How should I TINT my TAIL LIGHTS?
I'm looking to do that again actually...The photo attached is what it looked like.
What I did was basic...traced the light with a pencil and paper and then cut out the tint film accordingly, put windex on the light and placed it on the light
I wasnt sure whether the tint film would last because of the weather and the tint is for windows and that it usually inside...
What should I do? I heard tint spray is hard to remove
Please help!
1) use the tint spray again but tape off everything but the part u want tinted or take the tail lights out and then do it with taping.
2)use vinyl tint film , use a air squeegee thingy and remove the air bubbles.
3)professional tinting...
DRAWBACK: option 1 and 3 and probably gonna be unable to be undone. You could buy new taillights if you wanted.
2 might be the best. ebay or any vinyl supply retailer should be able to get you tinited transparent films....
just my $.02
http://www.lamin-x.com/product-p/mb226.htm
I'm really forward on getting the films.
Does it have to be a certain type?Can I just go to autozone or walmart and get some film?
Will it last well?
btw.. spray can be undone if you use something called "lens painter" ... basically you use isopropyl (rubbing alcohol) to take it off.. its basically a rattlecan.
http://www.k2motor.com/lenspainter.html
I own a graphics/plotter and i have the Vector file for the exact middle shape so a professional can cut it for you. You can go to your local graphics store and give them the file to cut it. Bring your own material though! Stickercity.com sells bulk-uncut sheets by the feet.
PM me if you would like the Vector File.
If a graphics shop tries to charge you for a setup fee, that is BS! All they have to do is put in the material, open the vector file, and cut it. They should only charge you to cut it. If they say otherwise, for instance: "we need to change the vector file to work with our software" thats BS! don't fall for it.
I would cut it for you guys but I dont have any smoke taillight film in stock and I dont think I'm aloud to sell on here with out being a sponsor.
. BTW- Smoked Vinyl and Smoked Protection Film are two DIFFERENT things.
Vinyl is 1mm (micro).
Smoked Protection Film is usually 17mm (micro) but there are some cheap companies making 8mm too.
learn to read. Vinyl has a general life of 2-4 years with a max of 7 years, thus painting is more durable. Then there's the added issue of film/vinyl is applies to the outside, and although this does protected the light housing, it does also expose it to scratches, chips, and all the other elements. With cheaper films you might find on ebay, there's a possibly of bubbling, cracking, peeling, and yellowing. Painting is on the inside and protected from those elements. Best would be painting, and using a clear protection film. And paint protection film can go down to 6mm (3M), which is what Nascar uses. JS Design Factory (http://www.jsdesignfactory.com/) runs their operation right out of our shop, so I know all the shortfalls of vinyl. Paint over vinyl. Paint vs Protection Film
Can make an argument either way.
http://cgi.ebay.com/ebaymotors/08-Me...3A1|240%3A1318
