HID hedlights
Old Jan 21, 2009 | 07:32 PM
andrusha's Avatar
C250 12 / CLK63 BS / ML63 09 / GTR 2012
HID hedlights
Im having some glare problems with my HID lights I installed. Is there a way to adjust them?
Old Jan 21, 2009 | 11:42 PM
RafaHim's Avatar
C300 Luxury w/sport grille
If it's the direction you can tilt it vertically and horizontally with some white knobs that are behind and on top of the housing
Old Jan 22, 2009 | 08:01 AM
andrusha's Avatar
what about glare on the sides?
Old Jan 22, 2009 | 04:53 PM
RafaHim's Avatar
hmm... I don't know about that :S Is it maybe the intensity/temperature on your kit? Did you by chance move the direction of the bulbs when installing?
I have a 35w 6000k kit and I don't see any glare... where is it coming from?
Old Jan 22, 2009 | 05:38 PM
andrusha's Avatar
I see my on the side when I drive in the tunnel or garage I get glare on the walls it almost looks like eyebrows making that light but its not. I have 55w 6k DDM Tunning.
Should I move my bulbs around?
Old Jan 25, 2009 | 10:38 PM
RafaHim's Avatar
I haven't driven mine through a tunnel so I can't compare... but my last car had factory HIDs and if I recall correctly they projected what I would say looked like a rectangle in front of the car... so maybe it is normal... however, you might want to try taking it to a shop to get the angles checked... or, I think there was an explanation here on how to do it yourself... but just to be safe, I would take it somewhere... it should be quick and inexpensive.
Old Jan 26, 2009 | 06:07 PM
siejoka's Avatar
2008 C300 Sport
Hey Andrusha, I have 55W DDM Tuning kit also, did you get the error canceler with that? Also, for some reason I couldn't get the bulb to light up more than 5 secs, do you happen to know why?
Old Jan 26, 2009 | 08:36 PM
andrusha's Avatar
Yes you do need error canceler that would make your bulbs function properly.
Just plug those in and you should be set to go.
Old Jan 26, 2009 | 09:02 PM
siejoka's Avatar
2008 C300 Sport
Awesome, thanks so much dude!
Old Jan 26, 2009 | 10:32 PM
andrusha's Avatar
no prob
