM
I got it to display the blank screen. After the change to "installed" . you have to get the key out and wait for maybe 5 mins or so. And then start the car and it will work once you change the gear to reserve.
After changing the Reverse Camera to "installed" I went back to my desk. When i finished working and get back to my car and started it the Blank screen for reverse camera was working.
Now the question is . is it plug and play?
Old 10-08-2008, 12:18 PM
white46's Avatar
08 C300
Originally Posted by Misiek4
Hi !
Regards
Misiek4
I'm not sure which connector is which. It is FAKRA connector behind the navi, also not sure whether it's male or female. Since I have both connectors we will see this weekend when I try to hook it up with AUX video input.
it should be plug and play. we will see after this weekend.
Old 10-08-2008, 12:36 PM
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
I hope all your work turns out guys. This would be a great mod for the whole w204 community and if you can pull it off you deserve our praise.
Old 10-08-2008, 01:06 PM
Misiek4's Avatar
C63
Don't forget to let us know.
Old 10-08-2008, 01:08 PM
Bokx_350's Avatar
C350
Wow. Nice. Now I REALLY regret not getting the navi
Old 10-08-2008, 01:20 PM
Devastator187's Avatar
2008 Sport C-300, 2003 Accord Coupe V6
Do you think this camera would work with our screen, for non MM? Wireless cam, no wiring.
http://www.costco.com/Browse/Product...=0F&lang=en-US
Old 10-09-2008, 09:54 PM
white46's Avatar
08 C300
for the moment of truth.
BWAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
I'M SO GETTING REAR-VIEW CAMERA NOW!!!
or...
maybe...
carputer?
cost so far, $10 + camera cost around $150. so in total, less than $200 for the rear-view camera. i also can add rca input select for extra $20 and i'll have extra aux input in glove box.
can not get any better than this.
Old 10-09-2008, 10:45 PM
Sweet! How'd you do that?
Old 10-10-2008, 12:05 AM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
I wanna do a PS3 but who knows where to fit the damn thing!
BLUE RAY PLAYER!
You have already rated this thread Rating: Thread Rating: 2 votes, 4.00 average.
Quick Reply: Back up camera
