VIM/Backup Cam Mid City
Old Oct 13, 2008 | 09:16 PM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
here are some pics that show another way to hook up the camera wires. doing it this way eliminates the need for the extra rca cable. It involves running the provided 18 ft camera wire all the way forward to the center console. (e.g. run the wire forward so that the little metal box that comes with the camera sits behind the radio as well. you can then get power at the cigarette plug.
Attached Thumbnails VIM/Backup Cam Mid City-cam1.jpg   VIM/Backup Cam Mid City-cam2.jpg   VIM/Backup Cam Mid City-cam3.jpg   VIM/Backup Cam Mid City-cam4.jpg   VIM/Backup Cam Mid City-cam5.jpg
Old Oct 14, 2008 | 12:21 AM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
DOA
Originally Posted by SDGuy
Do you get a blank screen or does nothing happen when you put the car in Reverse? A bad camera wouldn't stop the VIM from doing the video switchover I would think.
Nothing happens on the screen when in reverse but since 12V & ground is present where & when required, some sort of signal should be sent forward to bring up the reverse screen even if the camera was dead.
Old Oct 14, 2008 | 12:23 AM
RLE's Avatar
RLE
Wrong 12V
12V from the cigarette lighter doesn't sync up with reverse so how is this useful?
Old Oct 14, 2008 | 01:31 AM
Rick Hunter's Avatar
'08 W204.081; M 272.948 KE30; Colour Code#792
Sounds like the programming hasn't been activated in COMAND yet. If it was activated you should have at least gotten a black screen with the "Check Surroundings" blurb on the display. The power to the camera itself does not trigger any changes to the system.
I'm assuming that in this case the power to the camera would always be on when your car is on. Only when you put it in reverse would your MM screen flip to aux video (as programmed into the COMAND system)and display the signal. Am I right?
I'm not sure I would have done it this way had I known about it. But one thing that is brilliant about this setup is that you can set your COMAND to display via "aux video" instead of "reverse input." You could then freely turn on/off your camera display without having to put your car in [R]everse. Your camera could be displayed while driving! Wouldn't that be an awesome "second rear view mirror?"
Old Oct 14, 2008 | 03:41 PM
RLE's Avatar
RLE
DOA
<<Sounds like the programming hasn't been activated in COMAND yet. If it was activated you should have at least gotten a black screen with the "Check Surroundings" blurb on the display. The power to the camera itself does not trigger any changes to the system.>>
I have not only activated it using the steering wheel buttons, on and off several times, but have also gone to the onscreen menu which shows "camera on" and have turned it off and on from there. Still nothing when shifting into reverse.
So your feeling is that before commencing any step of the installation, simply activating the feature will result in a black screen anytime the lever is in the reverse position, then?
Old Oct 14, 2008 | 04:00 PM
bigbodybeeenz's Avatar
bike
I had my Midcity system installed by a local shop in San Diego and it cost $800.
The shop is a little on the pricey side, but I'm willing to pay for quality work and they did a good job.
Old Oct 14, 2008 | 04:20 PM
  #32
SDGuy's Avatar
2000 CLK430 Cab - sold; 2009 C350 White with Mocha P2,MM,18" AMG,Pano roof
May I ask which shop? I'm in San Diego. Did they provide the Midcity kit as well?
Old Oct 14, 2008 | 04:54 PM
  #33
bike
No. I ordered the kit directly and just took it into the shop. They're called La Jolla Audio.
Old Oct 14, 2008 | 05:01 PM
  #34
SDGuy's Avatar
You are right, they are the most expensive and one of the best shops in town. Glad they did a good job for you.
Old Oct 14, 2008 | 06:40 PM
  #35
PREMIUM SPONSOR
ML350, Lotus Elise
The camera can actually be wired to ignition.. it does not have to turn off with reverse as the radio and module take care of turning the reverse screen on/off.
Old Oct 14, 2008 | 06:47 PM
  #36
PREMIUM SPONSOR
ML350, Lotus Elise
correct.. the the main reason to have the camera on all the time is to allow for on-demand usage. we have new firmware coming out soon that will allow you to select on-demand rear camera through the steering wheel controls so it changes in reverse as well as being selectable while in gear...
and yes even if the camera was not working you should still be seeing a blank screen with the caption "check surroundings" when you shift in reverse. if that is not happening then re-run programming (press send, end, and vol+ on the steering wheel all at the same time)
Old Oct 14, 2008 | 10:59 PM
  #37
Yup.
(above photo taken from theinmoe)
Holy S#!T I need to quit my dayjob... I could be making a killing for these installs
How can us early adopters weigh in on the firmware upgrade? Are we eligible for this upgrade? I think on-the-fly usage is an excellent idea.
Old Oct 14, 2008 | 11:19 PM
  #38
RLE's Avatar
RLE
No joy
<<So your feeling is that before commencing any step of the installation, simply activating the feature will result in a black screen anytime the lever is in the reverse position, then?>>
<<Yup.>>
Not only is it shown "installed and on" in the hidden menu, it is also shown now in the System menu on the screen which tells me that it is officially "on in R" but moving the lever to "R" has no effect.
It has to be something simple.
Old Oct 15, 2008 | 06:12 PM
  #39
PREMIUM SPONSOR
ML350, Lotus Elise
<<Yup.>>
go into the service screen (not the hidden menu) and make sure that 'on in Reverse' is checked. (e.g. you can check and uncheck the selection but it needs to be checked to work.)
Old Oct 15, 2008 | 06:14 PM
  #40
PREMIUM SPONSOR
ML350, Lotus Elise
our module firmware upgrades are always free... you just cover the shipping...
Old Oct 15, 2008 | 10:37 PM
  #41
RLE's Avatar
RLE
RIZ signal source??
That box is checked.
Here's a new thought. In the Engineering menu is a line designated 7.7 HU Parameters.
Scrolling to line 10, the line:
"RIZ Signal Source Reverse Gear" is grayed out.
Reviewing:
Activated by steering wheel buttons which activated "Diagnosis" and a restart.
Verified in the System menu "Camera installed."
In the engineering menu: "Rear view camera installed." (checked "ON".
There is an RIZ mentioned on another line but opening it led to nothing but I think that might be a clue.
There are a few reset possibilities but I'm not touching those without knowing what the result might be.
Old Oct 16, 2008 | 05:58 AM
  #42
PREMIUM SPONSOR
ML350, Lotus Elise
Reviewing:
no, the RIZ: reverse being greyed out is normal. there are a bunch of feature locked out even on the engineering menu.
lets verify this: on the engineering menu, you should have
3. rearview camera:installed
and also
5. video aux : off
also when you pressed the three buttons on the steering wheel (send,end,+) the screen should have read "diagnosis" for about a second, then the command restarts and the screen motorizes down and then up again...
Old Oct 23, 2008 | 01:19 PM
  #43
rolodoc's Avatar
2008 C300 Sport
SAFETY CONCERN
I'm interested in the VIM unit and understands that the VIM module disables the speed sensors in 3 different areas to make the car think it is not moving. Just wondering if using the VIM will interfere with any safety features of the car, such as airbag, ABS, Electronic Stability Control, Traction control, and other pre-collision safety features.
If the car's computer thinks it is not in motion, maybe some of these safety features will not be active when needed?
Old Oct 23, 2008 | 03:48 PM
  #44
mb_horseshoe's Avatar
2008 C300 Sport
+1... good question
Old Oct 23, 2008 | 04:02 PM
  #45
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Now will all this going into the engineering menu and turning on this or that option allow me to buy a camera, adaptor cable and install it without any other hardware?
Old Oct 23, 2008 | 04:12 PM
  #46
RLE's Avatar
RLE
VIM DISABLES....?
I'm wondering where you got this theory. It is certainly not true.
Old Oct 23, 2008 | 04:14 PM
  #47
RLE's Avatar
RLE
Installing
You will have to buy a 12 foot RCA cable which is not included. Ten dollars or less at Radio Shack.
Old Oct 23, 2008 | 04:35 PM
  #48
rolodoc's Avatar
2008 C300 Sport
This information was posted by rob13572468 from MidCity Engineering. His quote "on the W204 the video disable is keyed into three things: GPS signal, gearshift position, and wheel speed sensor. all three have to register that the car is sitting still or the video output is disabled. on mercedes, all the information runs over the CAN network. other vehicles have hard wired signals on individual wires and a common hack was to install a switch that would disconnect those wires (e.g. parking brake and speed sense signal are still common on some lexus models) but with mercedes there is no easy way. What the VIM module is actually doing is taking all the data over the network and then selectively changing certain data parameters to make only the radio think that the vehicle is sitting still when in fact it is moving. At the same time it also has to disconnect the GPS antenna when you select vim mode and it has to do all this reliably. there is actually about 8000 lines of code involved in making all this happen."
https://mbworld.org/forums/showthrea...t=#post3108207
So back to the same question: Does using the VIM module interfere with any of the safety features if the car computer thinks the car is not moving?
Old Oct 23, 2008 | 04:41 PM
  #49
white46's Avatar
08 C300
hang in there.
i'll write up rear-view camera for less than $200 diy this weekend.
Old Oct 23, 2008 | 06:29 PM
  #50
Ron Jr's Avatar
Originally Posted by white46
hang in there.
Thank you Sir, I will wait patiently for this. To bad next weekend is clean the garage weekend or I would be doing it then.
