Meisterschaft Exhaust - help
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I had the exhaust installed this weekend and my tips do not stick out past the rear diffuser like the stock exhaust. The exhaust sounds a little loud inside the car. Is this causing the sound inside the vehicle? Did anyone else have these issues and if so what did you do to modify/correct the situation?
My muffler guy is at a lost why the tips do not come out further past the rear diffuser.
Yeah it would be best to get the exhaust reinstalled. If not just extend the tips further out. Because your exhaust is escaping under your apron which cause drone which is annoying.
The drone is coming through from under the car and not because of the position of the outlets. Did you remove your resonator as well?
MBworld Guru
white and whiter
exhaust tips location has NOTHING to do with droning. the drone is created by the chamber design and the exhaust flow of the muffler. Nothing you can fix there if you haven't even taken off the resonator yet. If you don't like the drone, put the stock exhaust back OR you can try adding Dynamat to the wheel tub in the trunk. Meistershaft or Eisenhaus brand as I like to call it is a Titanium canister setup meaning thin metal walls for the canister and the tubes. It's suppose to be loud.
in order to adjust the tips you need to adjust the hanger, but judging from the pic you need to add a short section to the part you cut off from the original piping. if the hangers are all at the same location as before that's just how that setup will be.
I love the look of the connected tips (CL 63 style) and I was trying to be a little bit different from everyone and was not trying to look like a C63. My vehicle is going to be used on the company's website once I get the tips on the driver side corrected. Thanks for the compliments.
S204 C220 CDI, VW Scirocco III 1.4TSI 160
1 Post
'08 C 300 Sport, '01 SL 500 & '08 Nissan Frontier SE Crew Cab 4WD
-Ryan
A little too "trumpety" for my taste although not bad.
