Driver's Seat Noise: Fixed!
kinda sad that the first pictures i'm putting up on the forums is of when i'm trying to fix a noise problem. o well... now that me and my baby are through this together who knows... maybe it just made our relationship that much stronger. (yes, baby = my car)
ok, so i'm thinking that this noise problem was similar to if not the actual noise heard in this thread:
https://mbworld.org/forums/c-class-w...ing-noisy.html
idk if they actually are this same problem, but in case it might be, i'm posting this to give an idea of what i tried to do. if it's an issue at the plant where the car was assembled on a certain day or something, who knows. it could be something in not just my car.
my c300, less than a couple weeks old, had this strange noise coming from the driver's seat. i could hear it when i'm driving (and trust me, it was pretty loud. i would have people in my car tell me if they heard it to make sure i wasn't going crazy, and we all concluded that it was pretty darn loud). it sounded like a creaking noise, almost like a spring that was loose or metal parts shifting when the weight would shift. it would happen more during weight shifting (acceleration, braking, moving my *** around...). so i decided to try to see if i could fix it.
first, i needed to localize the sound. i found that i could easily replicate the sound when i got in the back seat by moving the seat back back and forth at a certain pressure. interestingly, it became worse (sound appeared at less force applied to moving the seat back with my hands) at certain seat positions, specifically when the seat bottom was lower to the ground. it got to a point where i could replicate the sound perfectly. i set this seat position to memory now, since i have to move the seat way up to work on it and i want to get back to this position quickly to see if the sound was fixed.
i actually used a stethoscope (i'm not kidding) to try to hear the resonance of the sound. listened in the seat itself, very muffled, didn't sound like it was coming from inside the seat. listened on the ground right under the seat, and viola.. metal resonance. it had to be something attached through some metal or something to the car body.
then i moved the seat all the way forward and up. i circled in red the area where i became sure the sound was coming from.
this next photo is a closeup of the part i approached first. it's the mechanism that controls the height of the seat bottom (rear portion). notice the wear pattern on the metal? it seemed to be more worn than the passenger side counterpart (i don't know if that's really important, but that's what got me to notice this part first).
so from here i did 2 things. first, i got my wrench and loosened the nut shown below. it was barely anything, just enough so i could relieve some pressure in that joint. it's a 1/2 inch bolt. (that's like a 13mm, right?)
second, i got some good old WD40 and greased up that joint. careful, of course, not to get it everywhere.
after this, i returned the seat to the memory position where i had originally heard the noise. moved around. no sound. started shaking my ***. no sound. test drive around the block. no sound. excitement. happy. celebration. another test drive just to make sure. no sound. post!
sorry its so long and wordy, i wanted to be as detailed as possible in the case anyone else might find this helpful. hopefully, not many will have an this kind of thing. if ya do, hopefully its something easy to fix like an over-tightened bolt.
i missed my classes today for this. i'm just glad it's gone. stupid mercedes for making me fix a noise on a new car! but i still love my baby.
and yes, my car was made in south africa. it's an "R". coincidence? shrug.
And if it makes you feel any better, my car was made in Germany, not South Africa. So it must be a design issue and not a build quality issue.
awesome man, what a easy fix! someone else had posted something like that in the other thread and was the first place i looked, hoping that would fix the problem. but alas, it was not.
but i think the fix honestly had more to do with the loosening of the bolt, because i tried lubricating all the metal joints in first without any result. of course, now that it is loosened enough where it is normal, the little lube will make a big difference.
btw... to those without this issue this whole thing might seem trivial, but let me just say...
WOW. i'm so so happy that this creaking sound is gone. it really feels like a new car now.
now instead of this loud SHRIEK!, i get a very soft squeak which I can tolerate...truly thanks for this...it definitely works...
and for those that wonder just how to see the screw, you don't need to take anything off...just adjust your seat so that it tilts completely forward and UP....
thanks again!
its crazy how much difference a little creaking sound makes when you know you're driving in a car of this caliber. stupid mercedes for overtightening my screw!
sanjuro, hope you can somehow get rid of it 100%. maybe some more grease?
thanks so much!
They are currently ordering the part and I'll have to wait a few weeks...its not a big deal tho...since I already got rid of the sound, they just said its under warranty, so watever...
Can you kindly post the recall number or notice?
I would like this changed.
Thanks!
However, as Sanjuro Makabe posted, I wonder if there is any replacement solutions for seat issue? Could you let me informed?
