DIY: Rear-View Camera under $200
Old 02-02-2010, 01:16 PM
  #51
dacatz's Avatar
Location: Richmond Hill - Markham area, Toronto, Canada
c63, prius
Originally Posted by white46
I am not sure what eu-40 is but, you can just purchase this which is pre-maid with RCA output. Just easier solution.
http://cgi.ebay.com/Radioa-Extension...item3a53d33a84
thx for the link.....can't wait to install the camera asap....btw for u guys (near socal area) if u want to order the backup camera, u can order thru this place
http://www.sonicelectronix.com
from my understanding....u can go there and p/u your order and they have great service....(45mins away from LA)
Old 02-02-2010, 05:22 PM
  #52
Ron Jr's Avatar
2013 C300 Sport Black Darth V3.0
Originally Posted by f8al
You guys are making this look too easy, I gave in and started ordering my parts today....
If you have installed an aftermarket stereo this should only take an hour. Very easy job the hardest part for me was getting the video lead from the trunk to the passenger compartment.
Old 02-02-2010, 05:44 PM
  #53
f8al's Avatar
2008 c300 [] 1969 Chevelle SS [] 2010 Camaro
There's a step about splicing a wire to the reverse lights to give the camera power, that I'm a little weary about. There isn't much detail for what seems to be the most crucial part. I'm thinking it will make more sense when I'm actually doing the install.
Old 02-03-2010, 05:59 AM
  #54
Sully's Avatar
W204 C180 / W176 A45
f8al, that step isn't as difficult as it seems. The easiest way that I've found is to strip back some of the insulation on the wire that you're splicing so as to have the copper exposed, but not broken. Wrap the bare wire that you're splicing onto this exposed piece of copper and tape the whole thing up. I've done this numerous time when splicing to factory wires.
Old 02-03-2010, 11:38 AM
  #55
f8al's Avatar
Thanks! I was picturing some wire nut splice configuration, but your suggestion makes a lot more sense.
Old 02-03-2010, 12:21 PM
  #56
Ron Jr's Avatar
Just go to Radio Shack and pick up a pack of these.
http://www.radioshack.com/product/in...ductId=2104093
Old 03-17-2010, 01:12 AM
  #57
dacatz's Avatar
c63, prius
just finish install the backup camera last week....all the instruction are
helpful...but i need to comment some more info because i have some area which i have trouble......Spec for my c63: APP (Canadian Version P30 w/lsd) Premium Package, Carbon Trim, Sat. radio, Keyless Go
1. My kenwood backup camera require Accessories wire (red) to hook up, and i spliced to a wire going to cig ligther fuse (Pink wire) (pics will provide later)
2. for the steering wheel control to activate the backup camera funtion for my Command system, it didn't work for me, therefore i access the engineering manual by pressing 1 , # and hang up key...then i goto menu 7.7.17 to turn the backup camera funtion on. But i don't know why there is 3 option to choose, so i try each one...none of them work,everytime when i put in reverse ,also even if i turn off the car and turn on right away, it still doesn't work. At last, I have figure it out!
To Turn on the backup camera function for the my kenwood camera, first go engineering menu 7.7.17 , then choose SRVC, next turn off the car, not sure if require to lock the door or not...but i locked the door....leave the car for 5 mins....then start the car, put in "R", the backup camera screen will be turn on.
Attached Thumbnails DIY: Rear-View Camera under 0-dsc04669.jpg   DIY: Rear-View Camera under 0-dsc04670.jpg
Old 03-17-2010, 01:23 AM
  #58
dacatz's Avatar
c63, prius
sorry, have to borrow the pics from the previous post!
I have spliced my acc wire from to this wire!
Note: spliced to red circle area!
Attached Thumbnails DIY: Rear-View Camera under 0-img_0104.jpg
Old 03-17-2010, 10:44 AM
  #59
white46's Avatar
08 C300
was that constant 12v? meaning goes on when the car is on and goes off with the car going off?
Old 03-18-2010, 01:07 AM
  #60
dacatz's Avatar
c63, prius
not constant 12v....that is ignition on and u will get 12v in that wire...
Old 05-26-2010, 12:13 PM
  #61
rst63's Avatar
C63
It might just be stupid me but let me get this strait. We need a FRAKA to RCA because FRAKA is need to connect to the back of COMMAND, and RCA is to the back up cam?
Also for the FRAKA to RCA adaptor should the RCA be male or female?
Old 05-26-2010, 03:37 PM
  #62
I am Jeff's Avatar
Steel Grey Metallic C63!!
Yes!
Female! :-P I hope this helps
Old 05-26-2010, 10:00 PM
  #63
rst63's Avatar
C63
Thanks alot! Also i noticed that for the camera, there is 3 connection or wires that should be connect. Ground, Power, and Reverse light. I understand where the ground should be connected but where do i connect the power and reverse? should both be connected to the reverse tail light?
Old 05-27-2010, 10:33 AM
  #64
I am Jeff's Avatar
Some people run the ACC wire all the way to the front to the cigarette lighter, but I preferred to keep it clean, so i kept it back there. I forgot which one I put it to, but I'll let u know later when I re adjust my camera either today or tomorrow. The reverse should be connected to the reverse lamp.
Old 05-27-2010, 02:16 PM
  #65
kevinwithdabenz's Avatar
08 c350
This is a little off topic from the OP, but i noticed that there is a Blue port for AUX audio. is that what is used if someone wanted to install a system with bass? or is that for ipod integration?
thanks.
Old 06-25-2010, 12:35 PM
  #66
blue00r6's Avatar
2017 C43
This fakra adapter.. can it be found at Radio shack? or... I just got my camera yesterday and want to do this tomorrow, not wait for an ebay cable!!
Old 06-25-2010, 03:42 PM
  #67
I am Jeff's Avatar
The radio shacks around me do not sell FAKRA adapter. I just bought mine from mid city engineering.
Old 06-25-2010, 03:46 PM
  #68
blue00r6's Avatar
2017 C43
Boo.. maybe i'll get lucky at a bigger electronics store...
Old 06-25-2010, 04:33 PM
  #69
blue00r6's Avatar
2017 C43
waiiiiiiiit.... I just bout the CMOS-200 will this one work??? i see the guys using CCD-2000... .. does it matter?
Old 06-25-2010, 11:13 PM
  #70
I am Jeff's Avatar
It doesn't matter. I tested both teh CMOS-200 and CCD-2000. Dont' ask why I bought two. lol :p
Old 06-26-2010, 01:11 AM
  #71
joshg1001's Avatar
2017 E300
what is the difference between the two?
Old 06-26-2010, 10:27 AM
  #72
Nuru's Avatar
S350 BT 4MATIC
Originally Posted by na011
You need to use MS Internet Explorer Browser. When I use Google Chrome or Mozilla Firefox browser I also have the "red x".
My Firefox works fine, no issues.
Old 06-27-2010, 11:05 PM
  #73
I am Jeff's Avatar
On paper, slightly better resolution and better viewing angle. But on the screen, basically same thing.
Old 06-28-2010, 12:21 AM
  #74
joshg1001's Avatar
2017 E300
which one is the better one?
Old 06-28-2010, 12:27 AM
  #75
absolutleo's Avatar
c300
how are you all snaking the rca cable from rear to front? is taking the interior trim/carpeting apart required?
Quick Reply: DIY: Rear-View Camera under $200
