- Mercedes-Mercedes-Benz C-Class: How to Change Your Oil
Step by step instructions for do-it-yourself repairs
Browse all: Engine Guides
DIY oil change, step by step, with pictures
Had to do that anyway before transporting the used oil to AutoZone.
Alternatively, Autozone has an instant $10 coupon for every 5 quarts you buy from them: http://www.mobiloil.com/USA-English/...t_AutoZone.pdf
My other question is what else will I need other than the oil and filter? I just want to make sure I have all my bases covered since I still have a few days to gather parts/supplies.
Thanks!
Other members purchased a metal adapter from some retaier ti believe its www.fluidevacuators.com.
And by theay, you don't have to stick the tube into the entire length of the dipstick tube. In fact, with the way I did it, the tube from the Vac went into the wide end of the rubber adapter, but it was not sticking out of the other side. So in reality, its actually sucking the oil to the top of the dipstick tube, through the adapter, then the tube, and into the MityVac.
I have found the MityVac to be a bit more time consuming than the traditional drain at the bottom process, and you'll have to pump it a few times to get all the oil out.... but all in all, it is cleaner, less hassle than lifting the car and slidng under, getting burned by that first gush of oil... Black fingernails...
You should browse through the entire thread. Yeah its long and sure the few a few posts you can skip over but in general, I found it useful.
IYE Does the dipstick reach far enough into the oil pan to get all of the oil, or would it be a good idea to add the extra bit of small tubing to get everything?
will read through the rest of the thread now.
1) Make sure you open up the engine oil fill cap - air promotes better flow
2) Makes sure where the 'suck' tubes enter the MityVac bin - that there is a tight seal
** sometimes because of gravity, it bends the tubes a bit away from the inlet thus loosening the seal there & causing no suckage.
You don't want to add the engine side plastic tubing, and absolutely not if you have a 4MATIC, as you will leave a quart or two behind.
BTW: *** All Members, please click on User CP at the top left of page, just below the thread title. Then add the following to either Profile and/or Signature , selecting buttons on the left side of that page: year, model, 4MATIC or RWD, and Location (city, state, and non-US/Canada country if needed. This helps response to issues, like tires. ***
& am able to get ~8.5 qts out.
Should I not expect the same process with my new GLK350/4?
Apparently the mercedes dealership way overfilled the oil. I mean, when I checked it I knew it read over the max, but I had no idea how much till today.
I used the method of pushing the rubber coupling into the dipstick and evac'ing the oil straight out the dipstick. It pulled out just a hair over 8L of oil before it started gurgling and sputtering. I pumped it up some more but it was basically sucking air.
After that happened curiosity got me and so I added the smaller piece of tubing to the coupling and pushed it down till I could feel/hear it hit the bottom of the oilpan. Then I pumped up the mityvac again and it started sucking oil again. Shortly after that oil filled up the whole mityvac so I had to stop and dispense some of the used oil into a gallon milk jug before I could continue.
All said and done I ended up with 6 full quarts of oil plus almost a full gallon jug. If my calculations are correct that's almost 10 quarts of oil?
8 of which I was able to pull out using the dealerships method of pulling from top of dipstick. The remaining oil came out via pusing the tube to bottom.
My best guess is that the dealership left roughly a half quart of oil in using their method of evacuating, and then added back in 8.5qts of new oil.
On a related now, wife just came back from a Service B. Again, the oil looks to be over the "max" on the dipstick. They charged her for 9 quarts of M1, even though the car only takes 7.4 qt. I might have to suck some out if she starts getting the dread "check oil level" message again. Ugh...
milk jug is a little less full than i thought but it has got to have at least 3.5qts if the jug holds 4 total.
It isn't a 4matic.
Kevink2, do you have a post you can reference for the 4Matic please. I am having a hard time visualizing this adapter method for the 4matics.
2 oil changes in 2 years tells me I am getting 8.5 qts out each time.
Wife gets up to go to work and cranks the car and it's making a chirping sound. Sounds like it's coming from the front of the motor but I didn't let her keep it running for long enough to be sure. Freaked me out a little. Oil level is fine, but I don't want her driving it anywhere without knowing for sure where the sound is coming from. The only thing I think it could be is that I sprayed some armorall on the plastic engine cover and maybe I got some on the belt? I hope that's it.
Adaptor pic, 1st description of AGB Method with rubber bushing at top
oil-change, dealer-method
More Adaptor and Mytivac details
Adaptor still available, how to order
from a C300 parts catalog:
Dipstick:
----- W/4-matic
----- W/o 4-matic
It's also common knowledge now (thanks to others, not me) that the
4-MATICS take 7.5Q's, while the RWD's take 8.5Q's . Dealers still overfill 4MATICS !
Dipstick:
----- W/4-matic
----- W/o 4-matic
Thank you!!
When HOT, suck one to 1.5 out, & check dipstick, not dash.
