Old Jun 4, 2015, 06:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
Print Wikipost
Jacking points conpatability pieces.
Old Nov 21, 2008 | 02:39 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
Someone earlier on this forum mentioned that they had manufactured four jacking point pieces that made their lifting trolley ? jack compatable with their C Class jacking points. I cannot seem to find the post so would be grateful it they could post again with all the details & perhaps the photo.
Old Nov 21, 2008 | 03:24 PM
BENZ LIFER's Avatar
2009 C300 SPORT 1999 CLK320
TRY:
http://www.reverselogic.us/jackpad.html
Have seen a little cheaper on ebay.
Just keep an eye out it will pop up again under w204.
Old Nov 21, 2008 | 03:57 PM
flagman's Avatar
2016 C450 AMG, 2012 C350 4Matic Sport
Maybe a dumb question, but why is such a device required? How is MB's jack design different from other vehicles?
Old Nov 21, 2008 | 04:28 PM
BENZ LIFER's Avatar
Problem with floor jack if doing work at home or independent shop .
See pix
http://www.reverselogic.us/jackpad_instructions.html
Old Nov 21, 2008 | 05:17 PM
Carsy's Avatar
Originally Posted by BENZ LIFER
TRY:
Benz Lifer, Exactly what I wanted. Thank you. Carsy.
Old Nov 21, 2008 | 06:18 PM
nyca's Avatar
I usually place a flat 1/2" thick stainless steel plate on top of my jack saddle before lifting. Are you telling me that the those tabs that protrude from the lifting point are too soft and will deform even against a flat plate? And that the only way to do this is to get one of these adpaters?
Old Nov 21, 2008 | 09:43 PM
Derspeed's Avatar
X3 and 2012 C coming soon
I have that item. It's a must.
Old Nov 22, 2008 | 06:55 PM
flagman's Avatar
See pix
"reverse Logic" certainly seems an apt decription - why have such a unique jacking point design? What happens when someone takes their car to an independent service garage? Doubtful that every garage has these adapter devices - so there must be a lot of damage lift points out there.
Must be MB attempt to keep everyone coming to the dealer for service...
Old Nov 23, 2008 | 03:47 AM
Carsy's Avatar
My jack cup is not compatable with the jack pads for sale on E bay so this afternoon I cut a jack pad out of a block of mild steel & welded it to my jack cup. It does the job.Photo attached.
Old Nov 23, 2008 | 07:47 PM
nyca's Avatar
where is the photo?
You have the ability to mill steel and weld at home?
Old Nov 25, 2008 | 04:13 AM
Carsy's Avatar
Originally Posted by nyca
where is the photo?
I will try again to attach the photo.
It was a matter of hacksawing , squaring up with a file then arc welding to the jack cup. Time 1.5 hours.
Old Mar 21, 2009 | 08:02 PM
Saks_C350_Sport's Avatar
CLS63
in my haste putting my front wheel back on a few days ago, I forgot my jack pad tool in the undercarriage of the car. I have driven HUNDREDS of miles since and was shocked to find it still locked into the car this afternoon. this and the wheel alignment tool should be in anyones truck that is a do-it-yourselfer.
Old Mar 21, 2009 | 08:39 PM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Am I missing something or is this a case of overengineering by MB? I have had 14 different vehicles in my life and this is a first for me...
Old Mar 21, 2009 | 10:32 PM
nyca's Avatar
Like everything else, its good and bad. With the proper jack or saddle adapter, the lift point is very stable and secure and if you use it properly, very safe and it won't damage anything.
On the flipside, you need the adapter and if you take the car to a shop other then the dealer, they can screw things up badly.
Old Mar 21, 2009 | 10:56 PM
Carsy's Avatar
I have modified my MB jack pad by simply cutting a wide V crossways so it will now fit my Peugeot 405 jack mounting. No probs in this garage!!
Old Mar 21, 2009 | 11:22 PM
RLE's Avatar
RLE
'08 C300 Lux Barolo Red Beige Leather P2 MM 18" wheels '84 944
No damage
The dealers use lifts with rubber pads. Your home hydraulic jack has only a steel cup which will damage the jackpoint. Ugly but not fatal. I don't have a W204 jackpad yet but here's another example, this one for a Porsche 911. It slides into the jack receiver and the rubber pad faces down. I have one of these things I need to sell because it is not made for my present car.
Old Mar 22, 2009 | 10:18 AM
jrct9454's Avatar
'14 GLK250 Diesel
I have four of the jackpads from Fred Gwinn [Reverse Logic] - in fact, he made his first W204 pads for me back in Aug of '07. Went to the trouble of going to his local dealer to do the measurements, sent me the first prototype, etc.
When the car is at home in the condo garage, it's usually jacked up at all four corners using cheap Wal-Mart floor jacks, and the pads from Fred. This prevents tire flat-spotting when it would otherwise sit for days at a time, which is often the case in the winter around here [we can walk to most everything we need, so the car only goes out when the weather's nice]. On our W203, I had used four small cut blocks of wood, which worked but eventually wore out - I contacted him about his product when it came time to do something for the new car.
After a recent tire rotation, I too drove off with the pads attached, drove for 15 miles, and returned home to discover them all there, still hanging on. After smacking my forehead, I silently thanked Fred for his design and workmanship.
Old Mar 22, 2009 | 06:16 PM
Derspeed's Avatar
As I stated months ago, the Fred Gwinn unit is great. I have two and I am getting two more for when the car goes to the non-MB shop. Plus I am supporting a local.
Old Jun 12, 2009 | 09:03 PM
paladiumonblack's Avatar
C300 4Matic with 18in AMG's
Where can I get such an item?
Old Jun 12, 2009 | 09:31 PM
Norm01's Avatar
2011 E550 Coupe
Old Jun 14, 2009 | 08:58 PM
Originally Posted by Norm01
Thanks, but this link does not work - that's why I was looking for help.
Old Jun 14, 2009 | 09:11 PM
C300Sport's Avatar
I havn't been able to get any of the links to work either so I just googled them...try this link:
http://www.reverselogic.us/ReverseLo.../Products.html
Old Jun 15, 2009 | 09:35 PM
Thanks - just ordered one for my c300 so I can easily change my AMG wheels in Summer.
Old Jun 15, 2009 | 09:40 PM
How local is "local"? Is he in the Fairlawn area of just a local member?
Old Jun 15, 2009 | 09:47 PM
moparrbust's Avatar
2005 Crossfire SRT-6
You can also just jack the car up from the center in front by using the engine cradle jacking point(lifts the front end evenly) or for the rear just put the jack under the rear differential(make sure not to jack up on the rear cover).
