- Mercedes-Mercedes-Benz C-Class: How to Change Your Oil
Step by step instructions for do-it-yourself repairs
Browse all: Engine Guides
DIY oil change, step by step, with pictures
This is exactly why I don't go to dealers for service. It's not their car, so they don't care. Plus, I might as well do it myself, learn about the car, and save money. Not to mention that my engine bay isn't as filthy. Also, I seem to be missing the rear air filter clip that the 2011 has on my 2009... But I'm not shocked...
Early manuals 08, maybe 09, stated all took 8.5Q's.
Based on local MB dealer here, and your comment and other's, MB no longer treats diesel and gas engine oils differently, going back to an old, single oil philosopy. In this case ESP for all! M1 says it's good for both engines:
Mobil 1 ESP Formula M 5W-40 --- FOR ALL !!
The ESP UOA reports I've seen weren't very impressive.
-> Outstanding thermal and oxidation stability
-> Helps to reduce oil aging allowing extended drain interval protection
Date: May 24, 2011 11:16 AM...
Large orders are welcome and preferred !!
Thanks again for the order and spreading the word about our products !
Thanks,
Kevin McMurray
---- KevinK2 wrote:
> Kevin,
> I bought one from you and it works great. A few questions:
> 1) do you still sell it to individuals, ie just 1 unit?
> 2) I'm in a MB forum, I recomended this part in the "oil change" thread, but lately people say you don't return calls or emails.
> 3) would you sell lots of 10, 20, etc, to an independent mercedes shop?
Any ideas?
I just called their number, spoke to someone in sales and gave them my credit card number. Part came a week later. Works excellent.
Did you try calling a few times....I think I had to call twice to get someone on the line.
Will do. Thanks.
can't get provide any more info in my email than they asked:
We return all calls and emails provided they leave a name,call back #, and reason for the call. If they leave a message or email without that info we do not call back assuming it is a sales call.
I can get mine to suck as long as I'm pumping but I thought that once you got the oil flowing it would continue until it filled up the container.
At one time, I did overfill the MityVac and I think that's when my problem started.
Jabsco 12V or 120 volt bilge pumps. http://www.jabscoshop.com/
Nyca has a combo jabsco pump and oil container, but the pump is too small (4A) or too restricted at the connections to flow quickly.
I have a 12V 6amp bilge pump, currently used for a spare sump-pump back-up in the basement. Prior use was to evacuate oil at the turbo's oil outlet for a 924-Turbo track car.
I'm pretty sure that it over filled as oil was going into the top hose that goes to the valve.
But what you say about the connector makes a lot of sense. Mine is setup with the rubber reducer/connector and it may have been partially sucking air.
You said that you went to using a single hose. Will that larger hose go down the oil dipstick tube?????
Instead of pouring the oil out of the mityvac, I pumped it out using just the larger hose. It was a lot faster and didn't require all the pumping.
I am thinking of getting a longer hose and one that is a bit more flexible than the ones that come with the Mityvac.
. So next time, I think I'm just going to take the MityVac there and empty it out of the spout on top directly into the tank!! Heck, if I'm going to do it myself, I'm gonna do it MY WAY
so has anyone here actually tried draining the traditional way? I have a small ramp (9 inches high) I use for my e46 oil changes, but seems a bit small for the W204 C300 and I can't quite get in there and find the drain plug.
Can anyone help out?
Much much appreciated
for ten years in two MBs.
Yes, it does get it all out.
Thank you so much for your help in advance
Bobby
With that said, there is nothing wrong with draining the oil the old traditional way.
