Rightside ****ed?
Old Jan 9, 2009 | 01:20 AM
desi_benz's Avatar
009 BENZ C300
Rightside ****ed?
I have the c300 4matic i always feel that its slightly going to the right when im driving. Even the right turns are more kinda stiff. Is it like this with every c300 or just mine ?
Old Jan 9, 2009 | 05:30 AM
akbro93704's Avatar
2014 C250 sport
Your car should naturally drift to the right when you let go of the steering wheel, but gradually. My C300, especially on the freeway, immediately starts drifting to the right when I'm not holding the steering wheel. My dealer says this is "normal", even after a mechanic drove it. I beg to differ.
Old Jan 9, 2009 | 08:18 AM
C300Sport's Avatar
2008 C300 Sport 6 Speed Manual, 1953 Chevy Bel-Air, 2015 Audi allroad, 1963 Chevy Apache
Most roads are bermed in the center to allow water to run off efficiently. In the States that means your car should generally drift to the right. Find a safe stretch of road, parking lot, etc that is sloped to the left and see if the car still drifts right or even stays straight. If all is aligned properly, it should begin drifting left on pavement sloped to the left.
Old Jan 9, 2009 | 09:14 AM
dalazernet's Avatar
2020 GLC300 4MATIC
The question really is -- where does the car go if you hold the steering wheel perfectly straight/level? Does it go straight? If so, your steering center is aligned properly, then you can test if it is pulling in which case you may need alignment work - for this, go to a parking garage or some side streets where you can drive right in the middle of the road to prevent any possibly curvature of the surface to help rainwater drain properly...
If your car continues to pull to the right then you need your alignment fixed - I just had this done in fact because I smacked a BIG pothole - gotta love these NJ roads. My car was continuously pulling ever so slightly to the right -- no matter what road I was on... I always had to hold the steering wheel slightly turned to the left to stay going straight. Now, the vehicle tracks PERFECTLY. I couldn't be more pleased with this car - in fact its driving straighter than when I first got it...
Old Jan 9, 2009 | 01:15 PM
tpick23's Avatar
E63
Mine (350) did the same thing, always pulled (slightly) to the right so I had to keep pressure on the wheel to hold it left. I took it in and tech went for a ride and said nothing was wrong, whatever DBag. Took it back again, the SA finally agreed and did the complementary alignment, now it is fine although i did have a mishap when I left the dealer......irony sucks
https://mbworld.org/forums/c-class-w...tml?highlight=
Old Jan 10, 2009 | 11:06 AM
Krytech's Avatar
2014 Ghibli S Q4 & 2008 C350
Mine has always driven straight as an arrow.
Old Jan 10, 2009 | 06:52 PM
ShoremNJ's Avatar
ML 350-Black=Sold. New 08 C300 4Matic, Black/Black, P1, Ipod, Auto7speed, 10/10 hit 100,000 miles
30,000 miles and mine is straight as an arrow, tried it today on the highway.
Old Jan 11, 2009 | 12:20 PM
evanswan's Avatar
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
issue
has same problem, tech said same thing. so I finaly got them to do a free alighment, and it helped a little. I put a little more air in the right front tire and a bit less in the rear tire left tire. I got an 08 honda accord the same month and that thing was strait as an arrow. It makes me wonder what the f mercedes is doing.
