Old Jun 10, 2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
DIY oil change, step by step, with pictures
Rating: Thread Rating: 11 votes, 4.27 average.
Old Mar 25, 2019 | 05:21 PM
  #551
AAIIIC's Avatar
2014 C250 Luxury
Originally Posted by C0d3Sp4c3
It is called 27mm socket.
I didn't have a big-*** socket handy, so I used a set of big-*** pliers. I didn't need much torque, just a bit more leverage to get it loose.
You got this too! I used Mann HU514Y but switched to the OEM for the first time after 6 oil change intervals. The OEM oil filter from the Dealer cost $32 after CA tax and guess what? There is no discernable difference between the OEM and Mann HU514Y that I could tell except for the price. Your call...
The Mann is under $9 from rockauto.com, seems like a no-brainer to go with that if it's identical to the OEM part for $30+!
Why? Install the new oil filter in place. Use a funnel to pour oil into the top of the engine and hand tighten the oil cap. Make sense?
You're exactly right - fill through the oil fill cap, not through the filter housing. I posted a few weeks after we actually did the oil change, and I was going off (apparently faulty ) memory; post edited above.
Old Jun 13, 2020 | 06:00 PM
  #552
Flame145's Avatar
2008 MB C350 Sport
I did my oil change today. The service indicator stated i was 110 days overdue. But I do not drive the car that much as I had another vehicle as my daily driver. I typically just reset the reminder and change by mileage numbers. Anyway I let the service reminder go 110 days before today's oil change and reset.
I don't know why but I go through the whole reset procedure and confirm at the end, and the computer says it is unable to confirm reset now. It will not reset.
Does anyone know why or how I fix this. Please help.
Thanks Bryan
Old Jun 15, 2020 | 12:13 PM
  #553
C0d3Sp4c3's Avatar
2013 C250
Thanks Bryan
If you confirmed the reset at the end and made an attempt to go over again then you will be prompted with "unable to confirm reset now". It's all good if you don't see the Service Minder when you first start the car until the next scheduled service interval.
You have already rated this thread Rating: Thread Rating: 11 votes, 4.27 average.
